1.sciagnolem ndiswarper (
aptitude install ndiswrapperKod: Zaznacz cały
Sebubu:/home/sebolbo/Desktop# ndiswrapper -l
installed drivers:
net8187b driver installed, hardware (0BDA:8189) present
Sebubu:/home/sebolbo/Desktop# dmesg
Linux version 2.6.18-5-686 (Debian 2.6.18.dfsg.1-13etch4) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed Oct 3 00:12:50 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000007f6d0000 (usable)
BIOS-e820: 000000007f6d0000 - 000000007f6e3000 (ACPI NVS)
BIOS-e820: 000000007f6e3000 - 0000000080000000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fed00000 - 00000000fed00400 (reserved)
BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
1142MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000f6a70
On node 0 totalpages: 521936
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 292560 pages, LIFO batch:31
DMI 2.4 present.
ACPI: RSDP (v002 PTLTD ) @ 0x000f69d0
ACPI: XSDT (v001 GATEWA SYSTEM 0x20070712 LTP 0x00000000) @ 0x7f6d6bac
ACPI: FADT (v003 GATEWA SYSTEM 0x20070712 ALAN 0x00000001) @ 0x7f6dfc3a
ACPI: HPET (v001 GATEWA SYSTEM 0x20070712 LOHR 0x0000005a) @ 0x7f6dfd2e
ACPI: MCFG (v001 GATEWA SYSTEM 0x20070712 LOHR 0x0000005a) @ 0x7f6dfd66
ACPI: TCPA (v001 GATEWA SYSTEM 0x20070712 0x00005a52) @ 0x7f6dfda2
ACPI: TMOR (v001 GATEWA SYSTEM 0x20070712 PTL 0x00000003) @ 0x7f6dfdd4
ACPI: SLIC (v001 GATEWA SYSTEM 0x20070712 LTP 0x00000000) @ 0x7f6dfdfa
ACPI: MADT (v001 GATEWA SYSTEM 0x20070712 LTP 0x00000000) @ 0x7f6dff70
ACPI: BOOT (v001 GATEWA SYSTEM 0x20070712 LTP 0x00000001) @ 0x7f6dffd8
ACPI: SSDT (v001 PmRef Cpu0Tst 0x00003000 INTL 0x20050624) @ 0x7f6d71b4
ACPI: SSDT (v001 PmRef Cpu1Tst 0x00003000 INTL 0x20050624) @ 0x7f6d710e
ACPI: SSDT (v001 PmRef CpuPm 0x00003000 INTL 0x20050624) @ 0x7f6d6c28
ACPI: DSDT (v002 GATEWA SYSTEM 0x20070712 INTL 0x20050624) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:15 APIC version 20
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Processor #1 6:15 APIC version 20
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x8086a201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 88000000 (gap: 80000000:60000000)
Detected 1463.171 MHz processor.
Built 1 zonelists. Total pages: 521936
Kernel command line: root=/dev/sda3 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 2062300k/2087744k available (1541k kernel code, 24248k reserved, 576k data, 196k init, 1170240k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet0: at MMIO 0xfed00000 (virtual 0xf8800000), IRQs 2, 8, 0
hpet0: 3 64-bit timers, 14318180 Hz
Using HPET for base-timer
Calibrating delay using timer specific routine.. 2929.60 BogoMIPS (lpj=5859212)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000e39d 00000000 00000001
CPU: After vendor identify, caps: bfebfbff 20100000 00000000 00000000 0000e39d 00000000 00000001
monitor/mwait feature present.
using mwait in idle threads.
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 1024K
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
CPU: After all inits, caps: bfebfbff 20100000 00000000 00000940 0000e39d 00000000 00000001
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
CPU0: Intel(R) Pentium(R) Dual CPU T2310 @ 1.46GHz stepping 0d
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine.. 2926.04 BogoMIPS (lpj=5852081)
CPU: Processor Core ID: 1
Intel machine check reporting enabled on CPU#1.
CPU1: Intel(R) Pentium(R) Dual CPU T2310 @ 1.46GHz stepping 0d
Total of 2 processors activated (5855.64 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking TSC synchronization across 2 CPUs: passed.
Brought up 2 CPUs
migration_cost=32
checking if image is initramfs... it is
Freeing initrd memory: 4401k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:00:02.0
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: Embedded Controller [EC0] (gpe 27) interrupt mode.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 10 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
PCI: Bridge: 0000:00:1c.0
IO window: 2000-2fff
MEM window: f0200000-f02fffff
PREFETCH window: f0800000-f08fffff
PCI: Bridge: 0000:00:1c.2
IO window: 3000-3fff
MEM window: f0300000-f03fffff
PREFETCH window: f0900000-f09fffff
PCI: Bridge: 0000:00:1c.5
IO window: 4000-4fff
MEM window: f0400000-f04fffff
PREFETCH window: 88000000-880fffff
PCI: Bridge: 0000:00:1e.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1c.0 to 64
ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1c.2 to 64
ACPI: PCI Interrupt 0000:00:1c.5[B] -> GSI 16 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:1c.5 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
Simple Boot Flag at 0x36 set to 0x1
audit: initializing netlink socket (disabled)
audit(1195665992.032:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:1c.:p cie00]
Allocate Port Service[0000:00:1c.:p cie02]
Allocate Port Service[0000:00:1c.:p cie03]
Allocate Port Service[0000:00:1c.2 :p cie00]
Allocate Port Service[0000:00:1c.2 :p cie02]
Allocate Port Service[0000:00:1c.2 :p cie03]
Allocate Port Service[0000:00:1c.5 :p cie00]
Allocate Port Service[0000:00:1c.5 :p cie02]
Allocate Port Service[0000:00:1c.5 :p cie03]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Starting balanced_irq
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu0Cst] [20060707]
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU0] (supports 8 throttling states)
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Ist] [20060707]
ACPI (exconfig-0455): Dynamic SSDT Load - OemId [ PmRef] OemTableId [ Cpu1Cst] [20060707]
ACPI: CPU1 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU1] (supports 8 throttling states)
ACPI: Thermal Zone [TZ00] (45 C)
Time: hpet clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:1a.0 to 64
uhci_hcd 0000:00:1a.0: UHCI Host Controller
uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1a.0: irq 185, io base 0x00001820
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:1a.1 to 64
uhci_hcd 0000:00:1a.1: UHCI Host Controller
uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1a.1: irq 225, io base 0x00001840
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
SCSI subsystem initialized
libata version 2.00 loaded.
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.0: irq 233, io base 0x00001860
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 50
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.1: irq 50, io base 0x00001880
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1d.2: irq 177, io base 0x000018a0
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1a.7 to 64
ehci_hcd 0000:00:1a.7: EHCI Host Controller
ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 6
ehci_hcd 0000:00:1a.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1a.7
ehci_hcd 0000:00:1a.7: irq 177, io mem 0xf0704800
ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb6: configuration #1 chosen from 1 choice
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 4 ports detected
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 7
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 233, io mem 0xf0704c00
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb7: configuration #1 chosen from 1 choice
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 6 ports detected
ahci 0000:00:1f.2: version 2.0
ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 50
usb 6-1: new high speed USB device using ehci_hcd and address 2
usb 6-1: configuration #1 chosen from 1 choice
usb 6-3: new high speed USB device using ehci_hcd and address 3
usb 6-3: configuration #1 chosen from 1 choice
PCI: Setting latency timer of device 0000:00:1f.2 to 64
ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x7 impl SATA mode
ahci 0000:00:1f.2: flags: 64bit ncq ilck pm led clo pio slum part
ata1: SATA max UDMA/133 cmd 0xF883C100 ctl 0x0 bmdma 0x0 irq 58
ata2: SATA max UDMA/133 cmd 0xF883C180 ctl 0x0 bmdma 0x0 irq 58
ata3: SATA max UDMA/133 cmd 0xF883C200 ctl 0x0 bmdma 0x0 irq 58
scsi0 : ahci
usb 7-5: new high speed USB device using ehci_hcd and address 2
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-8, max UDMA/133, 234441648 sectors: LBA48 NCQ (depth 31/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi1 : ahci
ata2: SATA link down (SStatus 0 SControl 300)
scsi2 : ahci
usb 7-5: configuration #1 chosen from 1 choice
Initializing USB Mass Storage driver...
scsi3 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
ata3: SATA link down (SStatus 0 SControl 300)
Vendor: ATA Model: WDC WD1200BEVS-2 Rev: 01.0
Type: Direct-Access ANSI SCSI revision: 05
r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
ACPI: PCI Interrupt 0000:06:00.0[A] -> GSI 17 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:06:00.0 to 64
eth0: RTL8101e at 0xf8834000, 00:e0:b8:df:27:84, IRQ 169
ICH8M: IDE controller at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 19 (level, low) -> IRQ 50
ICH8M: chipset revision 3
ICH8M: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x1810-0x1817, BIOS settings: hda :D MA, hdb :p io
Probing IDE interface ide0...
SCSI device sda: 234441648 512-byte hdwr sectors (120034 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: Attached scsi disk sda
hda: Optiarc DVD RW AD-7560A, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Real Time Clock Driver v1.12ac
input: PC Speaker as /class/input/input1
ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 19 (level, low) -> IRQ 50
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 66
PCI: Setting latency timer of device 0000:00:1b.0 to 64
Synaptics Touchpad, model: 1, fw: 6.2, id: 0x12a0b1, caps: 0xa04713/0x204000
input: SynPS/2 Synaptics TouchPad as /class/input/input2
ts: Compaq touchscreen protocol output
Vendor: Generic- Model: Multi-Card Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 00
sd 3:0:0:0: Attached scsi removable disk sdb
usb-storage: device scan complete
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: [email]dm-devel@redhat.com[/email]
ndiswrapper version 1.28 loaded (preempt=no,smp=yes)
usb 6-1: reset high speed USB device using ehci_hcd and address 2
ndiswrapper: driver net8187b (Realtek Semiconductor Corp.,01/19/2007,5.1056.0119.2007) loaded
wlan0: vendor: 'Realtek RTL8187 Wireless LAN USB NIC '
wlan0: ethernet device 00:c0:a8:fd:86:d6 using NDIS driver net8187b, 0BDA:8189.F.conf
wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
usbcore: registered new driver ndiswrapper
ACPI: Battery Slot [BAT1] (battery absent)
ACPI: AC Adapter [ACAD] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
ACPI: Power Button (CM) [PWRB]
ACPI: Sleep Button (CM) [SLPB]
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
r8169: eth0: link up
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
mtrr: no more MTRRs available
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): wlan0: link is not ready
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
r8169: eth0: link down
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sebubu:/home/sebolbo/Desktop# dmesg | grep ndiswrapper
Sebubu:/home/sebolbo/Desktop# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11g ESSID :o ff/any
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Bit Rate:54 Mb/s Tx-Power:20 dBm Sensitivity=0/3
RTS thr:2346 B Fragment thr:2347 B
Encryption key:6E69-7665-61 Security mode:restricted
Power Management :o ff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
sit0 no wireless extensions.
wienc wklepuje :
Sebubu:/home/sebolbo/Desktop# iwconfig wlan0 essid <jakas> key s: <jakis>
Sebubu:/home/sebolbo/Desktop# dhclient
Internet Systems Consortium DHCP Client V3.0.4
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit [url]http://www.isc.org/sw/dhcp/[/url]
Listening on LPF/wlan0/00:c0:a8:fd:86:d6
Sending on LPF/wlan0/00:c0:a8:fd:86:d6
Listening on LPF/eth0/00:e0:b8:df:27:84
Sending on LPF/eth0/00:e0:b8:df:27:84
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 18
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
dodam ze w srodowisko->preferencje->ustawiania sieci widzi karte...i niby wrzystko ok ...tylko nie laczy mi sie..juz mnie poprostu nosi bo czytam i szukam i nie spotkalem sie z takim problemem rozwiazaniem...kazda podpowiedziec mile widziana..bo vista mnie meczy
acha dodaje jeszcze lspci po juz zaladowaniu modulu ndiswrapper ... :
Sebubu:/home/sebolbo/Desktop# lspci
00:00.0 Host bridge: Intel Corporation Mobile Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile Integrated Graphics Controller (rev 03)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1c.5 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 6 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation Mobile LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation Mobile IDE Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Mobile SATA AHCI Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E PCI Express Fast Ethernet controller (rev 01)
/var log/syslog tzn to co z ndiswrapperem jest ..najswierzsze :
Nov 21 18:27:58 Sebubu kernel: ndiswrapper version 1.28 loaded (preempt=no,smp=yes)
Nov 21 18:27:58 Sebubu kernel: usb 6-1: reset high speed USB device using ehci_hcd and address 2
Nov 21 18:27:58 Sebubu kernel: ndiswrapper: driver net8187b (Realtek Semiconductor Corp.,01/19/2007,5.1056.0119.2007) loadedNov 21 18:27:58 Sebubu kernel: wlan0: vendor: 'Realtek RTL8187 Wireless LAN USB NIC '
Nov 21 18:27:58 Sebubu kernel: wlan0: ethernet device 00:c0:a8:fd:86:d6 using NDIS driver net8187b, 0BDA:8189.F.conf
Nov 21 18:27:58 Sebubu kernel: wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA$Nov 21 18:27:58 Sebubu kernel: usbcore: registered new driver ndiswrapper
[ Dodano: 2007-11-22, 01:25 ]
znalazlem gdzies ze nie dzialaja stery z XP i zeby zainstalowac z win98...wienc tak zrobilem i tez widzie karte ale wciaz sie nielaczy robie tak :
1.modprobe -r ndiswrapper
2.ndiswrapper -r net8187b.inf
3.module-assistant ->buuild->install ndiswrapper
4.ndiswrapper -i /stery/win98/net8187b.inf
5.ndiswrapper -m
i tu sie pojawia problem :
Sebubu:/etc# ndiswrapper -m
adding "alias wlan0 ndiswrapper" to /etc/modprobe.d/ndiswrapper ...
couldn't add module alias: at /usr/sbin/ndiswrapper-1.9 line 717.
printf "adding \"alias wlan0 ndiswrapper\" to $modconf ...\n";
system("echo \"alias wlan0 ndiswrapper\" >>$modconf") or
die "couldn't add module alias: $!";
if (-x "/sbin/update-modules")
system("/sbin/update-modules");
return 0;
[ Dodano: 2007-11-22, 01:26 ]
ale przechodze dalej i robie :
modprobe ndiswrapperwciaz to samo po wykonaniu polecenia dhclient ...
rece opadaja..
