[+] vmware, problem z konfiguracja
Beynar
Post autor: Beynar »
rozpakowalem, zainstalowalem i konfiguruje zgodnie z opisem kaki http://kaka.ovh.org/howto/vmware/
Jednek w pewnym momencie kofigruacja zwraca mi cos takiego:
Your kernel was built with "gcc" version "4.1.3", while you are trying to use
"/usr/bin/gcc" version "4.2.3". This configuration is not recommended and
VMware Server may crash if you'll continue. Please try to use exactly same
compiler as one used for building your kernel. Do you want to go with compiler
"/usr/bin/gcc" version "4.2.3" anyway? [no] yes
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.22-2-amd64/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Building for VMware Server 1.0.0.
Using 2.6.x kernel build system.
make: Wejście do katalogu `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.22-2-amd64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/linux-headers-2.6.22-2-amd64'
/tmp/vmware-config0/vmmon-only/Makefile:127: *** Inappropriate build environment: you wanted to use gcc version 4.2.3 while kernel attempts to use gcc version 4.1.3.
/tmp/vmware-config0/vmmon-only/Makefile:129: *** For proper build you'll have to replace  gcc-4.1 with symbolic link to /usr/bin/gcc. Stop.
make[1]: *** [_module_/tmp/vmware-config0/vmmon-only] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/linux-headers-2.6.22-2-amd64'
make: *** [vmmon.ko] Błąd 2
make: Opuszczenie katalogu `/tmp/vmware-config0/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
lanceroot:/vmware/vmware-any-any-update114#
Domyslam sie, ze to przez to ze najpierw mialem etcha ktory uzywal gcc 4.1.3 ale po przejsciu na lenny mam teraz 4.2.3, jak jednak moge to rozwiazac?
Moj system:
Linux lanceroot 2.6.22-2-amd64 #1 SMP Thu Aug 30 23:43:59 UTC 2007 x86_64 GNU/Linux
//edit
poprawiłem tytuł tematu - nie dodajemy [solved], ale [+] na początku
mlyczek
Duncan Idaho
Post autor: Duncan Idaho »
Beynar pisze:Domyslam sie, ze to przez to ze najpierw mialem etcha ktory uzywal gcc 4.1.3 ale po przejsciu na lenny mam teraz 4.2.3, jak jednak moge to rozwiazac?
Bardzo prosto.. system nawet podał ci rozwiązanie
Beynar pisze:*** For proper build you'll have to replace gcc-4.1 with symbolic link to /usr/bin/gcc. Stop.
Po prostu musisz zastąpić symlinka /usr/bin/gcc (teraz pokazuje na /usr/bin/gcc-4.2) tak aby wskazywał na starszą wersję (/usr/bin/gcc-4.1)
rm /usr/bin/gcc
ln -s /usr/bin/gcc-4.1 /usr/bin/gcc
aby przywrócić poprzednie ustawienia po insatalacji vmware
rm /usr/bin/gcc
ln -s /usr/bin/gcc-4.2 /usr/bin/gcc
Mam nadzieję że nic nie poknociłem - robiłem to jakiś czas temu jak sam instalowałem vmware na moim Sidzie
Bober
Post autor: Bober »
Utworz dowiazanie symboliczne do gcc z ktorego chce korzystac tak jak napisal poprzednik. U mnie zabieg ten pomaga nie tylko z Vmware.
Beynar
Stworzylem poprawnie dowiązanie, puszczam tego configa i znowu zwraca cos takiego:
  CC [M]  /tmp/vmware-config0/vmmon-only/linux/driver.o
  CC [M]  /tmp/vmware-config0/vmmon-only/linux/hostif.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/comport.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/cpuid.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/hash.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/memtrack.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/phystrack.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/task.o
gcc-4.1: error trying to exec 'cc1plus': execvp: Nie ma takiego pliku ani katalogu
make[2]: *** [/tmp/vmware-config0/vmmon-only/common/task.o] Błąd 1
Execution aborted.
Dowiazanie jest zrobione napewno dobrze wiec czemu ma taki problem jeszcze?
Bober
Post autor: Bober »
zainstaluj gcc-4.1
apt-get install gcc-4.1
Beynar
Mam zainstalowane
ale na wszelki wypadek go usunalem i zainstalowalem jeszcze raz
Jako, ze usunal tez headersy to i je zainstalowalem ponownie
Niestety wciaz ten sam blad jak powyzej :(
Duncan Idaho
A masz zainstalowane build-essential?? Jak nie to zainstaluj. To podstawowy pakiet do kompilowania źródeł.
Jak wkleisz ten błąd:
W google to wyrzuca że to z powodu braku paczek gcc itp...
To są moje paczki gcc:
g++
g++-4.2
gcc
gcc-3.3-base
gcc-3.4-base
gcc-4.1
gcc-4.1-base
gcc-4.2
gcc-4.2-base
To paczki z sida ale w lenny'm powinny być podobne (najwyżej numerki będą mieć inne)
A najlepszym narzędziem do sprawdzania błędów jest Google....
Beynar
Posiadam wszystkie w/w wymienione paczki
salmon
Post autor: salmon »
a co pokazuje
locate cc1plus
Beynar
salmon pisze:a co pokazuje
locate cc1plus
zwraca:
/usr/lib/gcc/x86_64-linux-gnu/4.2/cc1plus
