compiz GLX
zomer
compiz GLX
Post autor: zomer »
Problem polega na tym że po wpisaniu polecenia
compiz --replace
Wyżuca taki błąd
 $ libGL warning: 3D driver claims to not support visual 0x4b
Pomocy! Moja walka z copizem jest nierówna.
Compiz się uruchamia, ale nie mam obramowań na oknach i okna się jakby zawieszają.
Moj xorg.conf
# package.
Section "Files"
	FontPath	"/usr/share/fonts/X11/misc"
	FontPath	"/usr/X11R6/lib/X11/fonts/misc"
	FontPath	"/usr/share/fonts/X11/cyrillic"
	FontPath	"/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/Type1"
	FontPath	"/usr/X11R6/lib/X11/fonts/Type1"
	FontPath	"/usr/share/fonts/X11/100dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath	"/usr/share/fonts/X11/75dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load	"i2c"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"vbe"
	Load    "dbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
Section "Device"
	Identifier	"ATI Technologies Inc RV280 [Radeon 9200 SE]"
	Driver		"ati"
	BusID		"PCI:1:0:0"
	Option "AddARGBGLXVisuals" "On"
	Option "XAANoOffscreenPixmaps" "true"
	Option "RenderAccel" "true"
	EndSection
Section "Monitor"
	Identifier	"FLATRON 775F"
	Option		"DPMS"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"ATI Technologies Inc RV280 [Radeon 9200 SE]"
	Monitor		"FLATRON 775F"
	DefaultDepth	24
	SubSection "Display"
		Depth		1
		Modes		"1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
	EndSubSection
		Depth		4
	EndSubSection
		Depth		8
	EndSubSection
		Depth		15
	EndSubSection
		Depth		16
	EndSubSection
		Depth		24
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	Screen		"Default Screen"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
	Option 		"AIGLX" "true"
EndSection
Section "DRI"
	Mode	0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
