postfix problem
gribollo
postfix problem
Post autor: gribollo »
witam mam taki problem bo nie moge uruchomić postfix robie zgodnie z opisem http://forum.dug.net.pl/viewtopic.php?t=6331 jak wpisze telnet localhost 25
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
220 domena.pl ESMTP Exim4 (GENTOO/GNU)
500 5.5.2 Error: bad syntax
zgóry dzieki
//używaj tagów code
ruun
ruun
Post autor: ruun »
bad syntax
Masz błąd składni w jakimś pliku konfiguracyjnym (prawdopodobnie w /etc/postfix/main.cf).
gribollo
mój plik wyglonda tak co jest nie tak
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
myhostname = localhost
#mydestination = gieldowyrynek.pl, localhost, localhost.localdomain, localhost
relayhost =
mynetworks = 127.0.0.0/8
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
[size=200][ [i][b]Dodano[/b]: 2007-11-06, 15:15[/i] ][/size]
sory tak
# is /etc/mailname.
biff = no
# TLS parameters
smtpd_use_tls=yes
relayhost =
virtual_maps = hash:/etc/postfix/virtusertable
mydestination = /etc/postfix/local-host-names
transport_maps = hash:/etc/postfix/transport
relay_domains = hash:/etc/postfix/relay-host-names
mailman_destination_recipient_limit = 1
//używaj tagów code i popraw orta!
ruun
