configure i b
zomer
configure i błąd z QT
Post autor: zomer »
Witam!
Prubuję skompilować kydpdict za pomocą polecenia
.configure
Ale otrzymuje komunikat o błędzie
checking for Qt library name... failed
configure: error: Cannot compile a simple Qt executable. Check you have the righ
Nie mam już pomysłu co mam doinstalować żeby skompilować ten program?
Oto cały log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by kydpdict configure 0.9.2, which was
generated by GNU Autoconf 2.59.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = debiao
uname -m = i686
uname -r = 2.6.18-4-k7
uname -s = Linux
uname -v = #1 SMP Mon Mar 26 17:57:15 UTC 2007
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = i686
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
hostinfo               = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/bin/X11
## Core tests. ##
configure:1348: checking for gcc
configure:1364: found /usr/bin/gcc
configure:1374: result: gcc
configure:1618: checking for C compiler version
configure:1621: gcc --version </dev/null >&5
gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:1624: $? = 0
configure:1626: gcc -v </dev/null >&5
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --with-tune=i686 --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
configure:1629: $? = 0
configure:1631: gcc -V </dev/null >&5
gcc: '-V' option must have argument
configure:1634: $? = 1
configure:1657: checking for C compiler default output file name
configure:1660: gcc    conftest.c  >&5
configure:1663: $? = 0
configure:1709: result: a.out
configure:1714: checking whether the C compiler works
configure:1720: ./a.out
configure:1723: $? = 0
configure:1740: result: yes
configure:1747: checking whether we are cross compiling
configure:1749: result: no
configure:1752: checking for suffix of executables
configure:1754: gcc -o conftest    conftest.c  >&5
configure:1757: $? = 0
configure:1782: result:
configure:1788: checking for suffix of object files
configure:1809: gcc -c   conftest.c >&5
configure:1812: $? = 0
configure:1834: result: o
configure:1838: checking whether we are using the GNU C compiler
configure:1862: gcc -c   conftest.c >&5
configure:1868: $? = 0
configure:1872: test -z
			 || test ! -s conftest.err
configure:1875: $? = 0
configure:1878: test -s conftest.o
configure:1881: $? = 0
configure:1894: result: yes
configure:1900: checking whether gcc accepts -g
configure:1921: gcc -c -g  conftest.c >&5
configure:1927: $? = 0
configure:1931: test -z
configure:1934: $? = 0
configure:1937: test -s conftest.o
configure:1940: $? = 0
configure:1951: result: yes
configure:1968: checking for gcc option to accept ANSI C
configure:2038: gcc  -c -g -O2  conftest.c >&5
configure:2044: $? = 0
configure:2048: test -z
configure:2051: $? = 0
configure:2054: test -s conftest.o
configure:2057: $? = 0
configure:2075: result: none needed
configure:2093: gcc -c -g -O2  conftest.c >&5
conftest.c:2: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'me'
configure:2099: $? = 1
configure: failed program was:
| #ifndef __cplusplus
|   choke me
| #endif
configure:2237: checking how to run the C preprocessor
configure:2272: gcc -E  conftest.c
configure:2278: $? = 0
configure:2310: gcc -E  conftest.c
conftest.c:9:28: error: ac_nonexistent.h: No such file or directory
configure:2316: $? = 1
| /* confdefs.h.  */
| #define PACKAGE_NAME "kydpdict"
| #define PACKAGE_TARNAME "kydpdict"
| #define PACKAGE_VERSION "0.9.2"
| #define PACKAGE_STRING "kydpdict 0.9.2"
| #define PACKAGE_BUGREPORT "ytm@elysium.pl"
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:2355: result: gcc -E
configure:2379: gcc -E  conftest.c
configure:2385: $? = 0
configure:2417: gcc -E  conftest.c
configure:2423: $? = 1
| /* confdefs.h.  */
configure:2512: checking for gcc
configure:2538: result: gcc
configure:2782: checking for C compiler version
configure:2785: gcc --version </dev/null >&5
configure:2788: $? = 0
configure:2790: gcc -v </dev/null >&5
Thread model: posix
configure:2793: $? = 0
configure:2795: gcc -V </dev/null >&5
configure:2798: $? = 1
configure:2801: checking whether we are using the GNU C compiler
configure:2857: result: yes
configure:2863: checking whether gcc accepts -g
configure:2914: result: yes
configure:2931: checking for gcc option to accept ANSI C
configure:3038: result: none needed
configure:3056: gcc -c -g -O2  conftest.c >&5
configure:3062: $? = 1
| #ifndef __cplusplus
|   choke me
| #endif
configure:3247: checking for g++
configure:3263: found /usr/bin/g++
configure:3273: result: g++
configure:3289: checking for C++ compiler version
configure:3292: g++ --version </dev/null >&5
g++ (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
configure:3295: $? = 0
configure:3297: g++ -v </dev/null >&5
Thread model: posix
configure:3300: $? = 0
configure:3302: g++ -V </dev/null >&5
g++: '-V' option must have argument
configure:3305: $? = 1
configure:3308: checking whether we are using the GNU C++ compiler
configure:3332: g++ -c   conftest.cc >&5
configure:3338: $? = 0
configure:3342: test -z
configure:3345: $? = 0
configure:3348: test -s conftest.o
configure:3351: $? = 0
configure:3364: result: yes
configure:3370: checking whether g++ accepts -g
configure:3391: g++ -c -g  conftest.cc >&5
configure:3397: $? = 0
configure:3401: test -z
configure:3404: $? = 0
configure:3407: test -s conftest.o
configure:3410: $? = 0
configure:3421: result: yes
configure:3463: g++ -c -g -O2  conftest.cc >&5
configure:3469: $? = 0
configure:3473: test -z
configure:3476: $? = 0
configure:3479: test -s conftest.o
configure:3482: $? = 0
configure:3508: g++ -c -g -O2  conftest.cc >&5
conftest.cc: In function 'int main()':
conftest.cc:13: error: 'exit' was not declared in this scope
configure:3514: $? = 1
| /* confdefs.h.  */
| int
| main ()
| exit (42);
|   return 0;
configure:3514: $? = 0
configure:3518: test -z
configure:3521: $? = 0
configure:3524: test -s conftest.o
configure:3527: $? = 0
configure:3555: checking how to run the C++ preprocessor
configure:3586: g++ -E  conftest.cc
configure:3592: $? = 0
configure:3624: g++ -E  conftest.cc
conftest.cc:12:28: error: ac_nonexistent.h: No such file or directory
configure:3630: $? = 1
| /* confdefs.h.  */
| #ifdef __cplusplus
| extern "C" void std::exit (int) throw (); using std::exit;
| #endif
configure:3669: result: g++ -E
configure:3693: g++ -E  conftest.cc
configure:3699: $? = 0
configure:3731: g++ -E  conftest.cc
configure:3737: $? = 1
| /* confdefs.h.  */
| #ifdef __cplusplus
| #endif
configure:3777: checking whether make sets $(MAKE)
configure:3797: result: yes
configure:3808: checking for X
configure:3913: gcc -E  conftest.c
configure:3919: $? = 0
configure:3969: gcc -o conftest -g -O2   conftest.c -lXt  >&5
configure:3975: $? = 0
configure:3979: test -z
configure:3982: $? = 0
configure:3985: test -s conftest
configure:3988: $? = 0
configure:4038: result: libraries , headers
configure:4210: gcc -o conftest -g -O2   conftest.c   -lX11 >&5
configure:4216: $? = 0
configure:4220: test -z
configure:4223: $? = 0
configure:4226: test -s conftest
configure:4229: $? = 0
configure:4387: checking for gethostbyname
configure:4444: gcc -o conftest -g -O2   conftest.c  >&5
configure:4450: $? = 0
configure:4454: test -z
configure:4457: $? = 0
configure:4460: test -s conftest
configure:4463: $? = 0
configure:4475: result: yes
configure:4626: checking for connect
configure:4683: gcc -o conftest -g -O2   conftest.c  >&5
configure:4689: $? = 0
configure:4693: test -z
configure:4696: $? = 0
configure:4699: test -s conftest
configure:4702: $? = 0
configure:4714: result: yes
configure:4789: checking for remove
configure:4846: gcc -o conftest -g -O2   conftest.c  >&5
configure:4852: $? = 0
configure:4856: test -z
configure:4859: $? = 0
configure:4862: test -s conftest
configure:4865: $? = 0
configure:4877: result: yes
configure:4952: checking for shmat
configure:5009: gcc -o conftest -g -O2   conftest.c  >&5
configure:5015: $? = 0
configure:5019: test -z
configure:5022: $? = 0
configure:5025: test -s conftest
configure:5028: $? = 0
configure:5040: result: yes
configure:5124: checking for IceConnectionNumber in -lICE
configure:5154: gcc -o conftest -g -O2   conftest.c -lICE   >&5
configure:5160: $? = 0
configure:5164: test -z
configure:5167: $? = 0
configure:5170: test -s conftest
configure:5173: $? = 0
configure:5186: result: yes
configure:5196: checking whether byte ordering is bigendian
configure:5223: gcc -c -g -O2  conftest.c >&5
configure:5229: $? = 0
configure:5233: test -z
configure:5236: $? = 0
configure:5239: test -s conftest.o
configure:5242: $? = 0
configure:5266: gcc -c -g -O2  conftest.c >&5
conftest.c: In function 'main':
conftest.c:19: error: 'not' undeclared (first use in this function)
conftest.c:19: error: (Each undeclared identifier is reported only once
conftest.c:19: error: for each function it appears in.)
conftest.c:19: error: expected ';' before 'big'
configure:5272: $? = 1
| /* confdefs.h.  */
| #ifdef __cplusplus
| #endif
| #include <sys/types.h>
| #include <sys/param.h>
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
|  not big endian
| #endif
|   return 0;
configure:5407: result: no
configure:5475: checking for moc
configure:5517: result: /usr/bin/moc
configure:5548: checking for uic
configure:5590: result: /usr/bin/uic
configure:5605: checking for Qt library name
configure:5650: g++ -o conftest -g -O2     conftest.cc  -lqt3 >&5
conftest.cc:13:22: error: qglobal.h: No such file or directory
conftest.cc:14:22: error: qstring.h: No such file or directory
conftest.cc:22: error: stray '\' in program
conftest.cc:20: error: 'QString' was not declared in this scope
conftest.cc:20: error: expected `;' before 's'
conftest.cc:22: error: 'break_me_' was not declared in this scope
configure:5656: $? = 1
| /* confdefs.h.  */
| #ifdef __cplusplus
| #endif
| 	#include <qglobal.h>
| 	#include <qstring.h>
| int
| main ()
| 	QString s("mangle_failure");
| 	#if (QT_VERSION < 221)
| 	break_me_(\\);
| 	#endif
|   return 0;
configure:5650: g++ -o conftest -g -O2     conftest.cc  -lqt-mt >&5
| /* confdefs.h.  */
| #ifdef __cplusplus
| #endif
| int
| main ()
| 	break_me_(\\);
| 	#endif
|   return 0;
configure:5692: result: failed
configure:5695: error: Cannot compile a simple Qt executable. Check you have the right $QTDIR !
## Cache variables. ##
ac_cv_c_bigendian=no
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LRELEASE_set=
ac_cv_env_LRELEASE_value=
ac_cv_env_LUPDATE_set=
ac_cv_env_LUPDATE_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=
ac_cv_func_connect=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_remove=yes
ac_cv_func_shmat=yes
ac_cv_have_x='have_x=yes 		ac_x_includes= ac_x_libraries='
ac_cv_lib_ICE_IceConnectionNumber=yes
ac_cv_objext=o
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_stdc=
ac_cv_prog_cxx_g=yes
ac_cv_prog_make_make_set=yes
qt_cv_dir=
qt_cv_path_moc=/usr/bin/moc
qt_cv_path_uic=/usr/bin/uic
## Output variables. ##
CC='gcc'
CFLAGS='-g -O2'
CPP='gcc -E'
CPPFLAGS=''
CXX='g++'
CXXCPP='g++ -E'
CXXFLAGS='-g -O2'
DEFS=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
HAVE_X11=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LRELEASE=''
LTLIBOBJS=''
LUPDATE=''
MOC='/usr/bin/moc'
OBJEXT='o'
PACKAGE_BUGREPORT='ytm@elysium.pl'
PACKAGE_NAME='kydpdict'
PACKAGE_STRING='kydpdict 0.9.2'
PACKAGE_TARNAME='kydpdict'
PACKAGE_VERSION='0.9.2'
PATH_SEPARATOR=':'
QT_INCLUDES=''
QT_LDFLAGS=''
QT_LIB=''
QT_VERSION=''
SET_MAKE=''
SHELL='/bin/sh'
UIC='/usr/bin/uic'
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIB=''
X_LIBS=''
X_PRE_LIBS=' -lSM -lICE'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
bindir='${exec_prefix}/bin'
build_alias=''
datadir='${prefix}/share'
exec_prefix='NONE'
host_alias=''
includedir='${prefix}/include'
infodir='${prefix}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#endif
#ifdef __cplusplus
configure: exit 1
ruun
Post autor: ruun »
Zainstaluj pakiety:
libqt3-headers
libqt3-mt
libqt3-mt-dev
zomer
Post autor: zomer »
Podczas pruby instalacji każdego z tych trzech pakietów otrzymóję tą samą odpowiedz:
libqt3-mt-dev jest już w najnowszej wersji.
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 3 nieaktualizowanych.
Prubowałem wywołać ./configure z opcją:
./configure --with-qt-dir=/usr/share/qt3/
Ale może coś źle wpisuje?. Bo też otrzymóję komunikat o problemie ze znalezieniem Qt. Sprawdzałem, ścieżka /usr/share/qt3/ istnieje.
Lorenzo
Post autor: Lorenzo »
Spróbuj przed configure, wywołac
  • export QTDIR='/usr/share/qt3'
zomer
Byłbym wdzięczny za objaśnienie
Post autor: zomer »
Pomogło, ale nie rozumiem co wykonałem tym poleceniem? W "Linux Receptury" tego polecenia nie ma, to jedna z lepszych książek.
Powiedz co to polecenie robi, może się przyda w przyszłości.
Lorenzo
Ustawia zmienna środowiskową QTDIR. Ja się nie babram z qt, ale chyba skrypty configure są tak generowane, że sprawdzają istnienie tej opcji i jak jej nie ma ustawionej to się plują. Chociaż przy kompilacji np. kadu, zmienna ta może w systemie nie istnieć a kompilacja i tak sie uda ;-).
