Invoking /usr/lib/wine/wine.bin /media/disk-5/Virtua Tennis/VIRTUA_TENNIS_PC.exe ...
ALSA lib conf.c:3949 :( snd_config_expand) Unknown parameters 0
ALSA lib control.c:909 :( snd_ctl_open_noupdate) Invalid CTL default:0
ALSA lib seq_hw.c:457 :( snd_seq_hw_open) open /dev/snd/seq failed: Nie ma takiego pliku ani katalogu
fixme:win:EnumDisplayDevicesW ((null),0,0x33f524,0x00000000), stub!
fixme:d3d:IWineD3DDeviceImpl_GetAvailableTextureMem (0x126578) : stub, simulating 64MB for now, returning 64MB left
err :o le:CoInitializeEx Attempt to change threading model of this apartment from multi-threaded to apartment threaded
err:d3d:IWineD3DDeviceImpl_Reset Cannot change the back buffer format yet
err :o le:CoUninitialize Mismatched CoUninitialize
Wine exited with a successful status
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Sep 12 14:29:35 PDT 2007
# xorg.conf (xorg X Window System server configuration file)
# package.
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 28.0 - 51.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1024x768" "800x600" "640x480"
EndSubSection
Option "TripleBuffer" "true"
Option "no GLXFBConfig for depth 32"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "true"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
