KDE w wersji 3.5.7 zainstalowane na sid (było też na etch i lenny i problem był ten sam).
Kdepim/Kontact po uruchomieniu go mieli się przez pewien czas, a potem wywala błąd, że "uległ awarii wywołując sygnał 11 (SIGSEGV)".
¦lad wykonywanych czynności wygląda tak:
Using host libthread_db library "/lib/i686/cmov/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread 0xb5e136c0 (LWP 9936)]
[New Thread 0xb3259b90 (LWP 9940)]
[New Thread 0xb3a5ab90 (LWP 9939)]
[New Thread 0xb425bb90 (LWP 9938)]
[New Thread 0xb4a5cb90 (LWP 9937)]
[KCrash handler]
#6 0xb6e48d3c in QObject: :p arent (this=0x0) at ../include/qobject.h:154
#7 0xb6e494ff in QWidget: :p arentWidget (this=0x0, sameWindow=false)
at ../include/qwidget.h:878
#8 0xb6e83652 in QWidget::raise (this=0x0) at kernel/qwidget_x11.cpp:1869
#9 0xb288ae20 in Archive: :o pen () from /usr/lib/libbasketcommon.so
#10 0xb289d945 in BNPView::addWelcomeBaskets ()
#11 0xb289df79 in BNPView::lateInit () from /usr/lib/libbasketcommon.so
#12 0xb289ee62 in BNPView::qt_invoke () from /usr/lib/libbasketcommon.so
#13 0xb6f23b10 in QObject::activate_signal (this=0x864f218, clist=0x864f260,
o=0xbfda1428) at kernel/qobject.cpp:2356
#14 0xb72b332e in QSignal::signal (this=0x864f218, t0=@0x864f240)
at .moc/debug-shared-mt/moc_qsignal.cpp:100
#15 0xb6f42cc6 in QSignal::activate (this=0x864f218) at kernel/qsignal.cpp:212
#16 0xb6f4aeaa in QSingleShotTimer::event (this=0x864f1f0)
at kernel/qtimer.cpp:286
#17 0xb6eb836a in QApplication::internalNotify (this=0xbfda29c8,
receiver=0x864f1f0, e=0xbfda1768) at kernel/qapplication.cpp:2635
#18 0xb6eba193 in QApplication::notify (this=0xbfda29c8, receiver=0x864f1f0,
e=0xbfda1768) at kernel/qapplication.cpp:2358
#19 0xb75f9ff2 in KApplication::notify (this=0xbfda29c8, receiver=0x864f1f0,
event=0xbfda1768)
at /build/buildd/kdelibs-3.5.7.dfsg.1/./kdecore/kapplication.cpp:550
#20 0xb6e496c9 in QApplication::sendEvent (receiver=0x864f1f0,
event=0xbfda1768) at ../include/qapplication.h:520
#21 0xb6eab1b1 in QEventLoop::activateTimers (this=0x80abc28)
at kernel/qeventloop_unix.cpp:556
#22 0xb6e5e19a in QEventLoop: :p rocessEvents (this=0x80abc28, flags=3)
at kernel/qeventloop_x11.cpp:389
#23 0xb52dce00 in SummaryWidget::initDocuments (this=0x871a258)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/newsticker/summarywidget.cpp:145
#24 0xb52ddad0 in SummaryWidget (this=0x871a258, parent=0x863a130, name=0x0)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/newsticker/summarywidget.cpp:78
#25 0xb52dab2c in NewsTickerPlugin::createSummaryWidget (this=0x82c3c20,
parentWidget=0x863a130)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/newsticker/newsticker_plugin.cpp:42
#26 0xb52b996a in SummaryViewPart::updateWidgets (this=0x86ce2f8)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/summary/summaryview_part.cpp:179
#27 0xb52ba8a8 in SummaryViewPart::initGUI (this=0x86ce2f8, core=0x80cce80)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/summary/summaryview_part.cpp:395
#28 0xb52baee9 in SummaryViewPart (this=0x86ce2f8, core=0x80cce80,
aboutData=0x86b3da0, parent=0x82b7798, name=0xb52bcf27 "summarypart")
at /build/buildd/kdepim-3.5.7/./kontact/plugins/summary/summaryview_part.cpp:78
#29 0xb52b7041 in SummaryView::createPart (this=0x82b7798)
at /build/buildd/kdepim-3.5.7/./kontact/plugins/summary/summaryview_plugin.cpp:47
#30 0xb7d7d5c2 in Kontact::Plugin: :p art (this=0x82b7798)
at /build/buildd/kdepim-3.5.7/./kontact/interfaces/plugin.cpp:144
#31 0x0805cc30 in Kontact::MainWindow::selectPlugin (this=0x80cce80,
plugin=0x82b7798)
at /build/buildd/kdepim-3.5.7/./kontact/src/mainwindow.cpp:536
#32 0x0805cbbe in Kontact::MainWindow::selectPlugin (this=0x80cce80,
pluginName=@0x80bb844)
at /build/buildd/kdepim-3.5.7/./kontact/src/mainwindow.cpp:623
#33 0x0805a853 in Kontact::MainWindow::loadSettings (this=0x80cce80)
at /build/buildd/kdepim-3.5.7/./kontact/src/mainwindow.cpp:638
#34 0x0805e652 in Kontact::MainWindow::initObject (this=0x80cce80)
at /build/buildd/kdepim-3.5.7/./kontact/src/mainwindow.cpp:160
#35 0x080593bf in KontactApp::newInstance (this=0xbfda29c8)
at /build/buildd/kdepim-3.5.7/./kontact/src/main.cpp:100
#36 0xb75eb2df in KUniqueApplication: :p rocessDelayed (this=0xbfda29c8)
at /build/buildd/kdelibs-3.5.7.dfsg.1/./kdecore/kuniqueapplication.cpp:444
#37 0xb75f19c8 in KUniqueApplication::qt_invoke (this=0xbfda29c8, _id=19,
_o=0xbfda23f8) at ./kuniqueapplication.moc:86
#38 0xb6f23b10 in QObject::activate_signal (this=0x80b9e98, clist=0x80b9f70,
o=0xbfda23f8) at kernel/qobject.cpp:2356
#39 0xb72b332e in QSignal::signal (this=0x80b9e98, t0=@0x80b9ec0)
#40 0xb6f42cc6 in QSignal::activate (this=0x80b9e98) at kernel/qsignal.cpp:212
#41 0xb6f4aeaa in QSingleShotTimer::event (this=0x80b9e70)
#42 0xb6eb836a in QApplication::internalNotify (this=0xbfda29c8,
receiver=0x80b9e70, e=0xbfda2738) at kernel/qapplication.cpp:2635
#43 0xb6eba193 in QApplication::notify (this=0xbfda29c8, receiver=0x80b9e70,
e=0xbfda2738) at kernel/qapplication.cpp:2358
#44 0xb75f9ff2 in KApplication::notify (this=0xbfda29c8, receiver=0x80b9e70,
event=0xbfda2738)
#45 0xb6e496c9 in QApplication::sendEvent (receiver=0x80b9e70,
event=0xbfda2738) at ../include/qapplication.h:520
#46 0xb6eab1b1 in QEventLoop::activateTimers (this=0x80abc28)
#47 0xb6e5e19a in QEventLoop: :p rocessEvents (this=0x80abc28, flags=4)
#48 0xb6ed36e4 in QEventLoop::enterLoop (this=0x80abc28)
at kernel/qeventloop.cpp:198
#49 0xb6ed33e2 in QEventLoop::exec (this=0x80abc28)
at kernel/qeventloop.cpp:145
#50 0xb6eb9f13 in QApplication::exec (this=0xbfda29c8)
at kernel/qapplication.cpp:2758
#51 0x08059989 in main (argc=142343840, argv=0xbfda2bd4)
at /build/buildd/kdepim-3.5.7/./kontact/src/main.cpp:163
#52 0xb7697050 in __libc_start_main () from /lib/i686/cmov/libc.so.6
#53 0x08059111 in _start ()
Da się coś z tym zrobić?
// Poprawiłem Twój post - dodałem tagi code.
Kaka'
