[+]Sferia, problem z ppp?
cinek810
Post autor: cinek810 »
Mam problem w uruchomieniu Sferii(provider internetu radiowego w Wawie). Jest to połączenie radiowe, do instalcji postępuje zgodnie z opisem na stronie dostawcy.
http://www.sferia.pl/files/11755928531767715249.pdf
Nie wiem czy dobrze odczytuje z logow, ze strownik modemu jest ok, tylko... brakuej sygnalu?
Kiedys dawno temu, jak odpalalo sie ppp z kabla z tpsa wychodzili ten komnikat (NO CARRIER) gdy nie było sygnału w kablu.. teraz nie wiem jak to odczytać. Poniżej logi z podłączenia modemu i ppp:
Sep 29 13:09:34 localhost kernel: generic ttyUSB0: Generic converter now disconnected from ttyUSB0
Sep 29 13:09:34 localhost kernel: usbserial_generic 1-1:1.0: device disconnected
Sep 29 13:09:34 localhost kernel: generic ttyUSB1: Generic converter now disconnected from ttyUSB1
Sep 29 13:09:34 localhost kernel: usbserial_generic 1-1:1.1: device disconnected
Sep 29 13:09:42 localhost kernel: usb 1-1: new full speed USB device using address 5
Sep 29 13:09:43 localhost kernel: usbserial_generic 1-1:1.0: Generic converter detected
Sep 29 13:09:43 localhost kernel: usb 1-1: Generic converter now attached to ttyUSB0
Sep 29 13:09:43 localhost kernel: usbserial_generic 1-1:1.1: Generic converter detected
Sep 29 13:09:43 localhost kernel: usb 1-1: Generic converter now attached to ttyUSB1
Sep 29 13:11:05 localhost pppd[3510]: pppd 2.4.3 started by root, uid 0
Sep 29 13:11:06 localhost chat[3511]: abort on (BUSY)
Sep 29 13:11:06 localhost chat[3511]: abort on (NO CARRIER)
Sep 29 13:11:06 localhost chat[3511]: abort on (VOICE)
Sep 29 13:11:06 localhost chat[3511]: abort on (NO DIALTONE)
Sep 29 13:11:06 localhost chat[3511]: abort on (NO ANSWER)
Sep 29 13:11:06 localhost chat[3511]: abort on (DELAYED)
Sep 29 13:11:06 localhost chat[3511]: send (ATZ^M)
Sep 29 13:11:06 localhost chat[3511]: expect (OK)
Sep 29 13:11:06 localhost chat[3511]: ATZ^M^M
Sep 29 13:11:06 localhost chat[3511]: OK
Sep 29 13:11:06 localhost chat[3511]:  -- got it
Sep 29 13:11:07 localhost chat[3511]: expect (OK)
Sep 29 13:11:07 localhost chat[3511]: ^M
Sep 29 13:11:07 localhost chat[3511]: ATZ^M^M
Sep 29 13:11:07 localhost chat[3511]: OK
Sep 29 13:11:07 localhost chat[3511]:  -- got it
Sep 29 13:11:07 localhost chat[3511]: send (ATDT#777^M)
Sep 29 13:11:07 localhost chat[3511]: expect (CONNECT)
Sep 29 13:11:08 localhost chat[3511]: ATDT#777^M^M
Sep 29 13:11:08 localhost chat[3511]: CONNECT
Sep 29 13:11:08 localhost chat[3511]:  -- got it
Sep 29 13:11:08 localhost chat[3511]: send (\d)
Sep 29 13:11:09 localhost pppd[3510]: Serial connection established.
Sep 29 13:11:09 localhost pppd[3510]: Using interface ppp0
Sep 29 13:11:09 localhost pppd[3510]: Connect: ppp0 <--> /dev/ttyUSB0
Sep 29 13:11:40 localhost pppd[3510]: LCP: timeout sending Config-Requests
Sep 29 13:11:40 localhost pppd[3510]: Connection terminated.
Sep 29 13:11:45 localhost chat[3526]: abort on (BUSY)
Sep 29 13:11:45 localhost chat[3526]: abort on (NO CARRIER)
Sep 29 13:11:45 localhost chat[3526]: abort on (VOICE)
Sep 29 13:11:45 localhost chat[3526]: abort on (NO DIALTONE)
Sep 29 13:11:45 localhost chat[3526]: abort on (NO ANSWER)
Sep 29 13:11:45 localhost chat[3526]: abort on (DELAYED)
Sep 29 13:11:45 localhost chat[3526]: send (ATZ^M)
Sep 29 13:11:45 localhost chat[3526]: expect (OK)
Sep 29 13:11:45 localhost chat[3526]: ATZ^M^M
Sep 29 13:11:45 localhost chat[3526]: OK
Sep 29 13:11:45 localhost chat[3526]:  -- got it
Sep 29 13:11:45 localhost chat[3526]: ^M
Sep 29 13:11:45 localhost chat[3526]: send (ATDT#777^M)
Sep 29 13:11:45 localhost chat[3526]: expect (CONNECT)
Sep 29 13:11:46 localhost chat[3526]: ATDT#777^M^M
Sep 29 13:11:46 localhost chat[3526]: NO CARRIER
Sep 29 13:11:46 localhost chat[3526]:  -- failed
Sep 29 13:11:46 localhost chat[3526]: Failed (NO CARRIER)
Sep 29 13:11:47 localhost pppd[3510]: Modem hangup
Sep 29 13:11:47 localhost pppd[3510]: Exit.
Co o tym myslicie, gdzie szukac problemu?
PS. Połączenie nie zostało jeszcze uruchomione na rzadnym systemie.
[ Dodano: 2007-09-29, 18:00 ]
Problem rozwiązany. W opisie providera jest błąd, trzeba wywalic z pliku konfiguracyjnego
ABORT "NO CARRIRE"
wasilo
Post autor: wasilo »
Ja nie mogę ręcznie załadować sterownika anydata poleceniem
modprobe usbserial vendor=0x16d5 product=0x6501
po wpisaniu tego polecenia wyskakuje mi komunikat, że nie ma takiego polecenia modprobe. Czy to polecenie ma swój inny odpowiednik w Debianie?
fabix
Post autor: fabix »
Nie te polecenie wykonuje się z konta root :mrgreen:
