(exaile.py:7142): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
Traceback (most recent call last):
File "exaile.py", line 68, in ?
from xl import *
File "/usr/share/exaile/xl/tracks.py", line 18, in ?
import common, media, db, config, trackslist
File "/usr/share/exaile/xl/media/__init__.py", line 1, in ?
from xl.media import mp3, ogg, flac, wav
File "/usr/share/exaile/xl/media/mp3.py", line 2, in ?
from xl import xlmisc
File "/usr/share/exaile/xl/xlmisc.py", line 23, in ?
import prefs
File "/usr/share/exaile/xl/prefs.py", line 18, in ?
import tracks, xlmisc, media, audioscrobbler
File "/usr/share/exaile/xl/audioscrobbler.py", line 334, in ?
if enc == 'ascii' and locale.getpreferredencoding():
File "/usr/lib/python2.4/locale.py", line 417, in getpreferredencoding
setlocale(LC_CTYPE, "")
File "/usr/lib/python2.4/locale.py", line 381, in setlocale
return _setlocale(category, locale)
locale.Error: unsupported locale setting
(exaile.py:5057): Gtk-WARNING **: Locale not supported by C library.
from xl import *
import prefs
To podczas instalacji jakiejś innej pacz wyskoczyło takie okienko (jak przy reconfigu xorg) z prośbą o wypełnienie. A ja bezmyślnie wpisałem "user" :-/
Może ktoś mógłby zainstalować Exaile i powiedzieć co to za pakiecik.
(exaile.py:5799): Gtk-WARNING **: Locale not supported by C library.
from xl import *
import prefs
//EDIT
Mam jeszcze większy problem. Xfmedia ma problem z odtwarzaniem. Skonfigurowałem ALSA i zmieniłem w Xfmedia. A Exaile z root odtwarza.
(process:8266): Gdk-WARNING **: locale not supported by C library
(xfmedia:8266): Gtk-WARNING **: Locale not supported by C library.
(xfmedia:8266): GLib-GObject-WARNING **: invalid cast from `GtkLabel' to `ExoEllipsizedLabel'
rancherr@gucek:~$ exaile
GRE_GetGREPathWithProperties failed
File "/usr/lib/exaile/exaile.py", line 94, in <module>
from xl.gui import main as exailemain
File "/usr/lib/exaile/xl/gui/main.py", line 23, in <module>
from xl import library, logger, media, equalizer, burn, common
File "/usr/lib/exaile/xl/library.py", line 20, in <module>
from xl import common, media, db, audioscrobbler, xlmisc, dbusinterface
File "/usr/lib/exaile/xl/media/__init__.py", line 4, in <module>
from xl import common, xlmisc
File "/usr/lib/exaile/xl/xlmisc.py", line 34, in <module>
from xl import mozembed
File "/usr/lib/exaile/xl/mozembed.py", line 29, in <module>
import gtkmozembed
SystemError: dynamic module not initialized properly
rancherr@gucek:~$
