Sep 25 16:50:59 maksior postfix/smtpd[13601]: sql auxprop plugin using mysql engine
Sep 25 16:51:01 maksior postfix/smtpd[13601]: warning: 127.0.0.1: hostname localhost verification failed: Name or service not known
Sep 25 16:51:01 maksior postfix/smtpd[13601]: connect from unknown[127.0.0.1]
Sep 25 16:51:01 maksior postfix/trivial-rewrite[13556]: warning: do not list domain maksior.zadupie.eu in BOTH mydestination and virtual_mailbox_domains
Sep 25 16:51:01 maksior postfix/smtpd[13601]: C364481F1: client=unknown[127.0.0.1]
Sep 25 16:51:02 maksior postfix/cleanup[13554]: C364481F1: message-id=<20070925145045.0B24A81F2@maksior.zadupie.eu>
Sep 25 16:51:02 maksior postfix/qmgr[3453]: C364481F1: from=<root@maksior.zadupie.eu>, size=3388, nrcpt=1 (queue active)
Sep 25 16:51:02 maksior postfix/trivial-rewrite[13556]: warning: do not list domain maksior.zadupie.eu in BOTH mydestination and virtual_mailbox_domains
Sep 25 16:51:02 maksior last message repeated 25 times
Sep 25 16:51:02 maksior postfix/local[13612]: warning: alias database loop for postmaster
Sep 25 16:51:02 maksior postfix/local[13612]: C364481F1: to=<postmaster@maksior.zadupie.eu>, orig_to=<root@maksior.zadupie.eu>, relay=local, delay=1.1, delays=0.36/0.14/0/0.62, dsn=5.4.6, status=bounced (alias database loop for postmaster)
Sep 25 16:51:02 maksior postfix/cleanup[13554]: E0B5081F4: message-id=<20070925145102.E0B5081F4@maksior.zadupie.eu>
Sep 25 16:51:02 maksior postfix/qmgr[3453]: E0B5081F4: from=<>, size=5308, nrcpt=1 (queue active)
Sep 25 16:51:03 maksior last message repeated 9 times
Sep 25 16:51:03 maksior postfix/bounce[13616]: C364481F1: sender non-delivery notification: E0B5081F4
Sep 25 16:51:03 maksior postfix/qmgr[3453]: C364481F1: removed
Sep 25 16:51:03 maksior postfix/trivial-rewrite[13556]: warning: do not list domain maksior.zadupie.eu in BOTH mydestination and virtual_mailbox_domains
Sep 25 16:51:03 maksior last message repeated 14 times
Sep 25 16:51:03 maksior postfix/local[13612]: warning: alias database loop for postmaster
Sep 25 16:51:03 maksior postfix/local[13612]: E0B5081F4: to=<postmaster@maksior.zadupie.eu>, orig_to=<root@maksior.zadupie.eu>, relay=local, delay=0.5, delays=0.08/0.06/0/0.37, dsn=5.4.6, status=bounced (alias database loop for postmaster)
Sep 25 16:51:03 maksior postfix/qmgr[3453]: E0B5081F4: removed
Sep 25 16:51:03 maksior postfix/smtpd[13601]: disconnect from unknown[127.0.0.1]
Sep 25 16:51:03 maksior amavis[3449]: (03449-02) Passed CLEAN, <root@maksior.zadupie.eu> -> <root@maksior.zadupie.eu>, Message-ID: <20070925145045.0B24A81F2@maksior.zadupie.eu>, mail_id: 4m-y-B0JzCs2, Hits: 0.851, queued_as: C364481F1, 16809 ms
Sep 25 16:51:03 maksior postfix/smtp[13563]: 0B24A81F2: to=<root@maksior.zadupie.eu>, orig_to=<root>, relay=127.0.0.1[127.0.0.1]:10024, delay=53, delays=36/0.07/0.01/17, dsn=2.6.0, status=sent (250 2.6.0 Ok, id=03449-02, from MTA([127.0.0.1]:10025): 250 2.0.0 Ok: queued as C364481F1)
Sep 25 16:51:03 maksior postfix/qmgr[3453]: 0B24A81F2: removed
[ Dodano: 2007-09-29, 20:59 ]
Za dużo to nie zdrowo skupmy sie na tym kawałku
Sep 29 20:59:29 maksior postfix/cleanup[27990]: 98EE8970C: message-id=<20070929185929.98EE8970C@maksior.zadupie.eu>
Sep 29 20:59:29 maksior postfix/qmgr[3646]: 98EE8970C: from=<>, size=4870, nrcpt=1 (queue active)
Sep 29 20:59:29 maksior postfix/bounce[28079]: 4CBBA474E: sender non-delivery notification: 98EE8970C
Sep 29 20:59:29 maksior postfix/qmgr[3646]: 4CBBA474E: removed
Sep 29 20:59:29 maksior postfix/virtual[28078]: 98EE8970C: to=<root@maksior.zadupie.eu>, relay=virtual, delay=0.1, delays=0.04/0/0/0.06, dsn=5.1.1, status=bounced (unknown user: "root@maksior.zadupie.eu")
Co jest nie tak ?
