Instalowalem compiz fusion wedlug tego faq
Uruchamiam go poprzez
fusion-iconCzy ktos wie jak rozwiazac moj problem ?Mam 1024 ramu i karte graficzna intela.
fusion-iconKod: Zaznacz cały
# package.
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "dbe"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller"
Driver "intel"
BusID "PCI:0:2:0"
Option "MonitorLayout" "CRT"
Option "CloneRefresh" "75"
Option "DevicePresence" "yes"
Option "Clone" "true"
Option "XAANoOffscreenPixmaps" "true"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Synaptics Touchpad"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSectionKod: Zaznacz cały
/usr/bin/compiz: line 777: 6481 Segmentation fault (core dumped) $*
X Error: BadDevice, invalid or uninitialized input device 169
Major opcode: 145
Minor opcode: 3
Resource id: 0x0
Failed to open device
Major opcode: 145
Minor opcode: 3
Resource id: 0x0
spider@debian:~$ fusion-icon
* Detected Session: gnome
* Searching for installed applications...
* NVIDIA on Xorg detected, exporting: __GL_YIELD=NOTHING
* Using the GTK Interface
* Starting Compiz
... executing: compiz.real --replace --sm-disable --ignore-desktop-hints ccp --indirect-rendering
compiz.real (core) - Fatal: No composite extensionJakieś pomysły? :-/# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Sep 12 14:29:35 PDT 2007
# xorg.conf (xorg X Window System server configuration file)
# package.
Screen "Default Screen" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
Load "dbe"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "nVidia Corporation G70 [GeForce 7600 GT]"
Driver "nvidia"
EndSection
Section "Screen"
Device "nVidia Corporation G70 [GeForce 7600 GT]"
DefaultDepth 24
Depth 24
Modes "1280x1024" "800x600" "640x480"
EndSubSection
EndSection
EndSection
