Po zainstalowaniu urządznie mfc250c w debianie 13 ni edziała skaner
pawelk29
Post autor: pawelk29 »
zainstalowałem wszystko skryptem ze strony producenta jednakże
sudo scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
sudo sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
found possible USB scanner (vendor=0x04f9 [Brother], product=0x01fe [MFC-250C]) at libusb:001:004
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
pk28@mypc:~$
próbowałem przeinstalować stery ale nic z tego
