Ostatnio wgralem sobie Debiana(bo chcialem sie przekonac czego jest wart) no i klapa nie umiem uruchomic x'ow. Pisze startx i wyskakuja mi bledy. Ponadto nie umie skonfigurowac XF86,myszki karty i tym podobne. Aha chcialbym miec xorga ale nie wiem jak go zainstalowac( probowalem: apt-get install -t testing xserver-xorg) ale nie znalazlo takiego pakietu
(II) RADEON(0): Acceleration enabled
(==) RADEON(0): Backing store disabled
(==) RADEON(0): Silken mouse enabled
(II) RADEON(0): Using hardware cursor (scanline 770)
(II) RADEON(0): Largest offscreen area available: 1024 x 7405
(II) RADEON(0): Direct rendering disabled
(==) RandR enabled
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XFree86-Bigfont
(**) Option "Protocol" "auto"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/mouse"
(EE) xf86OpenSerial: Cannot open device /dev/mouse
No such file or directory.
(WW) Mouse0: cannot open input device
(**) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(==) Mouse0: Buttons: 3
(II) Keyboard "Keyboard0" handled by legacy driver
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Open APM successful
(EE) RADEON(0): [dri] RADEONInitVisualConfigs failed (depth 8 not supported). Disabling DRI.
(II) RADEON(0): Memory manager initialized to (0,0) (1024,8191)
(II) RADEON(0): Reserved area from (0,768) to (1024,770)
(II) RADEON(0): Largest offscreen area available: 1024 x 7421
(==) RandR enabled
