OMV i kondycja dysku systemowego
pelermo
Post autor: pelermo »
Witam po zalogowaniu się do panelu omv zobaczyłem S.M.A.R.T że jest podświetlony na żółto dysk systemowy. Nie znam się na tyle aby zdiagnozować czy dysk już jest na wykończeniu czy tylko pojawiło się kilka bad sektorów i SMART zgłasza mi że coś jest nie tak. Poniżej zamieszczam zrzut ekranu jak to wygląda:
zakładka Attributes:
Self-Test Logs:
Extended Information:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.16.0-0.bpo.4-amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Momentus 7200.2
Device Model: ST9120823AS
Serial Number: 5NJ0DSNG
Firmware Version: 3.ADC
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Tue Jan 23 20:29:55 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Disabled
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Another SCT command is executing, abort Feature Control
(SCT ext_status_code 0xffff, action_code=4, function_code=2)
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 426) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 111) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 100 253 006 - 0
3 Spin_Up_Time PO---- 099 098 085 - 0
4 Start_Stop_Count -O--CK 098 098 020 - 2850
5 Reallocated_Sector_Ct PO--CK 100 100 036 - 25
7 Seek_Error_Rate POSR-- 078 060 030 - 47921236934
9 Power_On_Hours -O--CK 072 072 000 - 24690
10 Spin_Retry_Count PO--C- 100 100 034 - 0
12 Power_Cycle_Count -O--CK 098 098 020 - 2702
187 Reported_Uncorrect -O--CK 100 100 000 - 0
189 High_Fly_Writes -O-RCK 001 001 000 - 128
190 Airflow_Temperature_Cel -O---K 061 035 045 Past 39 (Min/Max 34/41)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 1783
193 Load_Cycle_Count -O---K 092 092 000 - 17336
194 Temperature_Celsius -O-RC- 039 065 000 - 39 (0 12 0 0 0)
195 Hardware_ECC_Recovered -O--C- 060 053 000 - 152181678
197 Current_Pending_Sector ----C- 097 097 000 - 80
198 Offline_Uncorrectable -OSRCK 097 097 000 - 80
199 UDMA_CRC_Error_Count ------ 200 200 000 - 0
200 Multi_Zone_Error_Rate -O--CK 100 253 000 - 0
202 Data_Address_Mark_Errs ------ 100 253 000 - 0
254 Free_Fall_Sensor ------ 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory not supported
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 SL R/O 5 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 SL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 SL R/O 1 NCQ Command Error log
0x11 SL R/O 1 SATA Phy Event Counters log
0x20 SL R/O 1 Streaming performance log [OBS-8]
0x21 SL R/O 1 Write stream error log
0x22 SL R/O 1 Read stream error log
0x23 SL R/O 1 Delayed sector log [OBS-8]
0x80-0x9f SL R/W 16 Host vendor specific log
0xa0 SL VS 1 Device vendor specific log
0xa1 SL VS 20 Device vendor specific log
0xa2 SL VS 101 Device vendor specific log
0xa8 SL VS 20 Device vendor specific log
0xa9 SL VS 1 Device vendor specific log
0xe0 SL R/W 1 SCT Command/Status
0xe1 SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log (GP Log 0x03) not supported
SMART Error Log Version: 1
No Errors Logged
SMART Extended Self-test Log (GP Log 0x07) not supported
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 10101 -
# 2 Short offline Completed without error 00% 9450 -
# 3 Short offline Completed without error 00% 1460 -
# 4 Short offline Completed without error 00% 1 -
# 5 Short offline Interrupted (host reset) 80% 1 -
# 6 Short offline Completed without error 00% 0 -
# 7 Short offline Interrupted (host reset) 30% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 521 (0x0209)
Device State: Active (0)
Current Temperature: 39 Celsius
Power Cycle Min/Max Temperature: 34/43 Celsius
Lifetime Min/Max Temperature: 15/66 Celsius
Specified Max Operating Temperature: 40 Celsius
Under/Over Temperature Limit Count: 0/0
Another SCT command is executing, abort Read Data Table
Read SCT Temperature History failed
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 4 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0009 2 4 Transition from drive PhyRdy to drive PhyNRdy
0x8002 2 0 Vendor specific
0x8003 2 3 Vendor specific
0x8004 2 0 Vendor specific
Za pomoc bardzo dziękuję
Re: OMV i kondycja dysku systemowego
Jeśli są robione regularne kopie zapasowe to monitorowałbym tylko czy nie rośnie wartość parametru 05 Reallocated_Sector_Ct.
Inne parametry, które warto monitorować:
https://www.elektroda.pl/rtvforum/viewt ... 9315c4f3bb
