Laptop i dwa dodatkowe monitory (nie widzi jednego z nich)
Fraktal
Post autor: Fraktal »
Hej,
Mam Debiana 11 na Dell E7450 + podłączyłem pod niego 2 monitory (1 x HDMI, 2 x przejściówka display port - HDMI). Ten, który jest podpiętym pod HDMI nie wyświetla obrazu.
Dodam, że poprzez stację dokującą: inne monitory, ale ta sama firma i model działają, ale są podpięte pod VGA i DVI. Obydwa monitory są sprawne i kable również, bo sprawdziłem w różnych opcjach.
xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 309mm x 173mm
   1920x1080     60.05*+  60.01    59.97    59.96    59.93    48.04
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1280x800      59.99    59.97    59.81    59.91
   1152x864      60.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     60.00*+  50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1400x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09)
Fraktal
Re: Laptop i dwa dodatkowe monitory (nie widzi jednego z nich)
Jakieś pomysły?
https://www.dell.com/support/kbdoc/pl-p ... 0-graphics
Karty graficzne HD 4600/HD 5500 obsługują 1 wyświetlacz analogowy (LCD lub VGA) oraz 2 wyświetlacze cyfrowe (DVI lub DisplayPort) w konfiguracji trzech wyświetlaczy.
Fraktal
dedito pisze: 02 marca 2023, 09:01 https://www.dell.com/support/kbdoc/pl-p ... 0-graphics
Bardzo dziękuję za pomoc.
Zamykam.
