Pi pico właściciel root
Tematy związane z RPI
Michal8883
Post autor: Michal8883 »
System debian 11 dlaczego włascicielem pi pico jest root? Jak to naprawić?
root@michal:/home/michal# mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=3956912k,nr_inodes=989228,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=796672k,mode=755)
/dev/sda2 on / type ext4 (rw,relatime,errors=remount-ro)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10489)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
/dev/sda1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=796668k,nr_inodes=199167,mode=700,uid=1000,gid=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sdc1 on /media/michal/RPI-RP2 type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
  GNU nano 5.4                       /etc/fstab
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# systemd generates mount units based on this file, see systemd.mount(5).
# Please run 'systemctl daemon-reload' after making changes here.
# / was on /dev/sda2 during installation
UUID=812e6158-7968-421b-b2ab-806aff24ce53 /               ext4    errors=remoun>
# /boot/efi was on /dev/sda1 during installation
UUID=BBC4-AC92  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda3 during installation
UUID=d4c51bd7-4f13-45e4-b3db-d8aa9a7f4067 none            swap    sw           >
Michal8883
Re: Pi pico właściciel root
Screeny
A tak bardziej konkretnie, o co chodzi?
Szukam w tych przedstawionych wyżej logach wspomnianego pi pico i roota i nie znajduję nic sensownego.
Michal8883
Ostatnio zmieniony 20 grudnia 2022, 13:28 przez Michal8883, łącznie zmieniany 2 razy.
Czy ty chcesz spytać o to czemu nie masz uprawnień do odczytu pliku flash_nuke.uf2 w katalogu /media/michal/RPI-RP2?
Michal8883
Tak. Nie mogę wgrać nic na pi pico
Spróbuj zmienić właściciela z poziomu konta root
chown michal:michal /media/michal/RPI-RP2
lub zamontuj "pi pico" (zakładam, że pod tą nazwą kryje się nośnik USB) z poziomu własnego konta w swoim katalogu domowym (michal).
Michal8883
Wyświetlanymi się pico na pulpicie i dale prawy i zamontuj, ale jak widzisz nic nie działa zaraz sprawdzę twoje rozwiązanie.
Michal8883
Dalej brak dostępu.
root@michal:/home/michal# mount /media/michal/RPI-RP2/ /home/michal
mount: /home/michal: urządzenie specjalne /media/michal/RPI-RP2/ nie istnieje.
mount: /home/michal:  /media/michal/RPI-RP2 nie jest urządzeniem blokowym.
root@michal:/home/michal# chown michal:michal /media/michal/RPI-RP2
Próbujesz montować, ale źle to robisz.
Poczytaj man mount.
Podstawa to mount nazwa_urządzenia sciezka_montowania
W Internecie są setki przykładów jak poprawnie montować.
Zmiana właściciela się chyba udała, ale rób to po zamontowaniu lub jak już wcześniej pisałem montuj do swojego katalogu domowego.
