Aktualizacja debiana/proxmox pakiety są zbyt aktualne
Kiui
Post autor: Kiui »
Cześć,
Przejąłem serwer z PVE4 oraz z debianem 8.
Standardowo rozpocząłem aktualizację zgodnie z zaleceniami producenta PVE z Wikipedii z 4 do 5 itd.
Nie wiem ale coś poszło nie tak.
aktualnie konsola wyrzuca mi:
 libpam-systemd : Depends: systemd (= 215-17+deb8u13) but 247.3-6 is installed
 openssh-sftp-server : Depends: openssh-client (= 1:6.7p1-5+deb8u8) but 1:8.4p1-5 is installed
 systemd-sysv : Depends: systemd (= 215-17+deb8u13) but 247.3-6 is installed
Pakiety o których mowa w kodzie są niedostępne.
Co zrobić takiej sytuacji.
Polecnia:
 dpkg --configure -a
Setting up initscripts (2.96-7) ...
/var/lib/dpkg/info/initscripts.postinst: 56: /var/lib/dpkg/info/initscripts.postinst: update-rc.d: not found
dpkg: error processing package initscripts (--configure):
 installed initscripts package post-installation script subprocess returned error exit status 127
Setting up util-linux (2.36.1-8+deb11u1) ...
/var/lib/dpkg/info/util-linux.postinst: 17: /var/lib/dpkg/info/util-linux.postinst: update-rc.d: not found
dpkg: error processing package util-linux (--configure):
 installed util-linux package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of mount:
 mount depends on util-linux (>= 2.29.2-3~); however:
  Package util-linux is not configured yet.
dpkg: error processing package mount (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of systemd:
 systemd depends on util-linux (>= 2.27.1); however:
 systemd depends on mount (>= 2.26); however:
  Package mount is not configured yet.
dpkg: error processing package systemd (--configure):
dpkg: dependency problems prevent configuration of systemd-timesyncd:
 systemd-timesyncd depends on systemd (= 247.3-6); however:
  Package systemd is not configured yet.
dpkg: error processing package systemd-timesyncd (--configure):
dpkg: dependency problems prevent configuration of udev:
 udev depends on util-linux (>= 2.27.1); however:
dpkg: error processing package udev (--configure):
dpkg: dependency problems prevent processing triggers for initramfs-tools:
 initramfs-tools depends on udev; however:
  Package udev is not configured yet.
dpkg: error processing package initramfs-tools (--configure):
 dependency problems - leaving triggers unprocessed
Errors were encountered while processing:
 initscripts
 util-linux
 mount
 systemd
 systemd-timesyncd
 udev
 initramfs-tools
Z góry dziękuje za pomoc.
Re: Aktualizacja debiana/proxmox pakiety są zbyt aktualne
Pokaż wynik
apt policy
