Debian 10 z LAMP na HP DL380G7
Atalisha
Post autor: Atalisha »
Witajcie,
nie wiem czy dobre miejsce, ale mam problem z apache2:
Po restarcie w logu mam (tak sypie tym komunikatem cały czas):
Gorzej, że jak patrzyłem to nie mam w mods-avaiable mod_watchdog :/
Instalacja samego watchdog do systemu to inna kwestia choć tam ustawiłem tylko, żeby ping mi sprawdzał.
Jakiś pomysł ?
[Fri Aug 28 13:01:50.366995 2020] [core:info] [pid 833] AH00096: removed PID file /var/run/apache2/apache2.pid (pid=833)
[Fri Aug 28 13:01:50.367035 2020] [mpm_prefork:notice] [pid 833] AH00169: caught SIGTERM, shutting down
[Fri Aug 28 13:01:50.517541 2020] [watchdog:debug] [pid 1252] mod_watchdog.c(454): AH010033: Watchdog: Running with WatchdogInterval 1000ms
[Fri Aug 28 13:01:50.517585 2020] [watchdog:debug] [pid 1252] mod_watchdog.c(462): AH02974: Watchdog: found parent providers.
[Fri Aug 28 13:01:50.517595 2020] [watchdog:debug] [pid 1252] mod_watchdog.c(508): AH02977: Watchdog: found child providers.
[Fri Aug 28 13:01:50.517602 2020] [watchdog:debug] [pid 1252] mod_watchdog.c(516): AH02978: Watchdog: Looking for child (_default_).
[Fri Aug 28 13:01:50.517609 2020] [watchdog:debug] [pid 1252] mod_watchdog.c(516): AH02978: Watchdog: Looking for child (_singleton_).
[Fri Aug 28 13:01:50.521047 2020] [watchdog:debug] [pid 1270] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:50.522018 2020] [watchdog:debug] [pid 1271] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:50.522915 2020] [watchdog:debug] [pid 1272] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:50.523253 2020] [mpm_prefork:notice] [pid 1252] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Fri Aug 28 13:01:50.523275 2020] [mpm_prefork:info] [pid 1252] AH00164: Server built: 2019-10-15T19:53:42
[Fri Aug 28 13:01:50.523292 2020] [core:notice] [pid 1252] AH00094: Command line: '/usr/sbin/apache2'
[Fri Aug 28 13:01:50.523300 2020] [core:debug] [pid 1252] log.c(1571): AH02639: Using SO_REUSEPORT: yes (1)
[Fri Aug 28 13:01:50.523315 2020] [mpm_prefork:debug] [pid 1252] prefork.c(919): AH00165: Accept mutex: none (default: sysvsem)
[Fri Aug 28 13:01:50.524067 2020] [watchdog:debug] [pid 1273] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:50.525101 2020] [watchdog:debug] [pid 1274] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:51.527392 2020] [watchdog:debug] [pid 1275] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:52.529645 2020] [watchdog:debug] [pid 1277] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Fri Aug 28 13:01:52.530872 2020] [watchdog:debug] [pid 1278] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
Re: Debian 10 z LAMP na HP DL380G7
pokaż co wyświetla polecenie
apachectl -M
W jaki sposób zainstalowałeś ten moduł?
W jaki sposób załadowałeś ten moduł do apache?
Atalisha
sudo apache2ctl -M
Loaded Modules:
core_module (static)
so_module (static)
watchdog_module (static)
http_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
unixd_module (static)
access_compat_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
filter_module (shared)
mime_module (shared)
mpm_prefork_module (shared)
negotiation_module (shared)
php7_module (shared)
reqtimeout_module (shared)
rewrite_module (shared)
setenvif_module (shared)
status_module (shared)
Zapewne sam apache próbuje go uruchomić tylko, że go nie ma... ? W Mods_available też go nie ma jak pisałem. Pytanie jak go dodać ? Względnie jak usunąć / skonfigurować...
No właśnie go nie dodawałem ... bo nawet nie miałbym jak zlinkować mods-enabled do mods-available...
Co więcej jak dam sudo a2dismod watchdog_module dostaję informację, że nie istnieje... to samo przy mod_watchodog
Idąc dalej jak w configu dopiszę: WatchdogInterval 10
przed załadowaniem modułów też nic...
log dalej sypie:
[watchdog:debug] [pid 842] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
Chyba kluczową kwestią będzie czego on oczekuje - gdzie i co mam dla niego skonfigurować ?
Atalisha
No to widzę :) tylko czego oczekuje ?
Pakietu watchdog w systemie z ustawieniami ? Jeśli tak to którymi ? wszystkimi ?
(jak doinstalowałem watchdog i włączyłem choćby ping to i tak to nic nie zmienia w logach)
Atalisha
Ktoś coś w tym temacie ?
sam watchdog.conf mam ustawiony (pakiet watchdog),
nie wiem natomiast czego oczekuje mod_watchdog.
