[+]Paczki makemkv-oss makemkv-bin - uninstallable
etrollo
Post autor: etrollo »
To jest instalacja MakeMKV w wersji beta.
Korzystam z tego manuala, z punktu 2:
sudo apt-get install makemkv-oss makemkv-bin
For those who don’t want to add PPA, grab the .deb packages for both makemkv-bin and makemkv-oss from THIS PAGE.
paczki Debiana sa na tej stronie:
https://launchpad.net/~heyarje/+archive ... /+packages
a ja mam do zainstalowania dwie takie dla Debiana:
makemkv-bin_1.14.4-1~xenial_amd64.deb (5.0 MiB)
makemkv-oss_1.14.4-1~xenial_amd64.deb (1.0 MiB)
nie instaluja i jakies bledy zaleznosci
calosc moich staran tu:
neutron@neutron:~$ su -
Password:
root@neutron:~# sudo apt update
Hit:1 http://www.deb-multimedia.org stretch InRelease
Ign:2 http://deb.debian.org/debian stretch InRelease
Get:3 http://security.debian.org/debian-security stretch/updates InRelease [94.3 kB]
Hit:4 http://deb.opera.com/opera-stable stable InRelease
Get:5 http://deb.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:6 http://deb.debian.org/debian stretch Release
Fetched 185 kB in 2s (81.6 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
root@neutron:~# sudo apt-get install makemkv-oss makemkv-bin
E: Unable to locate package makemkv-oss
E: Unable to locate package makemkv-bin
root@neutron:~# sudo apt install /path/to/package/makemkv-oss_1.14.4-1~xenial_amd64.deb
E: Unsupported file /path/to/package/makemkv-oss_1.14.4-1~xenial_amd64.deb given on commandline
root@neutron:~# sudo apt install ./makemkv-oss_1.14.4-1~xenial_amd64.deb
E: Unsupported file ./makemkv-oss_1.14.4-1~xenial_amd64.deb given on commandline
root@neutron:~# cd /home
root@neutron:/home# cd neutron
root@neutron:/home/neutron# cd Downloads
root@neutron:/home/neutron/Downloads# install makemkv-oss_1.14.4-1~xenial_amd64.deb
install: missing destination file operand after 'makemkv-oss_1.14.4-1~xenial_amd64.deb'
Try 'install --help' for more information.
root@neutron:/home/neutron/Downloads# makemkv-oss_1.14.4-1~xenial_amd64.deb
-su: makemkv-oss_1.14.4-1~xenial_amd64.deb: command not found
root@neutron:/home/neutron/Downloads# dpkg -i makemkv-oss_1.14.4-1~xenial_amd64.deb
Selecting previously unselected package makemkv-oss.
(Reading database ... 308100 files and directories currently installed.)
Preparing to unpack makemkv-oss_1.14.4-1~xenial_amd64.deb ...
Unpacking makemkv-oss (1.14.4-1~xenial) ...
dpkg: dependency problems prevent configuration of makemkv-oss:
 makemkv-oss depends on libavcodec-ffmpeg56 (>= 7:2.4) | libavcodec-ffmpeg-extra56 (>= 7:2.4); however:
  Package libavcodec-ffmpeg56 is not installed.
  Package libavcodec-ffmpeg-extra56 is not installed.
 makemkv-oss depends on libavutil-ffmpeg54 (>= 7:2.4); however:
  Package libavutil-ffmpeg54 is not installed.
 makemkv-oss depends on libssl1.0.0 (>= 1.0.0); however:
  Package libssl1.0.0 is not installed.
dpkg: error processing package makemkv-oss (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
Processing triggers for gnome-menus (3.13.3-9) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for mime-support (3.60) ...
Errors were encountered while processing:
 makemkv-oss
root@neutron:/home/neutron/Downloads# sudo apt install -f
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  icedtea-netx icedtea-netx-common
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  makemkv-oss
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 26.1 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 308112 files and directories currently installed.)
Removing makemkv-oss (1.14.4-1~xenial) ...
root@neutron:/home/neutron/Downloads# exit
logout
Password:
root@neutron:~# dpkg -i makemkv-oss_1.14.4-1~xenial_amd64.deb
dpkg: error: cannot access archive 'makemkv-oss_1.14.4-1~xenial_amd64.deb': No such file or directory
 makemkv-oss
  makemkv-oss
root@neutron:/home/neutron/Downloads# xitec
-su: xitec: command not found
root@neutron:/home/neutron/Downloads# sudo gdebi makemkv-oss_1.14.4-1~xenial_amd64.deb
This package is uninstallable
Dependency is not satisfiable: libavcodec-ffmpeg56 (>= 7:2.4)|libavcodec-ffmpeg-extra56 (>= 7:2.4)
root@neutron:/home/neutron/Downloads# sudo apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@neutron:/home/neutron/Downloads# gdebi
Usage: gdebi [options] filename
For a graphical version run gdebi-gtk
Options:
  --version             show program's version number and exit
  -h, --help            show this help message and exit
  -n, --non-interactive
                        Run non-interactive (dangerous!)
  -o APT_OPTS, --option=APT_OPTS
                        Set an APT configuration option
  -q, --quiet           Do not show progress information
  --apt-line            Simulate only and print a apt-get install compatible
                        line to stderr
  --root=ROOTDIR        Use alternative root dir
logout
Password:
root@neutron:~# sudo gdebi makemkv-oss_1.14.4-1~xenial_amd64.deb
gdebi error, file not found: makemkv-oss_1.14.4-1~xenial_amd64.deb
(Reading database ... 308283 files and directories currently installed.)
 makemkv-oss
  makemkv-oss
(Reading database ... 308295 files and directories currently installed.)
root@neutron:/home/neutron/Downloads# This package is uninstallable
-su: This: command not found
root@neutron:/home/neutron/Downloads# Dependency is not satisfiable: libavcodec-ffmpeg56 (>= 7:2.4)|libavcodec-ffmpeg-extra56 (>= 7:2.4)
-su: syntax error near unexpected token `('
Ostatnio zmieniony 18 sierpnia 2019, 14:04 przez etrollo, łącznie zmieniany 1 raz.
Re: Paczki makemkv-oss makemkv-bin - uninstallable
Po co znowu te kombinacje alpejskie, które zapewne skończą się ponowną reinstalacją systemu?
etrollo
Zalezy co przez to rozumiesz? Ten program nie jest open source i nie ma go w repozytoriach. Ale pod linuxiem działa!
Czy nalezysz do tych osob co uwazaja aby nie instalowac zewnetrznych softow?
Pytam po co na siłę instalujesz coś z zewnątrz, gdy w repozytoriach masz inne narzędzia robiące to samo.
etrollo
Udało sie z paczek tar.gz
pobrane
- makemkv-bin_1.14.4.orig.tar.gz
- makemkv-oss_1.14.4.orig.tar.gz
dalej rozpakowac obie paczki:
tar xzvf file.tar.gz
i po rozpakowaniu zainstalowac kazda paczke przez:
./configure
make
sudo make instal
l
Działa!
Re: [+]Paczki makemkv-oss makemkv-bin - uninstallable
No i tak się robi bałagan w systemie, ale Twój wybór, Twój system.
Zamykam.
