Błędy po dist-upgrade
mes mariusz
Post autor: mes mariusz »
Przeedydtowałem /etc/apt/sources.list z jessie do stretch.
Zrobiłem:
apt update
apt dist-upgrade
I mam taką sytuację:
root@NAS-T5740:/home/mariusz# apt update
Ign:1 http://ftp.pl.debian.org/debian stretch InRelease
Stary:2 http://ftp.pl.debian.org/debian stretch-updates InRelease
Stary:3 http://security.debian.org stretch/updates InRelease
Stary:4 http://ftp.pl.debian.org/debian stretch-backports InRelease
Błąd:2 http://ftp.pl.debian.org/debian stretch-updates InRelease
  Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-updates_InRelease into data and signature failed
Błąd:3 http://security.debian.org stretch/updates InRelease
  Splitting up /var/lib/apt/lists/security.debian.org_dists_stretch_updates_InRelease into data and signature failed
Błąd:4 http://ftp.pl.debian.org/debian stretch-backports InRelease
  Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-backports_InRelease into data and signature failed
Stary:5 http://ftp.pl.debian.org/debian stretch Release
Błąd:6 http://ftp.pl.debian.org/debian stretch Release.gpg
  Napotkano przynajmniej jeden nieprawidłowy podpis.
Budowanie drzewa zależności
188 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.pl.debian.org/debian stretch-updates InRelease: Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-updates_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://security.debian.org stretch/updates InRelease: Splitting up /var/lib/apt/lists/security.debian.org_dists_stretch_updates_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.pl.debian.org/debian stretch-backports InRelease: Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-backports_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.pl.debian.org/debian stretch Release: Napotkano przynajmniej jeden nieprawidłowy podpis.
W: Nie udało się pobrać http://security.debian.org/dists/stretch/updates/InRelease  Splitting up /var/lib/apt/lists/security.debian.org_dists_stretch_updates_InRelease into data and signature failed
W: Nie udało się pobrać http://ftp.pl.debian.org/debian/dists/stretch-updates/InRelease  Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-updates_InRelease into data and signature failed
W: Nie udało się pobrać http://ftp.pl.debian.org/debian/dists/stretch-backports/InRelease  Splitting up /var/lib/apt/lists/ftp.pl.debian.org_debian_dists_stretch-backports_InRelease into data and signature failed
W: Nie udało się pobrać http://ftp.pl.debian.org/debian/dists/stretch/Release.gpg  Napotkano przynajmniej jeden nieprawidłowy podpis.
W: Nie udało się pobrać niektórych plików indeksu, zostały one zignorowane lub użyto ich starszej wersji.
root@NAS-T5740:/home/mariusz# clear
Co powinienem zrobić?
Re: Błędy po dist-upgrade
