[+]Problem z uruchomieniem po instalacji
Mów mi Andżej
Post autor: Mów mi Andżej »
Cześć,
zainstalowałem na swojej stacji LinuxCNC (Debian 2.7 Wheezy) i po starcie wyświetla mi się takie coś.
Ktoś mógłby mi powiedzieć czym jest to spowodowane i co zrobić by system wystartował normalnie?
Z góry dzięki
Re: Problem z uruchomieniem po instalacji
Mów mi Andżej
                  Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos1)/boot/grub on this drive.
 => Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Debian GNU/Linux 7
    Boot files:        /boot/grub/grub.cfg /etc/fstab /boot/grub/core.img
sda2: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sdb1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  SYSLINUX 4.07 2013-07-25
    Boot sector info:  Syslinux looks at sector 32776 of /dev/sdb1 for its
                       second stage. The integrity of Syslinux couldn't be
                       verified (install gawk). SYSLINUX is installed in the
                       directory. The 2 ADV sectors are not the same
                       (corrupt). No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /syslinux.cfg /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1    *          2,048   226,097,151   226,095,104  83 Linux
/dev/sda2         226,099,198   234,440,703     8,341,506   5 Extended
/dev/sda5         226,099,200   234,440,703     8,341,504  82 Linux swap / Solaris
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 7811 MB, 7811891200 bytes
255 heads, 63 sectors/track, 949 cylinders, total 15257600 sectors
/dev/sdb1    *          2,048    15,257,599    15,255,552   c W95 FAT32 (LBA)
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/sda1        29c145cd-1e3b-4d16-897d-77cf28f66b7f   ext4
/dev/sda5        597ddfc4-c9ef-4d65-b3a7-e90fe4027925   swap
/dev/sdb1        B690-B5A4                              vfat       DEBIAN WHEE
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/loop0       /lib/live/mount/rootfs/filesystem.squashfs squashfs   (ro,noatime)
/dev/sda1        /media/29c145cd-1e3b-4d16-897d-77cf28f66b7f ext4       (rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks)
/dev/sdb1        /lib/live/mount/medium   vfat       (ro,noatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=utf8,shortname=mixed,errors=remount-ro)
=========================== sda1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  insmod vbe
  insmod vga
  insmod video_bochs
  insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set=root 29c145cd-1e3b-4d16-897d-77cf28f66b7f
if loadfont /usr/share/grub/unicode.pf2 ; then
  set gfxmode=640x480
  load_video
  insmod gfxterm
  insmod part_msdos
  insmod ext2
  set locale_dir=($root)/boot/grub/locale
  set lang=pl_PL
  insmod gettext
fi
terminal_output gfxterm
set timeout=5
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
insmod part_msdos
insmod ext2
insmod png
if background_image /usr/share/images/desktop-base/joy-grub.png; then
  set color_normal=white/black
  set color_highlight=black/white
else
  set menu_color_normal=cyan/blue
  set menu_color_highlight=white/blue
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Debian GNU/Linux, za pomocą systemu Linux 3.4-9-rtai-686-pae' --class debian --class gnu-linux --class gnu --class os {
	load_video
	insmod gzio
	insmod part_msdos
	insmod ext2
	echo	'Wczytywanie systemu Linux 3.4-9-rtai-686-pae...'
	linux	/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=29c145cd-1e3b-4d16-897d-77cf28f66b7f ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
	echo	'Wczytywanie początkowego dysku RAM...'
	initrd	/boot/initrd.img-3.4-9-rtai-686-pae
menuentry 'Debian GNU/Linux, za pomocą systemu Linux 3.4-9-rtai-686-pae (tryb ratunkowy)' --class debian --class gnu-linux --class gnu --class os {
	load_video
	insmod gzio
	insmod part_msdos
	insmod ext2
	linux	/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=29c145cd-1e3b-4d16-897d-77cf28f66b7f ro single initrd=/install/gtk/initrd.gz
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
	insmod part_msdos
	insmod ext2
	linux16	/boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
	insmod part_msdos
	insmod ext2
	linux16	/boot/memtest86+.bin console=ttyS0,115200n8
menuentry "Memory test (memtest86+, experimental multiboot)" {
	insmod part_msdos
	insmod ext2
	multiboot	/boot/memtest86+_multiboot.bin
menuentry "Memory test (memtest86+, serial console 115200, experimental multiboot)" {
	insmod part_msdos
	insmod ext2
	multiboot	/boot/memtest86+_multiboot.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda1/etc/fstab: ================================
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# / was on /dev/sda1 during installation
UUID=29c145cd-1e3b-4d16-897d-77cf28f66b7f /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=597ddfc4-c9ef-4d65-b3a7-e90fe4027925 none            swap    sw              0       0
/dev/sdb1       /media/usb0     auto    rw,user,noauto  0       0
=================== sda1: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
               =                boot/grub/core.img                             1
               =                boot/grub/grub.cfg                             1
               =                boot/initrd.img-3.4-9-rtai-686-pae             1
               =                boot/vmlinuz-3.4-9-rtai-686-pae                1
            ?? = ??             vmlinuz                                        1
============================== sdb1/syslinux.cfg: ==============================
DEFAULT loadconfig
LABEL loadconfig
  CONFIG /isolinux/isolinux.cfg
  APPEND /isolinux/
================= sdb1: Location of files loaded by Syslinux: ==================
            ?? = ??             ldlinux.sys                                    1
            ?? = ??             syslinux.cfg                                   1
=============================== StdErr Messages: ===============================
xz: (stdin): Compressed data is corrupt
awk: cmd. line:36: Math support is not compiled in
Mów mi Andżej
chyba przy instalowaniu wybierałem złe partycje. zainstalowałem jeszcze raz tym razem wybrałem opcję +LVN (jakoś tak) i system się normalnie załadował po instalacji
