Debian 9 - błąd przy ładowaniu systemu
jumper1
Post autor: jumper1 »
Mam problem jak w temacie - Podczas ładowania systemu wyskakuje błąd (wklejony poniżej), przyznaję się bez bicia, nie przyuważyłem po jakiej aktualizacji (lub nie po niej) to się zaczęło pojawiać - system działa normalnie.
Prosiłbym o pomoc od czego to może być.
dane:
debian 9.4
4.9.0-6-amd64
log:
[    0.228115] ACPI: Added _OSI(Module Device)
Jun  6 08:05:49 x kernel: [    0.228116] ACPI: Added _OSI(Processor Device)
Jun  6 08:05:49 x kernel: [    0.228117] ACPI: Added _OSI(3.0 _SCP Extensions)
Jun  6 08:05:49 x kernel: [    0.228118] ACPI: Added _OSI(Processor Aggregator Device)
Jun  6 08:05:49 x kernel: [    0.228284] ACPI Error: Field [CDW3] at 96 exceeds Buffer [NULL] size 64 (bits) (20160831/dsopcode-236)
Jun  6 08:05:49 x kernel: [    0.228417] ACPI Error: Method parse/execution failed [\_SB._OSC] (Node ffff8af2af5b1910), AE_AML_BUFFER_LIMIT (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.228779] ACPI Error: [CSD0] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.228939] ACPI Error: Method parse/execution failed [\_PR.CPU0._OSC] (Node ffff8af2af5be910), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.229144] ACPI Error: Method parse/execution failed [\_PR.CPU0._PDC] (Node ffff8af2af5beb18), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.229461] ACPI Error: [CSD1] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.229620] ACPI Error: Method parse/execution failed [\_PR.CPU1._OSC] (Node ffff8af2af5be528), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.229825] ACPI Error: Method parse/execution failed [\_PR.CPU1._PDC] (Node ffff8af2af5bec80), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.230140] ACPI Error: [CSD2] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.230299] ACPI Error: Method parse/execution failed [\_PR.CPU2._OSC] (Node ffff8af2af5be4b0), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.230504] ACPI Error: Method parse/execution failed [\_PR.CPU2._PDC] (Node ffff8af2af5beac8), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.230820] ACPI Error: [CSD3] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.231006] ACPI Error: Method parse/execution failed [\_PR.CPU3._OSC] (Node ffff8af2af5be640), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.231212] ACPI Error: Method parse/execution failed [\_PR.CPU3._PDC] (Node ffff8af2af5be2a8), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.231526] ACPI Error: [CSD4] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.231691] ACPI Error: Method parse/execution failed [\_PR.CPU4._OSC] (Node ffff8af2af5be3e8), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.231895] ACPI Error: Method parse/execution failed [\_PR.CPU4._PDC] (Node ffff8af2af5be230), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.232216] ACPI Error: [CSD5] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.232421] ACPI Error: Method parse/execution failed [\_PR.CPU5._OSC] (Node ffff8af2af5be208), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.232672] ACPI Error: Method parse/execution failed [\_PR.CPU5._PDC] (Node ffff8af2af5bebe0), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.233035] ACPI Error: [CSD6] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.233241] ACPI Error: Method parse/execution failed [\_PR.CPU6._OSC] (Node ffff8af2af5bea78), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.233492] ACPI Error: Method parse/execution failed [\_PR.CPU6._PDC] (Node ffff8af2af5be410), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.233854] ACPI Error: [CSD7] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
Jun  6 08:05:49 x kernel: [    0.234060] ACPI Error: Method parse/execution failed [\_PR.CPU7._OSC] (Node ffff8af2af5be0f0), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.234311] ACPI Error: Method parse/execution failed [\_PR.CPU7._PDC] (Node ffff8af2af5beb40), AE_NOT_FOUND (20160831/psparse-543)
Jun  6 08:05:49 x kernel: [    0.234714] ACPI: Interpreter enabled
Jun  6 08:05:49 x kernel: [    0.234727] ACPI: (supports S0 S4 S5)
Jun  6 08:05:49 x kernel: [    0.234728] ACPI: Using IOAPIC for interrupt routing
Jun  6 08:05:49 x kernel: [    0.234746] HEST: Table parsing has been initialized.
Jun  6 08:05:49 x kernel: [    0.234748] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jun  6 08:05:49 x kernel: [    0.237596] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7f])
Jun  6 08:05:49 x kernel: [    0.237602] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
Jun  6 08:05:49 x kernel: [    0.237606] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
Moderowano: Do prezentowania logów używaj znaczników kodu.
Re: Debian 9 - błąd przy ładowaniu systemu
spróbuj zaktualizować bios płyty głównej.
te pojawające się błędy z ACPI chyba zaczęły się od kernela 4.8 albo 4.9 ....
nie są niepokojące w każdym razie.... co by system nie mogł chodzić dobrze. Po prostu podczas startu systemu sypie błędami.
czasami pomaga właśnie aktualizacja biosu. ewentualnie aby komunikatu nie widzieć trzeba wyłączyć pewne funkcje w kernelu i skompilować swój kernel, ewentualnie wymiana sprzętu na nowszy.
Jaką masz płyte główna? z jakiego roku?
https://www.linuxquestions.org/question ... 175448907/
https://bugzilla.redhat.com/show_bug.cgi?id=1413342
hepa
Post autor: hepa »
Zobacz, co się stanie, jak odłączysz dyski twarde (HDD) z komputera.
Jak masz SSD, to spróbuj zainstalować tylko na SSD, a resztę odłącz.
