[+]Pendive bardzo wolne kopiowanie
korbielow
Post autor: korbielow »
Witam!
Mam Debian GNU/Linux buster/sid i nie wiem czemu, ale bardzo wolno mi kopiuje pliki na pendrive.
dmesg output
[74137.718581] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[74137.739071] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[74137.757968] acpi PNP0401:00: Already enumerated
[74137.779783] acpi PNP0501:01: Still not present
[74137.814853] video LNXVIDEO:01: Restoring backlight state
[74137.820016] PM: suspend exit
[74138.042971] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[74138.044593] ata2.00: configured for UDMA/100
[74138.256278] e1000e: eno1 NIC Link is Down
[74138.257144] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[74138.479266] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[74138.481198] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[74138.552106] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[74138.552124] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[74138.552393] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[74138.639253] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[74138.639270] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[74138.639460] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[74138.711539] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[74139.689842] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[74139.689859] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[74139.690096] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[74140.628224] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[74140.628288] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[74140.630042] wlp2s0b1: authenticated
[74140.631911] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[74140.635232] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=2)
[74140.635924] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[74140.635931] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[74140.635947] wlp2s0b1: associated
[74140.642708] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[74140.650991] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[74140.651379] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[74140.660053] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[74434.348345] audit: type=1400 audit(1521137502.673:35): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/sbin/cups-browsed" pid=13465 comm="apparmor_parser"
[76914.768208] pci_bus 0000:0b: Allocating resources
[76914.768240] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.768247] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.768256] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.768262] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.776740] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.776747] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.776754] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.776759] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.776794] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.776798] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.776804] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.776809] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.777140] pci_bus 0000:01: Allocating resources
[76914.777159] pci_bus 0000:02: Allocating resources
[76914.777182] pci_bus 0000:03: Allocating resources
[76914.777251] pci_bus 0000:05: Allocating resources
[76914.777265] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.777269] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.777275] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.777280] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.777315] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.777319] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.777326] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.777331] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.777431] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.777436] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.777443] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.777447] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.777524] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.777529] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.777537] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.777543] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76914.777707] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76914.777711] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76914.777717] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76914.777724] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76915.303517] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[76915.305382] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[76915.344766] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[76915.344777] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[76915.432250] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[76915.432268] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[76915.432521] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76915.476068] PM: suspend entry (deep)
[76915.476071] PM: Syncing filesystems ... done.
[76915.483213] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[76915.483242] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[76915.483252] Freezing user space processes ... (elapsed 0.030 seconds) done.
[76915.514102] OOM killer disabled.
[76915.514103] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[76915.515495] Suspending console(s) (use no_console_suspend to debug)
[76915.515826] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[76915.516788] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[76915.516867] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[76915.516870] sd 1:0:0:0: [sdb] Stopping disk
[76915.517246] sd 0:0:0:0: [sda] Stopping disk
[76915.537540] e1000e: EEE TX LPI TIMER: 00000000
[76915.555847] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[76915.901857] ACPI: Preparing to enter system sleep state S3
[76915.941803] ACPI: EC: event blocked
[76915.941805] ACPI: EC: EC stopped
[76915.941806] PM: Saving platform NVS memory
[76915.941827] Disabling non-boot CPUs ...
[76915.958033] IRQ 25: no longer affine to CPU1
[76915.959058] smpboot: CPU 1 is now offline
[76915.978003] IRQ 26: no longer affine to CPU2
[76915.979186] smpboot: CPU 2 is now offline
[76916.002921] smpboot: CPU 3 is now offline
[76916.004502] ACPI: Low-level resume complete
[76916.004571] ACPI: EC: EC started
[76916.004571] PM: Restoring platform NVS memory
[76916.004979] Enabling non-boot CPUs ...
[76916.005311] x86: Booting SMP configuration:
[76916.005313] smpboot: Booting Node 0 Processor 1 APIC 0x4
[76916.007811]  cache: parent cpu1 should not be sleeping
[76916.008133] CPU1 is up
[76916.008434] smpboot: Booting Node 0 Processor 2 APIC 0x1
[76916.010835]  cache: parent cpu2 should not be sleeping
[76916.011192] CPU2 is up
[76916.011519] smpboot: Booting Node 0 Processor 3 APIC 0x5
[76916.013915]  cache: parent cpu3 should not be sleeping
[76916.014288] CPU3 is up
[76916.016290] ACPI: Waking up from system sleep state S3
[76916.182847] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[76916.185409] ACPI: EC: event unblocked
[76916.188620] sd 0:0:0:0: [sda] Starting disk
[76916.188621] sd 1:0:0:0: [sdb] Starting disk
[76916.434595] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[76916.442601] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[76916.538047] ata6: SATA link down (SStatus 0 SControl 300)
[76916.538081] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[76916.538116] ata5: SATA link down (SStatus 0 SControl 300)
[76916.620071] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[76916.630540] usb 2-1.2: reset high-speed USB device number 12 using ehci-pci
[76916.632137] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[76916.636178] ata1.00: configured for UDMA/133
[76916.774537] firewire_core 0000:03:00.4: rediscovered device fw0
[76916.818545] usb 2-1.7: reset full-speed USB device number 5 using ehci-pci
[76916.838144] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[76916.937462] usb 2-1.7:1.0: rebind failed: -517
[76916.937468] usb 2-1.7:1.1: rebind failed: -517
[76916.938712] OOM killer enabled.
[76916.938713] Restarting tasks ...
[76916.938792] pci_bus 0000:0b: Allocating resources
[76916.938815] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76916.938819] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76916.938825] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76916.938829] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76916.954864] done.
[76917.008696] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.008702] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.008708] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.008713] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.008742] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.008744] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.008749] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.008753] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.009035] pci_bus 0000:01: Allocating resources
[76917.009051] pci_bus 0000:02: Allocating resources
[76917.009072] pci_bus 0000:03: Allocating resources
[76917.009140] pci_bus 0000:05: Allocating resources
[76917.009151] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.009154] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.009159] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.009162] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.009183] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.009186] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.009191] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.009195] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.009248] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.009250] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.009255] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.009259] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.009300] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.009302] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.009307] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.009311] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.009394] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[76917.009396] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[76917.009401] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[76917.009405] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[76917.011295] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[76917.030572] acpi PNP0401:00: Already enumerated
[76917.041263] acpi PNP0501:01: Still not present
[76917.086778] video LNXVIDEO:01: Restoring backlight state
[76917.089783] PM: suspend exit
[76917.338548] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[76917.340516] ata2.00: configured for UDMA/100
[76917.555516] e1000e: eno1 NIC Link is Down
[76917.556426] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[76917.778714] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[76917.781195] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76917.850990] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[76917.851006] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[76917.851291] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76917.939061] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[76917.939075] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[76917.939282] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76918.015328] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76919.000914] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[76919.000932] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[76919.001127] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[76919.955883] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[76919.956011] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[76919.957950] wlp2s0b1: authenticated
[76919.962373] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[76919.965728] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[76919.966560] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[76919.966567] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[76919.966583] wlp2s0b1: associated
[76919.972376] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[76919.980361] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[76919.980735] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[76919.988966] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[77153.292205] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[77153.292820] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[77153.297256] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[77153.297268] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[77153.394145] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[77153.394161] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[77153.394361] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[77153.439562] PM: suspend entry (deep)
[77153.439565] PM: Syncing filesystems ... done.
[77153.446721] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[77153.446754] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[77153.446762] Freezing user space processes ... (elapsed 0.014 seconds) done.
[77153.461746] OOM killer disabled.
[77153.461747] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[77153.463144] Suspending console(s) (use no_console_suspend to debug)
[77153.463498] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[77153.464574] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[77153.464588] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[77153.464633] sd 1:0:0:0: [sdb] Stopping disk
[77153.464951] sd 0:0:0:0: [sda] Stopping disk
[77153.481343] e1000e: EEE TX LPI TIMER: 00000000
[77153.497851] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[77153.861797] ACPI: Preparing to enter system sleep state S3
[77153.901720] ACPI: EC: event blocked
[77153.901721] ACPI: EC: EC stopped
[77153.901722] PM: Saving platform NVS memory
[77153.901742] Disabling non-boot CPUs ...
[77153.917978] IRQ 25: no longer affine to CPU1
[77153.918999] smpboot: CPU 1 is now offline
[77153.937909] IRQ 26: no longer affine to CPU2
[77153.939078] smpboot: CPU 2 is now offline
[77153.961827] IRQ 16: no longer affine to CPU3
[77153.962843] smpboot: CPU 3 is now offline
[77153.964374] ACPI: Low-level resume complete
[77153.964443] ACPI: EC: EC started
[77153.964443] PM: Restoring platform NVS memory
[77153.964847] Enabling non-boot CPUs ...
[77153.965194] x86: Booting SMP configuration:
[77153.965195] smpboot: Booting Node 0 Processor 1 APIC 0x4
[77153.967720]  cache: parent cpu1 should not be sleeping
[77153.968048] CPU1 is up
[77153.968364] smpboot: Booting Node 0 Processor 2 APIC 0x1
[77153.970796]  cache: parent cpu2 should not be sleeping
[77153.971152] CPU2 is up
[77153.971495] smpboot: Booting Node 0 Processor 3 APIC 0x5
[77153.973927]  cache: parent cpu3 should not be sleeping
[77153.974290] CPU3 is up
[77153.976288] ACPI: Waking up from system sleep state S3
[77154.131177] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[77154.133377] ACPI: EC: event unblocked
[77154.134778] sd 0:0:0:0: [sda] Starting disk
[77154.134807] sd 1:0:0:0: [sdb] Starting disk
[77154.382504] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[77154.390510] usb 2-1.7: reset full-speed USB device number 5 using ehci-pci
[77154.485502] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[77154.485533] ata6: SATA link down (SStatus 0 SControl 300)
[77154.486023] ata5: SATA link down (SStatus 0 SControl 300)
[77154.560480] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[77154.572039] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[77154.576067] ata1.00: configured for UDMA/133
[77154.578460] usb 2-1.2: reset high-speed USB device number 12 using ehci-pci
[77154.734514] firewire_core 0000:03:00.4: rediscovered device fw0
[77154.766494] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[77154.783657] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[77154.895074] usb 2-1.7:1.0: rebind failed: -517
[77154.895080] usb 2-1.7:1.1: rebind failed: -517
[77154.895310] OOM killer enabled.
[77154.895311] Restarting tasks ...
[77154.895413] pci_bus 0000:0b: Allocating resources
[77154.895439] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.895443] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.895449] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.895454] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.897803] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[77154.913760] done.
[77154.934717] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.934723] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.934729] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.934733] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.934767] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.934771] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.934776] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.934781] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.935096] pci_bus 0000:01: Allocating resources
[77154.935115] pci_bus 0000:02: Allocating resources
[77154.935137] pci_bus 0000:03: Allocating resources
[77154.935207] pci_bus 0000:05: Allocating resources
[77154.935221] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.935225] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.935231] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.935236] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.935267] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.935271] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.935276] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.935281] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.935355] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.935358] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.935364] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.935369] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.935423] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.935427] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.935433] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.935437] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.935545] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[77154.935548] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[77154.935554] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[77154.935559] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[77154.952957] acpi PNP0401:00: Already enumerated
[77154.966003] acpi PNP0501:01: Still not present
[77154.985195] video LNXVIDEO:01: Restoring backlight state
[77154.987620] PM: suspend exit
[77155.282382] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[77155.284269] ata2.00: configured for UDMA/100
[77155.502792] e1000e: eno1 NIC Link is Down
[77155.503829] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[77155.726650] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[77155.728869] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[77155.798915] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[77155.798933] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[77155.799218] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[77155.871329] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[77156.731028] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[77156.796177] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[77156.796362] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[77156.798334] wlp2s0b1: authenticated
[77156.802171] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[77156.805899] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[77156.806539] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[77156.806546] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[77156.806559] wlp2s0b1: associated
[77156.816563] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[77156.833488] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[77156.833871] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[77156.843324] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[77164.410591] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[78475.850186] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 153/256 dur 1730/1504
[80553.300474] pci_bus 0000:0b: Allocating resources
[80553.300505] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.300511] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.300519] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.300524] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.304537] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.304544] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.304551] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.304558] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.304598] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.304603] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.304610] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.304616] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.304979] pci_bus 0000:01: Allocating resources
[80553.305014] pci_bus 0000:02: Allocating resources
[80553.305038] pci_bus 0000:03: Allocating resources
[80553.305112] pci_bus 0000:05: Allocating resources
[80553.305128] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.305133] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.305141] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.305147] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.305413] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.305418] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.305425] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.305431] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.305530] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.305534] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.305541] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.305546] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.305621] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.305626] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.305633] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.305638] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.305779] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80553.305784] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80553.305790] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80553.305795] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80553.832459] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[80553.836230] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[80553.873557] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[80553.873570] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[80553.961776] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[80553.961792] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[80553.961980] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80554.011183] PM: suspend entry (deep)
[80554.011186] PM: Syncing filesystems ... done.
[80554.019004] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[80554.019049] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[80554.019062] Freezing user space processes ... (elapsed 0.008 seconds) done.
[80554.027401] OOM killer disabled.
[80554.027402] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[80554.028750] Suspending console(s) (use no_console_suspend to debug)
[80554.029068] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[80554.029782] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[80554.029846] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[80554.029852] sd 1:0:0:0: [sdb] Stopping disk
[80554.030296] sd 0:0:0:0: [sda] Stopping disk
[80554.046742] e1000e: EEE TX LPI TIMER: 00000000
[80554.059724] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[80554.429319] ACPI: Preparing to enter system sleep state S3
[80554.469186] ACPI: EC: event blocked
[80554.469187] ACPI: EC: EC stopped
[80554.469188] PM: Saving platform NVS memory
[80554.469206] Disabling non-boot CPUs ...
[80554.485369] IRQ 25: no longer affine to CPU1
[80554.486380] smpboot: CPU 1 is now offline
[80554.505439] IRQ 26: no longer affine to CPU2
[80554.506600] smpboot: CPU 2 is now offline
[80554.529368] IRQ 16: no longer affine to CPU3
[80554.530383] smpboot: CPU 3 is now offline
[80554.531818] ACPI: Low-level resume complete
[80554.531886] ACPI: EC: EC started
[80554.531886] PM: Restoring platform NVS memory
[80554.532296] Enabling non-boot CPUs ...
[80554.532616] x86: Booting SMP configuration:
[80554.532617] smpboot: Booting Node 0 Processor 1 APIC 0x4
[80554.535111]  cache: parent cpu1 should not be sleeping
[80554.535433] CPU1 is up
[80554.535717] smpboot: Booting Node 0 Processor 2 APIC 0x1
[80554.538161]  cache: parent cpu2 should not be sleeping
[80554.538511] CPU2 is up
[80554.538819] smpboot: Booting Node 0 Processor 3 APIC 0x5
[80554.541317]  cache: parent cpu3 should not be sleeping
[80554.541683] CPU3 is up
[80554.543675] ACPI: Waking up from system sleep state S3
[80554.710649] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[80554.713138] ACPI: EC: event unblocked
[80554.719114] sd 1:0:0:0: [sdb] Starting disk
[80554.719115] sd 0:0:0:0: [sda] Starting disk
[80554.962032] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[80554.974090] usb 2-1.2: reset high-speed USB device number 12 using ehci-pci
[80555.073113] ata6: SATA link down (SStatus 0 SControl 300)
[80555.073144] ata5: SATA link down (SStatus 0 SControl 300)
[80555.073635] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[80555.082295] usb 2-1.2: device firmware changed
[80555.139900] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[80555.151241] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[80555.155262] ata1.00: configured for UDMA/133
[80555.162112] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[80555.302072] firewire_core 0000:03:00.4: rediscovered device fw0
[80555.350097] usb 2-1.7: reset full-speed USB device number 5 using ehci-pci
[80555.351268] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[80555.465045] usb 2-1.7:1.0: rebind failed: -517
[80555.465051] usb 2-1.7:1.1: rebind failed: -517
[80555.466280] OOM killer enabled.
[80555.466281] Restarting tasks ...
[80555.466360] pci_bus 0000:0b: Allocating resources
[80555.466384] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.466388] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.466393] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.466398] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.481812] done.
[80555.489300] usb 2-1.2: USB disconnect, device number 12
[80555.542903] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.542908] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.542914] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.542919] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.542951] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.542954] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.542959] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.542963] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.543268] pci_bus 0000:01: Allocating resources
[80555.543286] pci_bus 0000:02: Allocating resources
[80555.543306] pci_bus 0000:03: Allocating resources
[80555.543376] pci_bus 0000:05: Allocating resources
[80555.543389] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.543392] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.543396] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.543401] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.543431] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.543434] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.543439] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.543442] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.543512] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.543515] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.543520] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.543523] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.543577] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.543580] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.543586] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.543589] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.543689] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[80555.543693] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[80555.543698] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[80555.543703] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[80555.571550] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[80555.585088] acpi PNP0401:00: Already enumerated
[80555.604702] acpi PNP0501:01: Still not present
[80555.643601] video LNXVIDEO:01: Restoring backlight state
[80555.646258] PM: suspend exit
[80555.918097] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[80555.920030] ata2.00: configured for UDMA/100
[80556.072260] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[80556.072324] sd 6:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[80556.120977] e1000e: eno1 NIC Link is Down
[80556.122263] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[80556.180018] usb 2-1.2: new high-speed USB device number 15 using ehci-pci
[80556.287481] usb 2-1.2: New USB device found, idVendor=0781, idProduct=5567
[80556.287485] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[80556.287489] usb 2-1.2: Product: Cruzer Blade
[80556.287492] usb 2-1.2: Manufacturer: SanDisk
[80556.287495] usb 2-1.2: SerialNumber: 4C531001410118110382
[80556.288035] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[80556.288222] scsi host6: usb-storage 2-1.2:1.0
[80556.338299] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[80556.340296] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80556.414669] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[80556.414685] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[80556.414906] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80556.506645] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[80556.506661] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[80556.506831] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80556.569198] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80557.319227] scsi 6:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.27 PQ: 0 ANSI: 6
[80557.319759] sd 6:0:0:0: Attached scsi generic sg2 type 0
[80557.321804] sd 6:0:0:0: [sdc] 122606848 512-byte logical blocks: (62.8 GB/58.5 GiB)
[80557.323309] sd 6:0:0:0: [sdc] Write Protect is off
[80557.323313] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[80557.324300] sd 6:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[80557.337699]  sdc: sdc4
[80557.341307] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[80557.558539] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[80557.558559] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[80557.558780] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[80557.649225] FAT-fs (sdc4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[80558.502903] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[80558.502958] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[80558.505005] wlp2s0b1: authenticated
[80558.506246] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[80558.509586] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[80558.510285] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[80558.510290] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[80558.510303] wlp2s0b1: associated
[80558.519909] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[80558.527689] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[80558.528105] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[80558.537263] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[80581.816990] usb 2-1.3: new high-speed USB device number 16 using ehci-pci
[80581.927629] usb 2-1.3: New USB device found, idVendor=05c6, idProduct=f006
[80581.927634] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[80581.927637] usb 2-1.3: Product: Android
[80581.927640] usb 2-1.3: Manufacturer: Android
[80581.927643] usb 2-1.3: SerialNumber: 721QECRQ34MAF
[80581.930216] hid-generic 0003:05C6:F006.0003: hiddev1,hidraw2: USB HID v1.11 Device [Android Android] on usb-0000:00:1d.0-1.3/input0
[80594.908140] usb 2-1.3: USB disconnect, device number 16
[80595.228385] usb 2-1.3: new high-speed USB device number 17 using ehci-pci
[80595.338969] usb 2-1.3: New USB device found, idVendor=2a45, idProduct=2008
[80595.338973] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[80595.338977] usb 2-1.3: Product: Android
[80595.338979] usb 2-1.3: Manufacturer: Android
[80595.338982] usb 2-1.3: SerialNumber: 721QECRQ34MAF
[81678.226942] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 153/256 dur 1730/1504
[81690.076533] usb 2-1.2: USB disconnect, device number 15
[81694.906518] usb 2-1.2: new high-speed USB device number 18 using ehci-pci
[81695.017146] usb 2-1.2: New USB device found, idVendor=090c, idProduct=1000
[81695.017150] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[81695.017155] usb 2-1.2: Product: Flash Disk
[81695.017156] usb 2-1.2: Manufacturer: USB
[81695.018273] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[81695.020416] scsi host6: usb-storage 2-1.2:1.0
[81696.156796] scsi 6:0:0:0: Direct-Access     USB      Flash Disk       1100 PQ: 0 ANSI: 4
[81696.157217] sd 6:0:0:0: Attached scsi generic sg2 type 0
[81696.158398] sd 6:0:0:0: [sdc] 31129600 512-byte logical blocks: (15.9 GB/14.8 GiB)
[81696.159559] sd 6:0:0:0: [sdc] Write Protect is off
[81696.159562] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[81696.160645] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[81696.169037]  sdc: sdc1
[81696.173388] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[81696.494046] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[81696.988386] usb 2-1.3: USB disconnect, device number 17
[82523.825688] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[82523.826194] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[82523.832139] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[82523.832149] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[82523.932551] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[82523.932566] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[82523.933665] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82523.993212] PM: suspend entry (deep)
[82523.993215] PM: Syncing filesystems ... done.
[82524.002064] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[82524.002093] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[82524.002102] Freezing user space processes ... (elapsed 0.007 seconds) done.
[82524.009910] OOM killer disabled.
[82524.009911] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[82524.011233] Suspending console(s) (use no_console_suspend to debug)
[82524.011667] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[82524.012378] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[82524.012439] sd 1:0:0:0: [sdb] Stopping disk
[82524.012446] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[82524.012802] sd 0:0:0:0: [sda] Stopping disk
[82524.026881] e1000e: EEE TX LPI TIMER: 00000000
[82524.045734] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[82524.404257] ACPI: Preparing to enter system sleep state S3
[82524.444144] ACPI: EC: event blocked
[82524.444144] ACPI: EC: EC stopped
[82524.444145] PM: Saving platform NVS memory
[82524.444163] Disabling non-boot CPUs ...
[82524.460314] IRQ 25: no longer affine to CPU1
[82524.461323] smpboot: CPU 1 is now offline
[82524.480296] IRQ 26: no longer affine to CPU2
[82524.481449] smpboot: CPU 2 is now offline
[82524.504318] IRQ 16: no longer affine to CPU3
[82524.505332] smpboot: CPU 3 is now offline
[82524.506943] ACPI: Low-level resume complete
[82524.507012] ACPI: EC: EC started
[82524.507012] PM: Restoring platform NVS memory
[82524.507390] Enabling non-boot CPUs ...
[82524.507766] x86: Booting SMP configuration:
[82524.507767] smpboot: Booting Node 0 Processor 1 APIC 0x4
[82524.510262]  cache: parent cpu1 should not be sleeping
[82524.510587] CPU1 is up
[82524.510945] smpboot: Booting Node 0 Processor 2 APIC 0x1
[82524.513356]  cache: parent cpu2 should not be sleeping
[82524.513705] CPU2 is up
[82524.514069] smpboot: Booting Node 0 Processor 3 APIC 0x5
[82524.516567]  cache: parent cpu3 should not be sleeping
[82524.516931] CPU3 is up
[82524.518930] ACPI: Waking up from system sleep state S3
[82524.673296] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[82524.675877] ACPI: EC: event unblocked
[82524.680191] sd 0:0:0:0: [sda] Starting disk
[82524.680418] sd 1:0:0:0: [sdb] Starting disk
[82524.917071] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[82524.933049] usb 2-1.7: reset full-speed USB device number 5 using ehci-pci
[82525.032013] ata6: SATA link down (SStatus 0 SControl 300)
[82525.032396] ata5: SATA link down (SStatus 0 SControl 300)
[82525.032430] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[82525.103511] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[82525.114502] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[82525.118540] ata1.00: configured for UDMA/133
[82525.121042] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[82525.269008] firewire_core 0000:03:00.4: rediscovered device fw0
[82525.309033] usb 2-1.2: reset high-speed USB device number 18 using ehci-pci
[82525.337934] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[82525.432057] usb 2-1.7:1.0: rebind failed: -517
[82525.432076] usb 2-1.7:1.1: rebind failed: -517
[82525.433266] OOM killer enabled.
[82525.433267] Restarting tasks ...
[82525.433352] pci_bus 0000:0b: Allocating resources
[82525.433376] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.433380] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.433385] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.433390] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.451433] done.
[82525.512981] usb 2-1.3: new high-speed USB device number 19 using ehci-pci
[82525.546743] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.546749] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.546755] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.546760] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.546792] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.546796] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.546802] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.546807] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.547126] pci_bus 0000:01: Allocating resources
[82525.547144] pci_bus 0000:02: Allocating resources
[82525.547165] pci_bus 0000:03: Allocating resources
[82525.547233] pci_bus 0000:05: Allocating resources
[82525.547246] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.547250] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.547255] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.547260] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.547287] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.547290] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.547296] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.547301] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.547372] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.547375] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.547381] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.547386] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.547440] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.547443] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.547448] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.547453] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.547560] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[82525.547563] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[82525.547568] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[82525.547573] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[82525.573460] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[82525.592787] acpi PNP0401:00: Already enumerated
[82525.606056] acpi PNP0501:01: Still not present
[82525.628584] usb 2-1.3: New USB device found, idVendor=2a45, idProduct=2008
[82525.628587] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[82525.628589] usb 2-1.3: Product: Android
[82525.628590] usb 2-1.3: Manufacturer: Android
[82525.628591] usb 2-1.3: SerialNumber: 721QECRQ34MAF
[82525.644555] video LNXVIDEO:01: Restoring backlight state
[82525.649984] PM: suspend exit
[82525.880999] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[82525.882720] ata2.00: configured for UDMA/100
[82526.163088] e1000e: eno1 NIC Link is Down
[82526.164725] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[82526.389145] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[82526.390700] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82526.459576] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[82526.459590] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[82526.459821] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82526.543876] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[82526.543889] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[82526.544065] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82526.606257] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82527.469733] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[82527.593861] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[82527.593875] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[82527.594066] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[82528.525965] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[82528.526028] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[82528.529804] wlp2s0b1: authenticated
[82528.533120] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[82528.536874] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[82528.537439] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[82528.537447] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[82528.537469] wlp2s0b1: associated
[82528.542745] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[82528.550837] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[82528.551270] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[82528.563224] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[82529.025719] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[82529.542736] usb 2-1.2: USB disconnect, device number 18
[82529.581782] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[82529.581848] sd 6:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[82532.836673] usb 2-1.2: new high-speed USB device number 20 using ehci-pci
[82532.945707] usb 2-1.2: New USB device found, idVendor=0781, idProduct=5567
[82532.945711] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[82532.945713] usb 2-1.2: Product: Cruzer Blade
[82532.945714] usb 2-1.2: Manufacturer: SanDisk
[82532.945715] usb 2-1.2: SerialNumber: 4C531001410118110382
[82532.946734] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[82532.950094] scsi host6: usb-storage 2-1.2:1.0
[82533.973741] scsi 6:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.27 PQ: 0 ANSI: 6
[82533.975231] sd 6:0:0:0: Attached scsi generic sg2 type 0
[82533.976468] sd 6:0:0:0: [sdc] 122606848 512-byte logical blocks: (62.8 GB/58.5 GiB)
[82533.977967] sd 6:0:0:0: [sdc] Write Protect is off
[82533.977970] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[82533.978960] sd 6:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[82533.991880]  sdc: sdc4
[82533.995507] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[82571.186523] FAT-fs (sdc4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[84015.678656] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 153/256 dur 1730/1504
[84379.655485] usb 2-1.2: USB disconnect, device number 20
[84386.535404] usb 2-1.2: new high-speed USB device number 21 using ehci-pci
[84386.646209] usb 2-1.2: New USB device found, idVendor=090c, idProduct=1000
[84386.646213] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[84386.646215] usb 2-1.2: Product: Flash Disk
[84386.646216] usb 2-1.2: Manufacturer: USB
[84386.646218] usb 2-1.2: SerialNumber: SCY0000000002497
[84386.647313] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[84386.651748] scsi host6: usb-storage 2-1.2:1.0
[84387.978409] scsi 6:0:0:0: Direct-Access     USB      Flash Disk       1100 PQ: 0 ANSI: 4
[84387.979018] sd 6:0:0:0: Attached scsi generic sg2 type 0
[84387.981844] sd 6:0:0:0: [sdc] 62914560 512-byte logical blocks: (32.2 GB/30.0 GiB)
[84387.983093] sd 6:0:0:0: [sdc] Write Protect is off
[84387.983096] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[84387.984346] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[84387.999658]  sdc: sdc1 sdc2 < sdc5 >
[84388.007753] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[84404.231473] usb 2-1.3: USB disconnect, device number 19
[84409.175335] usb 2-1.2: USB disconnect, device number 21
[84409.190490] sd 6:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[84409.190495] sd 6:0:0:0: [sdc] tag#0 CDB: Write(10) 2a 00 01 80 08 00 00 00 08 00
[84409.190498] print_req_error: I/O error, dev sdc, sector 25167872
[84409.190505] Buffer I/O error on dev sdc1, logical block 3145728, lost async page write
[84409.191118] sd 6:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[84409.191121] sd 6:0:0:0: [sdc] tag#0 CDB: Write(10) 2a 00 01 80 08 10 00 00 08 00
[84409.191122] print_req_error: I/O error, dev sdc, sector 25167888
[84409.191125] Buffer I/O error on dev sdc1, logical block 3145730, lost async page write
[84409.191167] print_req_error: I/O error, dev sdc, sector 0
[84409.191173] JBD2: recovery failed
[84409.191177] EXT4-fs (sdc1): error loading journal
[84413.158334] usb 2-1.2: new high-speed USB device number 22 using ehci-pci
[84413.269370] usb 2-1.2: New USB device found, idVendor=090c, idProduct=1000
[84413.269373] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[84413.269375] usb 2-1.2: Product: Flash Disk
[84413.269376] usb 2-1.2: Manufacturer: USB
[84413.269377] usb 2-1.2: SerialNumber: SCY0000000002497
[84413.269918] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[84413.270063] scsi host6: usb-storage 2-1.2:1.0
[84414.601141] scsi 6:0:0:0: Direct-Access     USB      Flash Disk       1100 PQ: 0 ANSI: 4
[84414.603549] sd 6:0:0:0: Attached scsi generic sg2 type 0
[84414.605863] sd 6:0:0:0: [sdc] 62914560 512-byte logical blocks: (32.2 GB/30.0 GiB)
[84414.607113] sd 6:0:0:0: [sdc] Write Protect is off
[84414.607116] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[84414.608351] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[84414.682744]  sdc: sdc1 sdc2 < sdc5 >
[84414.690405] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[84454.712566] EXT4-fs (sdc1): 1 orphan inode deleted
[84454.712568] EXT4-fs (sdc1): recovery complete
[84456.317058] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[84508.431286] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[84631.663844]  sdc: sdc1 sdc2 < >
[84633.092829]  sdc: sdc1
[84634.432473]  sdc:
[84634.678112]  sdc:
[84634.698080]  sdc: sdc1
[84635.052009]  sdc: sdc1
[84639.468001]  sdc: sdc1
[84716.665219]  sdc: sdc1
[84728.710999] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
Ostatnio zmieniony 19 marca 2018, 09:18 przez korbielow, łącznie zmieniany 1 raz.
Re: Pendive bardzo wolne kopiowanie
pokaż co pokazuje polecenie
lsusb -v |grep   bcdUSB
korbielow
root@debian:/home/rafal# lsusb -v |grep   bcdUSB
  bcdUSB               1.10
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
  bcdUSB               2.00
Wolno Ci kopiuje tzn ile MB na sekunde?
Jaki interfejs ma pendrive 1.1 2.0 3.0 ?
Jaki system plików masz na pendrive?
korbielow
Zrobiłem własnie test i wyszło mi że plik 968 MB kopiuje sie 4min31sek. Nagrywam na pendrive san disk 64 GB sdcz50-064g USB 2.0 (interfejs fat32). Denerwuje mnie również pasek postępu, który po paru sekundach pokazuje niby 100%, ale w rzeczywistości trzeba czekac te 4min30sek. Nie pokazuje realnego postępu zapisu.
Jak dla mnie to kupiłeś taniego pendrive z niską prędkością zapisu, otrzymane 3,5 MB/s by to potwierdzało.
Dla pewności możesz:
1. Przeprowadzić szybki test prędkości zapisu/odczytu, np tak (zakładając, że masz go zamontowanego w /media/korbielow/usb, plik testowy będzie miał rozmiar ~200MB):
echo "Zapis"
dd if=/dev/zero of=/media/korbielow/usb/largefile bs=64k count=3000
echo "Dla poprawnosci wyniku czyszcze cache"
sudo sh -c "sync && echo 3 > /proc/sys/vm/drop_caches"
echo "Odczyt"
dd if=/media/korbielow/usb/largefile of=/dev/null bs=64k
2. Zmienić system plików jeśli uważasz, że powinien zapisywać szybciej, bo FAT-alny system plików jest przeżytkiem minionej epoki i jest po prostu wolny, nie wspominając o maksymalnym rozmiarze pików = 4 GB.
Co do błędnego pokazywania stanu kopiowania, niestety to znany problem związany z buforem dla kopiowania usb, można się do tego pryzwyczaić, wyłączyć bufor lub dla pewności wykonywać w konsoli polecenie sync, które się nie zakończy póki bufor nie zostanie opróżniony.
Morfik
Post autor: Morfik »
Realne testy wydajności, to najlepiej przeprowadzić z wykorzystaniem f3read i f3write.
korbielow pisze: 19 marca 2018, 08:09 Denerwuje mnie również pasek postępu, który po paru sekundach pokazuje niby 100%, ale w rzeczywistości trzeba czekac te 4min30sek. Nie pokazuje realnego postępu zapisu.
Nigdy nie pokaże ci realnego postępu, bo dane pierw są czytane z nośnika źródłowego, później buforowane w pamięci RAM i dopiero zapisywane na nośnik docelowy. Jak teraz masz dwa nośniki między którymi kopiujesz dane, i jeden z nich jest o wiele szybszy niż ten drugi, to bufor w pamięci się zapełni raz dwa (w zależności o wolnej pamięci i ustawień kernela), co będzie widoczne jako 100+ MiB/s przez parę sekund, a później ci to zwolni do faktycznej prędkości zapisu nośnika docelowego i dane z RAM będą sączone te 2-3 MiB/s i wtedy niby pasek postępu pokazuje ci 100% ale sobie wisi, aż dane z bufora RAM zostaną zrzucone na dysk. Rada jest taka, by kupować szybsze nośniki, lub odpowiednio sobie skonfigurować kenrel, albo jedno i drugie. :D
korbielow
Własnie znalazłem jakąś recenzje nt. w/w pen drive i to by wyjaśniało wszystko:
Zapis poniżej 5mb/s, zazwyczaj na poziomie 2mb/s. Wrzucenie 40gb backup'u dysku (1 plik) to wyzwanie na pół dnia, jak nie na cały. Zastanawiałem się nad wyborem tego pendrive albo karty microsd 64gb + czytnika i żałuje swojego wyboru.
Co ciekawe, mam taki sam pendrive, tylko 8 giga i działa 10x szybciej (odczyt 20~30mb/s, zapis 10~20mb).
Pendrive-a nie kupowałem tylko dostalem gratis wraz z zakupem laptopa z olx :). Wieć darowanemu koniowu się w zęby nie patrzy, a pen drive służy jako storage na bajki w tv dla córki stąd moje narzekania na wolny zapis pliku powyzej 700MB.:).
Dziękuje wszystkim za wyjaśnienia.
Re: [+]Pendive bardzo wolne kopiowanie
ja na pendrive mam ext4. no ale to pendrive nie do windowsów tylko do przenoszenia pomiedzy linuxami... i kupiłem pena USB 3.0 więc prędkości zapisu ma wartości maksymalne dla specyfikacji USB2.0 bo takie porty mam mam w komputerze...
