tommot
Posty: 15 Rejestracja: 09 października 2016, 12:30
Post
autor: tommot » 06 grudnia 2017, 20:51
prosze o interpretacje tego wpisu w logach
Dec 6 20:02:13 enterprise kernel: [194684.646801] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:03:33 enterprise kernel: [194765.367483] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:04:53 enterprise kernel: [194845.430934] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:07:11 enterprise kernel: [194983.540959] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:07:41 enterprise kernel: [195013.564184] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:08:21 enterprise kernel: [195053.595904] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:09:40 enterprise kernel: [195132.666599] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:11:48 enterprise kernel: [195260.538583] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:13:47 enterprise kernel: [195379.854479] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:15:53 enterprise kernel: [195505.954412] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:17:03 enterprise kernel: [195575.993910] JBD2: Detected IO errors while flushing file data on sda1-8
Dec 6 20:17:41 enterprise kernel: [195614.040634] JBD2: Detected IO errors while flushing file data on sda1-8
bo ja już czarne scenariusze pisze
Debian 9.1
Debian 3.16.43-2+deb8u5
Atom 1Ghz d2500cc miniATX
Ostatnio zmieniony 09 grudnia 2017, 09:02 przez
tommot , łącznie zmieniany 2 razy.
Posty: 3624 Rejestracja: 18 listopada 2013, 21:07
Post
autor: dedito » 06 grudnia 2017, 22:22
Pokaż tablicę smart tego dysku.
tommot
Post
autor: tommot » 07 grudnia 2017, 09:39
wlepię całość
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Black
Device Model: WDC WD3200BEKT-75PVMT1
Serial Number: WD-WXC1A72V1338
LU WWN Device Id: 5 0014ee 6ad78170d
Firmware Version: 01.01A01
User Capacity: 320,072,933,376 bytes [320 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Thu Dec 7 09:35:00 2017 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
Total time to complete Offline
data collection: ( 6600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 68) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 164 163 021 Pre-fail Always - 791
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 319
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18907
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 318
191 G-Sense_Error_Rate 0x0032 033 033 000 Old_age Always - 67
192 Power-Off_Retract_Count 0x0032 198 198 000 Old_age Always - 1901
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 2302889
194 Temperature_Celsius 0x0022 108 094 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0032 084 084 000 Old_age Always - 12148
241 Total_LBAs_Written 0x0032 200 200 000 Old_age Always - 2272128171
242 Total_LBAs_Read 0x0032 200 200 000 Old_age Always - 330699311
254 Free_Fall_Sensor 0x0032 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Poprawiłem znaczniki kodu. Uzupełnij komendę wywołującą.
Post
autor: dedito » 07 grudnia 2017, 11:24
Nie widzę problemów, ale warto też wykonać test.
tommot
Post
autor: tommot » 07 grudnia 2017, 14:58
musiałem chwilę zaczekać na wynik
$smartctl --test=long /dev/sda
smartctl 6.6 2016-05-31 r4324 [i686-linux-3.16.0-4-686-pae] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 68 minutes for test to complete.
Test will complete after Thu Dec 7 13:50:58 2017
Use smartctl -X to abort test.
wynik który nadal mi nic nie mówi
$ smartctl -a /dev/sda
Local Time is: Thu Dec 7 14:52:48 2017 CET
was never started.
command.
power-saving mode.
9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18912
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 2302911
194 Temperature_Celsius 0x0022 107 094 000 Old_age Always - 36
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0032 084 084 000 Old_age Always - 12153
241 Total_LBAs_Written 0x0032 200 200 000 Old_age Always - 2272937636
242 Total_LBAs_Read 0x0032 200 200 000 Old_age Always - 330711342
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 18911 -
# 2 Selective offline Completed without error 00% 18909 -
# 3 Extended offline Completed without error 00% 18908 -
1 10 20 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ps.
$ smartctl -t
=======> ARGUMENT REQUIRED FOR OPTION: t
=======> VALID ARGUMENTS ARE: offline, short, long, conveyance, force, vendor,N, select,M-N, pending,N, afterselect,[on|off] <=======
Use smartctl -h to get a usage summary
Post
autor: dedito » 07 grudnia 2017, 15:10
Dysk nie zgłasza problemów.
Uzupełnij dane na temat wersji systemu, kernela i sprzętu.
