Conky conky: Syntax error
solaris7
Post autor: solaris7 »
Debian_9 stretch
Zainstalowałem conky wrzuciłem mój konfig .conkyrc i dam w terminalu conky jako zwykły user jest to:
conky: Syntax error (/home/alkion/.conkyrc:1: '=' expected near 'no') while reading config file.
conky: Assuming it's in old syntax and attempting conversion.
conky: [string "..."]:139: attempt to index local 'settings' (a nil value)
O co chodzi z tą starą składnią czytam i czytam coś w konfingu mam zmienić.
background no
use_xft yes
xftfont Zekton:size=9
xftalpha 0.5
update_interval 1.0
total_run_times 0
double_buffer yes
no_buffers no
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
own_window_class conky-semi
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
minimum_size 500 5
maximum_width 250
default_color white
#alignment top_right
gap_x 990
gap_y 5
uppercase no
override_utf8_locale yes
TEXT
${color white}System $hr
${color white}Debian GNU/Linux 9 (stretch)
${color white}$sysname ${color white}$kernel (${color white}$machine)
${color white}Process $processes ${color white}w trakcie: $running_processes
${color white}Time work $uptime
${color white}Temperature $hr
${color white}CPU $alignr ${hwmon temp 1}°C ${hwmon temp 2}°C
${color white}HDD $alignr ${execi 60 ~/.scripts/hddtemp}°C
${color white}NVidia GeForce 7600 GS $alignr ${execi 60 ~/conky/nv_temp}°C
${color white}Processor $hr
${color white}Intel i3
${color white}CPU ${cpu cpu}% ${cpubar cpu}
$stippled_hr
${color white}CPU $alignr ${color white}CPU%
${color white}${top name 1} $alignr ${top cpu 1}
${color white}${top name 2} $alignr ${top cpu 2}
${color white}${top name 3} $alignr ${top cpu 3}
${color white}Memory $hr
${color white}RAM DDR3 4GB
${color white}RAM ${memperc}% ${membar}
$stippled_hr
${color white}RAM $alignr ${color white}RAM%
${color white}${top_mem name 1} $alignr ${top_mem mem 1}
${color white}${top_mem name 2} $alignr ${top_mem mem 2}
${color white}${top_mem name 3} $alignr ${top_mem mem 3}
${color white}Partitions $hr
${color white}system ${fs_used /}/${fs_size /} $alignr ${fs_used_perc /}%
${color white}${fs_bar /}
${color white}swap ${swap}/${swapmax} $alignr ${swapperc}%
${color white}${swapbar}
${color white}home ${fs_used /home}/${fs_size /home} $alignr ${fs_used_perc /home}%
${color white}${fs_bar /home}
${color white}Network $hr
${color white}eth1_ ${color white}${addr eth1}
${color white}dowland_ ${downspeedf eth1} KB/s $alignr ${totaldown eth1}
${color white}sending_ ${upspeedf eth1} KB/s $alignr ${totalup eth1}
${color white}wlan0_ ${color white}${addr wlan0}
${color white}dowland_ ${downspeedf wlan0} KB/s $alignr ${totaldown wlan0}
${color white}sending_ ${upspeedf wlan0} KB/s $alignr ${totalup wlan0}
${color white}Network and Ports $hr
DL: ${downspeedf wlan1} kB/s - total: ${totaldown wlan1}
UP: ${upspeedf wlan1} kB/s - total: ${totalup wlan1}
Inbound Connection ${tcp_portmon 1 32767 count}
Outbound Connection ${tcp_portmon 32768 61000 count}
${color}Outbound Connection ${alignr} Port$color
${tcp_portmon 32768 61000 rip 0} ${alignr} ${tcp_portmon 32768 61000 rservice 0}
${tcp_portmon 32768 61000 rip 1} ${alignr} ${tcp_portmon 32768 61000 rservice 1}
${tcp_portmon 32768 61000 rip 2} ${alignr} ${tcp_portmon 32768 61000 rservice 2}
${tcp_portmon 32768 61000 rip 3} ${alignr} ${tcp_portmon 32768 61000 rservice 3}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 4}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 5}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 6}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 7}
${tcp_portmon 32768 61000 rip 4} ${alignr} ${tcp_portmon 32768 61000 rservice 8}
Re: Conky conky: Syntax error
Od Conky 1.10 zmieniła się składnia: https://github.com/brndnmtthws/conky/wi ... n-Settings
Stara konfiguracja jest konwertowana przez conky.
Jeśli działa prawidłowo na starej składni to nie musisz przepisywać na nową.
solaris7
oki poczytam bardziej, mam debianowe zaległości nie używałem Debiana ze dwa lata, konsola mi z deka zardzewiała :) :)
yarq
Post autor: yarq »
conky jest jeszcze wspierane?
W jakim sensie?
