Zainstalowałem sterowniki nvidia i "Oh no something went wrong"
starach
Post autor: starach »
Zainstalowałem sterowniki do karty graficznej GTX 1050 ze strony nvidii. ( NVIDIA-Linux-x86_64-384.90.run )
Zgaduję że przez to system mi zdechł. Mam dostęp do terminala przez Ctrl + Alt + F2
Pełna zwartość dmesg ( tutaj ) nie zmieściło się wszystko:
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.000000]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000007698cfff]
[    0.000000]   node   0: [mem 0x000000007698f000-0x000000007c081fff]
[    0.000000]   node   0: [mem 0x000000007d3fe000-0x000000007d3fefff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000087effffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000087effffff]
[    0.000000] On node 0 totalpages: 8368157
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 23 pages reserved
[    0.000000]   DMA zone: 3996 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 7875 pages used for memmap
[    0.000000]   DMA32 zone: 503937 pages, LIFO batch:31
[    0.000000]   Normal zone: 122816 pages used for memmap
[    0.000000]   Normal zone: 7860224 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x000000007e000000-0x000000007fffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7698d000-0x7698dfff]
[    0.000000] PM: Registered nosave memory: [mem 0x7698e000-0x7698efff]
[    0.000000] PM: Registered nosave memory: [mem 0x7c082000-0x7cb3afff]
[    0.000000] PM: Registered nosave memory: [mem 0x7cb3b000-0x7cb81fff]
[    0.000000] PM: Registered nosave memory: [mem 0x7cb82000-0x7cfb9fff]
[    0.000000] PM: Registered nosave memory: [mem 0x7cfba000-0x7d37efff]
[    0.000000] PM: Registered nosave memory: [mem 0x7d37f000-0x7d3fdfff]
[    0.000000] PM: Registered nosave memory: [mem 0x7d3ff000-0x7fffffff]
[    0.000000] PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed01000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] percpu: Embedded 35 pages/cpu @ffffa0577ec00000 s103512 r8192 d31656 u262144
[    0.000000] pcpu-alloc: s103512 r8192 d31656 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 8237379
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-4.9.0-4-amd64 root=/dev/mapper/laptop--tarach--vg-root ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 32769364K/33472628K available (6196K kernel code, 1137K rwdata, 2856K rodata, 1396K init, 688K bss, 703264K reserved, 0K cma-reserved)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:33024 nr_irqs:2048 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Detected 2800.000 MHz processor
[    0.000025] Calibrating delay loop (skipped), value calculated using timer frequency.. 5616.00 BogoMIPS (lpj=11232000)
[    0.000027] pid_max: default: 32768 minimum: 301
[    0.000040] ACPI: Core revision 20160831
[    0.036343] ACPI: 10 ACPI AML tables successfully acquired and loaded
[    0.036942] Security Framework initialized
[    0.036942] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.036946] AppArmor: AppArmor disabled by boot time parameter
[    0.038242] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.042997] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.045154] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.045174] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.045439] CPU: Physical Processor ID: 0
[    0.045440] CPU: Processor Core ID: 0
[    0.045443] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.045443] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.045447] mce: CPU supports 10 MCE banks
[    0.045455] CPU0: Thermal monitoring enabled (TM1)
[    0.045473] process: using mwait in idle threads
[    0.045475] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.045476] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.046441] Freeing SMP alternatives memory: 24K
[    0.049869] ftrace: allocating 25191 entries in 99 pages
[    0.058686] smpboot: Max logical packages: 2
[    0.059885] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.064164] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.103853] TSC deadline timer enabled
[    0.103858] smpboot: CPU0: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (family: 0x6, model: 0x9e, stepping: 0x9)
[    0.103860] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.103889] ... version:                4
[    0.103889] ... bit width:              48
[    0.103889] ... generic registers:      4
[    0.103890] ... value mask:             0000ffffffffffff
[    0.103890] ... max period:             00007fffffffffff
[    0.103891] ... fixed-purpose events:   3
[    0.103891] ... event mask:             000000070000000f
[    0.104378] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.104456] x86: Booting SMP configuration:
[    0.104457] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.666037] x86: Booted up 1 node, 8 CPUs
[    0.666039] smpboot: Total of 8 processors activated (44935.19 BogoMIPS)
[    0.672937] devtmpfs: initialized
[    0.672985] x86/mm: Memory block size: 128MB
[    0.677383] PM: Registering ACPI NVS region [mem 0x7698d000-0x7698dfff] (4096 bytes)
[    0.677383] PM: Registering ACPI NVS region [mem 0x7cb82000-0x7cfb9fff] (4423680 bytes)
[    0.677492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.677502] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.677547] pinctrl core: initialized pinctrl subsystem
[    0.677631] NET: Registered protocol family 16
[    0.692388] cpuidle: using governor ladder
[    0.708399] cpuidle: using governor menu
[    0.708444] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.708445] ACPI: bus type PCI registered
[    0.708446] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.708503] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.708504] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.708513] PCI: Using configuration type 1 for base access
[    0.724520] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.724520] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.724709] ACPI: Added _OSI(Module Device)
[    0.724710] ACPI: Added _OSI(Processor Device)
[    0.724711] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.724711] ACPI: Added _OSI(Processor Aggregator Device)
[    0.724713] ACPI : EC: EC started
[    0.724714] ACPI : EC: interrupt blocked
[    0.726866] ACPI Error: [^^^PEG0.PEGP.EASP] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[    0.726873] ACPI Error: Method parse/execution failed [\_SB.PCI0.LPCB.EC._REG] (Node ffffa0575e0ed168), AE_NOT_FOUND (20160831/psparse-543)
[    0.726888] ACPI: \: Used as first EC
[    0.726890] ACPI: \: GPE=0x13, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.726890] ACPI: \: Used as boot ECDT EC to handle transactions
[    0.729645] ACPI: Executed 42 blocks of module-level executable AML code
[    0.744009] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.748047] ACPI: Dynamic OEM Table Load:
[    0.748056] ACPI: SSDT 0xFFFFA0575AB13000 000663 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.748208] ACPI: Executed 1 blocks of module-level executable AML code
[    0.748292] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[    0.749459] ACPI: Dynamic OEM Table Load:
[    0.749464] ACPI: SSDT 0xFFFFA0575AB7EC00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.749594] ACPI: Executed 1 blocks of module-level executable AML code
[    0.749974] ACPI: Dynamic OEM Table Load:
[    0.749979] ACPI: SSDT 0xFFFFA0575A559000 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.750312] ACPI: Executed 1 blocks of module-level executable AML code
[    0.750452] ACPI: Dynamic OEM Table Load:
[    0.750455] ACPI: SSDT 0xFFFFA0575A502200 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.750584] ACPI: Executed 1 blocks of module-level executable AML code
[    0.753018] ACPI : EC: EC stopped
[    0.753019] ACPI : EC: EC started
[    0.753019] ACPI : EC: interrupt blocked
[    0.754563] ACPI: \_SB_.PCI0.LPCB.EC__: Used as first EC
[    0.754564] ACPI: \_SB_.PCI0.LPCB.EC__: GPE=0x13, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.754565] ACPI: \_SB_.PCI0.LPCB.EC__: Used as boot DSDT EC to handle transactions
[    0.754565] ACPI: Interpreter enabled
[    0.754602] ACPI: (supports S0 S3 S4 S5)
[    0.754602] ACPI: Using IOAPIC for interrupt routing
[    0.754635] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.756757] ACPI: Power Resource [PG00] (on)
[    0.817228] ACPI: Power Resource [PG01] (on)
[    0.817597] ACPI: Power Resource [PG02] (on)
[    0.818011] ACPI: Power Resource [PXP] (off)
[    0.818347] ACPI: Power Resource [WRST] (on)
[    0.818661] ACPI: Power Resource [WRST] (on)
[    0.818967] ACPI: Power Resource [WRST] (on)
[    0.819274] ACPI: Power Resource [WRST] (on)
[    0.819365] ACPI: Power Resource [PXP] (off)
[    0.819737] ACPI: Power Resource [WRST] (on)
[    0.820125] ACPI: Power Resource [WRST] (on)
[    0.820432] ACPI: Power Resource [WRST] (on)
[    0.820746] ACPI: Power Resource [WRST] (on)
[    0.821054] ACPI: Power Resource [WRST] (on)
[    0.821360] ACPI: Power Resource [WRST] (on)
[    0.821450] ACPI: Power Resource [PXP] (off)
[    0.821785] ACPI: Power Resource [WRST] (on)
[    0.821879] ACPI: Power Resource [PXP] (off)
[    0.822212] ACPI: Power Resource [WRST] (on)
[    0.822525] ACPI: Power Resource [WRST] (on)
[    0.822615] ACPI: Power Resource [PXP] (off)
[    0.822985] ACPI: Power Resource [WRST] (on)
[    0.823368] ACPI: Power Resource [WRST] (on)
[    0.823674] ACPI: Power Resource [WRST] (on)
[    0.823980] ACPI: Power Resource [WRST] (on)
[    0.825155] ACPI: Power Resource [WRST] (on)
[    0.825462] ACPI: Power Resource [WRST] (on)
[    0.825769] ACPI: Power Resource [WRST] (on)
[    0.828811] ACPI: Power Resource [PX01] (off)
[    0.829618] ACPI: Power Resource [PX02] (off)
[    0.830389] ACPI: Power Resource [PX03] (off)
[    0.831705] ACPI: Power Resource [PX04] (off)
[    0.832542] ACPI: Power Resource [PX05] (off)
[    0.832739] ACPI: Power Resource [PX06] (off)
[    0.834916] ACPI: Power Resource [USBC] (on)
[    0.835078] ACPI: Power Resource [PAUD] (on)
[    0.835580] ACPI: Power Resource [V0PR] (on)
[    0.835632] ACPI: Power Resource [V1PR] (on)
[    0.835680] ACPI: Power Resource [V2PR] (on)
[    0.836762] ACPI: Power Resource [PXTC] (on)
[    0.837237] ACPI: Power Resource [PXTC] (off)
[    0.841198] ACPI: Power Resource [FN00] (off)
[    0.841277] ACPI: Power Resource [FN01] (off)
[    0.841355] ACPI: Power Resource [FN02] (off)
[    0.841431] ACPI: Power Resource [FN03] (off)
[    0.841506] ACPI: Power Resource [FN04] (off)
[    0.842477] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.842484] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.843887] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.843887] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.844416] PCI host bridge to bus 0000:00
[    0.844417] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.844418] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.844419] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.844420] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.844421] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.844421] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.844422] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.844423] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.844424] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.844424] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.844425] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.844426] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.844427] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.844428] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.844428] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.844430] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.844431] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[    0.844432] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfc00ffff window]
[    0.844432] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.844433] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.844439] pci 0000:00:00.0: [8086:5910] type 00 class 0x060000
[    0.844751] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.844784] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.844910] pci 0000:00:01.0: System wakeup disabled by ACPI
[    0.844963] pci 0000:00:02.0: [8086:591b] type 00 class 0x030000
[    0.844970] pci 0000:00:02.0: reg 0x10: [mem 0xdd000000-0xddffffff 64bit]
[    0.844975] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.844978] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.845163] pci 0000:00:14.0: [8086:a12f] type 00 class 0x0c0330
[    0.845179] pci 0000:00:14.0: reg 0x10: [mem 0xdf310000-0xdf31ffff 64bit]
[    0.845239] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.845406] pci 0000:00:14.0: System wakeup disabled by ACPI
[    0.845438] pci 0000:00:14.2: [8086:a131] type 00 class 0x118000
[    0.845454] pci 0000:00:14.2: reg 0x10: [mem 0xdf32e000-0xdf32efff 64bit]
[    0.845618] pci 0000:00:16.0: [8086:a13a] type 00 class 0x078000
[    0.845637] pci 0000:00:16.0: reg 0x10: [mem 0xdf32d000-0xdf32dfff 64bit]
[    0.845704] pci 0000:00:16.0: PME# supported from D3hot
[    0.845856] pci 0000:00:17.0: [8086:a103] type 00 class 0x010601
[    0.845868] pci 0000:00:17.0: reg 0x10: [mem 0xdf328000-0xdf329fff]
[    0.845874] pci 0000:00:17.0: reg 0x14: [mem 0xdf32c000-0xdf32c0ff]
[    0.845881] pci 0000:00:17.0: reg 0x18: [io  0xf090-0xf097]
[    0.845887] pci 0000:00:17.0: reg 0x1c: [io  0xf080-0xf083]
[    0.845893] pci 0000:00:17.0: reg 0x20: [io  0xf060-0xf07f]
[    0.845899] pci 0000:00:17.0: reg 0x24: [mem 0xdf32b000-0xdf32b7ff]
[    0.845935] pci 0000:00:17.0: PME# supported from D3hot
[    0.846086] pci 0000:00:1c.0: [8086:a110] type 01 class 0x060400
[    0.846139] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.846261] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.846296] pci 0000:00:1c.3: [8086:a113] type 01 class 0x060400
[    0.846349] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.846469] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.846516] pci 0000:00:1f.0: [8086:a152] type 00 class 0x060100
[    0.846733] pci 0000:00:1f.2: [8086:a121] type 00 class 0x058000
[    0.846742] pci 0000:00:1f.2: reg 0x10: [mem 0xdf324000-0xdf327fff]
[    0.846901] pci 0000:00:1f.3: [8086:a171] type 00 class 0x040300
[    0.846920] pci 0000:00:1f.3: reg 0x10: [mem 0xdf320000-0xdf323fff 64bit]
[    0.846943] pci 0000:00:1f.3: reg 0x20: [mem 0xdf300000-0xdf30ffff 64bit]
[    0.846987] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.847149] pci 0000:00:1f.3: System wakeup disabled by ACPI
[    0.847184] pci 0000:00:1f.4: [8086:a123] type 00 class 0x0c0500
[    0.847231] pci 0000:00:1f.4: reg 0x10: [mem 0xdf32a000-0xdf32a0ff 64bit]
[    0.847299] pci 0000:00:1f.4: reg 0x20: [io  0xf040-0xf05f]
[    0.847537] pci 0000:01:00.0: [10de:1c8d] type 00 class 0x030200
[    0.847555] pci 0000:01:00.0: reg 0x10: [mem 0xde000000-0xdeffffff]
[    0.847571] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.847587] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.847598] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.847608] pci 0000:01:00.0: reg 0x30: [mem 0xdf000000-0xdf07ffff pref]
[    0.847731] pci 0000:01:00.0: System wakeup disabled by ACPI
[    0.856507] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.856509] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.856511] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.856513] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.856580] pci 0000:02:00.0: [8086:24fb] type 00 class 0x028000
[    0.856611] pci 0000:02:00.0: reg 0x10: [mem 0xdf200000-0xdf201fff 64bit]
[    0.856764] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.856864] pci 0000:02:00.0: System wakeup disabled by ACPI
[    0.868515] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.868519] pci 0000:00:1c.0:   bridge window [mem 0xdf200000-0xdf2fffff]
[    0.868577] pci 0000:03:00.0: [1969:10a1] type 00 class 0x020000
[    0.868600] pci 0000:03:00.0: reg 0x10: [mem 0xdf100000-0xdf13ffff 64bit]
[    0.868610] pci 0000:03:00.0: reg 0x18: [io  0xd000-0xd07f]
[    0.868713] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.868783] pci 0000:03:00.0: System wakeup disabled by ACPI
[    0.880521] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.880523] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.880525] pci 0000:00:1c.3:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.884163] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884208] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.884250] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884293] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884335] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884377] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884420] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884462] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.884914] ACPI: Enabled 5 GPEs in block 00 to 7F
[    0.885031] ACPI : EC: interrupt unblocked
[    0.885043] ACPI : EC: event unblocked
[    0.885053] ACPI: \_SB_.PCI0.LPCB.EC__: GPE=0x13, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.885054] ACPI: \_SB_.PCI0.LPCB.EC__: Used as boot DSDT EC to handle transactions and events
[    0.885238] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.885238] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.885240] vgaarb: loaded
[    0.885241] vgaarb: bridge control possible 0000:00:02.0
[    0.885268] Registered efivars operations
[    0.900394] PCI: Using ACPI for IRQ routing
[    0.928396] PCI: pci_cache_line_size set to 64 bytes
[    0.928446] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.928447] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.928448] e820: reserve RAM buffer [mem 0x7698d000-0x77ffffff]
[    0.928449] e820: reserve RAM buffer [mem 0x7c082000-0x7fffffff]
[    0.928450] e820: reserve RAM buffer [mem 0x7d3ff000-0x7fffffff]
[    0.928450] e820: reserve RAM buffer [mem 0x87f000000-0x87fffffff]
[    0.928595] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.928598] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.930639] clocksource: Switched to clocksource hpet
[    0.935702] VFS: Disk quotas dquot_6.6.0
[    0.935721] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.935778] pnp: PnP ACPI init
[    0.935947] pnp 00:00: Plug and Play ACPI device, IDs MSI0007 PNP0303 (active)
[    0.935981] pnp 00:01: Plug and Play ACPI device, IDs SYN1509 SYN1500 SYN0002 PNP0f13 (active)
[    0.936094] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.936096] system 00:02: [io  0xffff] has been reserved
[    0.936097] system 00:02: [io  0xffff] has been reserved
[    0.936098] system 00:02: [io  0xffff] has been reserved
[    0.936099] system 00:02: [io  0x1800-0x18fe] has been reserved
[    0.936100] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.936101] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.936182] system 00:03: [io  0x0800-0x087f] has been reserved
[    0.936183] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.936200] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.936230] system 00:05: [io  0x1854-0x1857] has been reserved
[    0.936232] system 00:05: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.936784] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.936785] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.936786] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.936787] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.936788] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.936789] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.936790] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.936791] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.936792] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.936793] system 00:06: [mem 0xdffe0000-0xdfffffff] has been reserved
[    0.936795] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.936830] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.936831] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.936832] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.936833] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.936834] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.936835] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.936835] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.936837] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.937110] system 00:08: [io  0xff00-0xfffe] has been reserved
[    0.937112] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.938136] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.938137] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.938138] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.938139] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.938918] pnp: PnP ACPI: found 10 devices
[    0.945650] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.945667] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.945669] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.945671] pci 0000:00:01.0:   bridge window [mem 0xde000000-0xdf0fffff]
[    0.945673] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.945676] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.945678] pci 0000:00:1c.0:   bridge window [mem 0xdf200000-0xdf2fffff]
[    0.945683] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.945684] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.945687] pci 0000:00:1c.3:   bridge window [mem 0xdf100000-0xdf1fffff]
[    0.945692] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.945693] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.945694] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.945695] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.945696] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.945696] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.945697] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.945698] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.945699] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.945699] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.945700] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.945701] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[    0.945702] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[    0.945702] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[    0.945703] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[    0.945704] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[    0.945705] pci_bus 0000:00: resource 20 [mem 0x80000000-0xdfffffff window]
[    0.945705] pci_bus 0000:00: resource 21 [mem 0xfc000000-0xfc00ffff window]
[    0.945706] pci_bus 0000:00: resource 22 [mem 0xfd000000-0xfe7fffff window]
[    0.945707] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.945708] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[    0.945709] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.945709] pci_bus 0000:02: resource 1 [mem 0xdf200000-0xdf2fffff]
[    0.945710] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.945711] pci_bus 0000:03: resource 1 [mem 0xdf100000-0xdf1fffff]
[    0.945883] NET: Registered protocol family 2
[    0.946064] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.946324] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.946406] TCP: Hash tables configured (established 262144 bind 65536)
[    0.946431] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[    0.946502] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[    0.946591] NET: Registered protocol family 1
[    0.946603] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.946853] pci 0000:03:00.0: set MSI_INTX_DISABLE_BUG flag
[    0.946856] PCI: CLS 64 bytes, default 64
[    0.946887] Unpacking initramfs...
[    1.250066] Freeing initrd memory: 20164K
[    1.250069] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.250070] software IO TLB [mem 0x715fc000-0x755fc000] (64MB) mapped at [ffffa04f715fc000-ffffa04f755fbfff]
[    1.250407] audit: initializing netlink subsys (disabled)
[    1.250419] audit: type=2000 audit(1508600433.236:1): initialized
[    1.250850] workingset: timestamp_bits=40 max_order=23 bucket_order=0
[    1.250971] zbud: loaded
[    1.251697] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.251741] io scheduler noop registered
[    1.251742] io scheduler deadline registered
[    1.251753] io scheduler cfq registered (default)
[    1.252297] aer 0000:00:1c.0:pcie002: service driver aer loaded
[    1.252312] aer 0000:00:1c.3:pcie002: service driver aer loaded
[    1.252324] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    1.252325] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    1.252326] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[    1.252332] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[    1.252333] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    1.252335] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
[    1.252340] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
[    1.252341] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[    1.252343] pcie_pme 0000:00:1c.3:pcie001: service driver pcie_pme loaded
[    1.252349] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.252353] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.252362] efifb: probing for efifb
[    1.252381] efifb: framebuffer at 0xb0000000, using 8128k, total 8128k
[    1.252381] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.252382] efifb: scrolling: redraw
[    1.252383] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.255734] Console: switching to colour frame buffer device 240x67
[    1.259002] fb0: EFI VGA frame buffer device
[    1.259007] intel_idle: MWAIT substates: 0x11142120
[    1.259008] intel_idle: v0.4.1 model 0x9E
[    1.259348] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.259520] GHES: HEST is not enabled!
[    1.259559] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.259927] Linux agpgart interface v0.103
[    1.259994] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.259995] AMD IOMMUv2 functionality not available on this system
[    1.260514] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.264499] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.264501] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.264597] mousedev: PS/2 mouse device common for all mice
[    1.264634] rtc_cmos 00:04: RTC can wake from S4
[    1.264999] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    1.265078] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.265082] intel_pstate: Intel P-state driver initializing
[    1.265093] intel_pstate: Disabling energy efficiency optimization
[    1.265602] intel_pstate: HWP enabled
[    1.265780] ledtrig-cpu: registered to indicate activity on CPUs
[    1.266164] NET: Registered protocol family 10
[    1.266356] mip6: Mobile IPv6
[    1.266357] NET: Registered protocol family 17
[    1.266358] mpls_gso: MPLS GSO support
[    1.266554] microcode: sig=0x906e9, pf=0x20, revision=0x5e
[    1.266721] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.266815] registered taskstats version 1
[    1.266828] zswap: loaded using pool lzo/zbud
[    1.266988] ima: No TPM chip found, activating TPM-bypass!
[    1.267815] rtc_cmos 00:04: setting system clock to 2017-10-21 15:40:33 UTC (1508600433)
[    1.267866] PM: Hibernation image not present or could not be loaded.
[    1.268633] Freeing unused kernel memory: 1396K
[    1.268633] Write protecting the kernel read-only data: 12288k
[    1.269061] Freeing unused kernel memory: 1980K
[    1.270503] Freeing unused kernel memory: 1240K
[    1.273589] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.274844] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.308686] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.308739] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.308743] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.308749] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.309212] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.309240] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.310061] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.310086] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.310093] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.310240] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.328824] hidraw: raw HID events driver (C) Jiri Kosina
[    1.345021] thermal LNXTHERM:00: registered as thermal_zone0
[    1.345021] ACPI: Thermal Zone [THRM] (50 C)
[    1.345213] thermal LNXTHERM:01: registered as thermal_zone1
[    1.345214] ACPI: Thermal Zone [TZ00] (28 C)
[    1.345301] thermal LNXTHERM:02: registered as thermal_zone2
[    1.345301] ACPI: Thermal Zone [TZ01] (30 C)
[    1.346893] SCSI subsystem initialized
[    1.346941] ACPI: bus type USB registered
[    1.346960] usbcore: registered new interface driver usbfs
[    1.346968] usbcore: registered new interface driver hub
[    1.346995] usbcore: registered new device driver usb
[    1.348211] libata version 3.00 loaded.
[    1.348293] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.348297] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.349522] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00109810
[    1.349525] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.349633] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.349633] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.349634] usb usb1: Product: xHCI Host Controller
[    1.349635] usb usb1: Manufacturer: Linux 4.9.0-4-amd64 xhci-hcd
[    1.349635] usb usb1: SerialNumber: 0000:00:14.0
[    1.349741] hub 1-0:1.0: USB hub found
[    1.349763] hub 1-0:1.0: 16 ports detected
[    1.350096] alx 0000:03:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [4c:cc:6a:dc:d5:4a]
[    1.350616] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.350618] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.350652] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.350653] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.350654] usb usb2: Product: xHCI Host Controller
[    1.350655] usb usb2: Manufacturer: Linux 4.9.0-4-amd64 xhci-hcd
[    1.350655] usb usb2: SerialNumber: 0000:00:14.0
[    1.350758] hub 2-0:1.0: USB hub found
[    1.350775] hub 2-0:1.0: 8 ports detected
[    1.351572] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.351607] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.353486] ahci 0000:00:17.0: version 3.0
[    1.354125] AVX2 version of gcm_enc/dec engaged.
[    1.354125] AES CTR mode by8 optimization enabled
[    1.363805] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0xd impl SATA mode
[    1.363807] ahci 0000:00:17.0: flags: 64bit ncq sntf pm led clo only pio slum part ems deso sadm sds apst
[    1.380357] alx 0000:03:00.0 enp3s0: renamed from eth0
[    1.391480] scsi host0: ahci
[    1.391834] scsi host1: ahci
[    1.392069] scsi host2: ahci
[    1.392263] scsi host3: ahci
[    1.392296] ata1: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b100 irq 124
[    1.392297] ata2: DUMMY
[    1.392298] ata3: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b200 irq 124
[    1.392299] ata4: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b280 irq 124
[    1.674809] usb 1-10: new full-speed USB device number 2 using xhci_hcd
[    1.703061] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.703094] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.703128] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.703564] ata1.00: supports DRM functions and may not be fully accessible
[    1.703872] ata4.00: ATA-9: WDC WD10JPVX-22JC3T0, 01.01A01, max UDMA/133
[    1.703875] ata4.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.704483] ata1.00: ATA-10: Crucial_CT525MX300SSD4,  M0CR060, max UDMA/133
[    1.704488] ata1.00: 1025610768 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.704863] ata4.00: configured for UDMA/133
[    1.705540] ata1.00: supports DRM functions and may not be fully accessible
[    1.705896] ata3.00: ATAPI: HL-DT-ST DVDRAM GUD0N, 1.00, max UDMA/133
[    1.707132] ata1.00: configured for UDMA/133
[    1.707704] scsi 0:0:0:0: Direct-Access     ATA      Crucial_CT525MX3 R060 PQ: 0 ANSI: 5
[    1.709287] ata3.00: configured for UDMA/133
[    1.750769] scsi 2:0:0:0: CD-ROM            HL-DT-ST DVDRAM GUD0N     1.00 PQ: 0 ANSI: 5
[    1.765085] scsi 3:0:0:0: Direct-Access     ATA      WDC WD10JPVX-22J 1A01 PQ: 0 ANSI: 5
[    1.810249] ata1.00: Enabling discard_zeroes_data
[    1.810266] sd 0:0:0:0: [sda] 1025610768 512-byte logical blocks: (525 GB/489 GiB)
[    1.810327] sd 0:0:0:0: [sda] Write Protect is off
[    1.810331] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.810347] sd 3:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.810350] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.810355] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    1.810417] sd 3:0:0:0: [sdb] Write Protect is off
[    1.810422] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.810448] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.810724] ata1.00: Enabling discard_zeroes_data
[    1.812487]  sda: sda1 sda2 sda3
[    1.813237] ata1.00: Enabling discard_zeroes_data
[    1.813332] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.820068] usb 1-10: New USB device found, idVendor=8087, idProduct=0aa7
[    1.820071] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.822247]  sdb:
[    1.822555] sd 3:0:0:0: [sdb] Attached SCSI disk
[    1.826179] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.826183] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.826490] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    1.938740] usb 1-12: new high-speed USB device number 3 using xhci_hcd
[    2.016256] random: fast init done
[    2.035894] device-mapper: uevent: version 1.0.3
[    2.035949] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.049030] psmouse serio1: synaptics: queried max coordinates: x [..5656], y [..4728]
[    2.078057] psmouse serio1: synaptics: queried min coordinates: x [1284..], y [1128..]
[    2.079184] usb 1-12: New USB device found, idVendor=0bda, idProduct=0129
[    2.079187] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.079189] usb 1-12: Product: USB2.0-CRW
[    2.079191] usb 1-12: Manufacturer: Generic
[    2.079192] usb 1-12: SerialNumber: 20100201396000000
[    2.083309] usbcore: registered new interface driver rtsx_usb
[    2.134283] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.2, id: 0x1e2b1, caps: 0xf00323/0x840300/0x26800/0x0, board id: 3163, fw id: 2286728
[    2.170366] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
[    2.278810] tsc: Refined TSC clocksource calibration: 2807.999 MHz
[    2.278824] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2879c523a63, max_idle_ns: 440795252908 ns
[    3.303108] clocksource: Switched to clocksource tsc
[   31.795031] random: crng init done
[   37.712730] NET: Registered protocol family 38
[   37.920785] PM: Starting manual resume from disk
[   37.920788] PM: Hibernation image partition 254:2 present
[   37.920788] PM: Looking for hibernation image.
[   37.920914] PM: Image not found (code -22)
[   37.920915] PM: Hibernation image not present or could not be loaded.
[   38.053097] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   38.177479] ip_tables: (C) 2000-2006 Netfilter Core Team
[   38.231090] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[   38.231237] systemd[1]: Detected architecture x86-64.
[   38.231409] systemd[1]: Set hostname to <laptop-tarach>.
[   38.286666] systemd[1]: Listening on fsck to fsckd communication Socket.
[   38.286817] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   38.286839] systemd[1]: Listening on LVM2 poll daemon socket.
[   38.286859] systemd[1]: Listening on Journal Socket.
[   38.286899] systemd[1]: Listening on Journal Audit Socket.
[   38.286912] systemd[1]: Listening on Syslog Socket.
[   38.287540] systemd[1]: Created slice System Slice.
[   38.310584] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   38.316317] lp: driver loaded but no devices found
[   38.318093] ppdev: user-space parallel port driver
[   38.327235] systemd-journald[341]: Received request to flush runtime journal from PID 1
[   38.388732] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:49/PNP0C09:01/PNP0C0D:00/input/input3
[   38.388929] ACPI: Lid Switch [LID0]
[   38.388981] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[   38.388983] ACPI: Sleep Button [SLPB]
[   38.389026] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[   38.389027] ACPI: Power Button [PWRB]
[   38.389066] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[   38.389067] ACPI: Power Button [PWRF]
[   38.391645] tpm_crb MSFT0101:00: can't request region for resource [mem 0xfed40080-0xfed40fff]
[   38.391688] tpm_crb: probe of MSFT0101:00 failed with error -16
[   38.399385] wmi: Mapper loaded
[   38.404759] Bluetooth: Core ver 2.22
[   38.404767] NET: Registered protocol family 31
[   38.404767] Bluetooth: HCI device and connection manager initialized
[   38.404769] Bluetooth: HCI socket layer initialized
[   38.404771] Bluetooth: L2CAP socket layer initialized
[   38.404777] Bluetooth: SCO socket layer initialized
[   38.407875] Bluetooth: HCI UART driver ver 2.3
[   38.407876] Bluetooth: HCI UART protocol H4 registered
[   38.407876] Bluetooth: HCI UART protocol BCSP registered
[   38.407876] Bluetooth: HCI UART protocol LL registered
[   38.407877] Bluetooth: HCI UART protocol ATH3K registered
[   38.407877] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   38.407909] Bluetooth: HCI UART protocol Intel registered
[   38.407926] Bluetooth: HCI UART protocol Broadcom registered
[   38.407926] Bluetooth: HCI UART protocol QCA registered
[   38.407927] Bluetooth: HCI UART protocol AG6XX registered
[   38.407927] Bluetooth: HCI UART protocol Marvell registered
[   38.443079] input: PC Speaker as /devices/platform/pcspkr/input/input7
[   38.443127] EFI Variables Facility v0.08 2004-May-17
[   38.479043] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   38.479330] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   38.479485] sr 2:0:0:0: Attached scsi generic sg1 type 5
[   38.479515] sd 3:0:0:0: Attached scsi generic sg2 type 0
[   38.479577] iTCO_vendor_support: vendor-support=0
[   38.480842] usbcore: registered new interface driver btusb
[   38.481014] pstore: using zlib compression
[   38.481023] pstore: Registered efi as persistent store backend
[   38.481279] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   38.482528] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   38.482654] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[   38.482753] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   38.486537] [drm] Initialized
[   38.490465] Bluetooth: hci0: read Intel version: 370810225019140f00
[   38.491376] bluetooth hci0: firmware: failed to load intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq (-2)
[   38.491401] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq failed with error -2
[   38.491403] Bluetooth: hci0 failed to open Intel firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq(-2)
[   38.491435] bluetooth hci0: firmware: failed to load intel/ibt-hw-37.8.bseq (-2)
[   38.491463] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.bseq failed with error -2
[   38.491464] Bluetooth: hci0 failed to open default Intel fw file: intel/ibt-hw-37.8.bseq
[   38.500296] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   38.508950] intel_rapl: Found RAPL domain package
[   38.508951] intel_rapl: Found RAPL domain core
[   38.508952] intel_rapl: Found RAPL domain uncore
[   38.508953] intel_rapl: Found RAPL domain dram
[   38.509979] Intel(R) Wireless WiFi driver for Linux
[   38.509979] Copyright(c) 2003- 2015 Intel Corporation
[   38.510006] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[   38.510212] iwlwifi 0000:02:00.0: firmware: failed to load iwlwifi-3168-26.ucode (-2)
[   38.510238] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-26.ucode failed with error -2
[   38.510245] iwlwifi 0000:02:00.0: firmware: failed to load iwlwifi-3168-25.ucode (-2)
[   38.510276] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-25.ucode failed with error -2
[   38.510283] iwlwifi 0000:02:00.0: firmware: failed to load iwlwifi-3168-24.ucode (-2)
[   38.510315] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-24.ucode failed with error -2
[   38.510321] iwlwifi 0000:02:00.0: firmware: failed to load iwlwifi-3168-23.ucode (-2)
[   38.510351] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-3168-23.ucode failed with error -2
[   38.512504] [drm] Memory usable by graphics device = 4096M
[   38.512506] checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
[   38.512507] fb: switching to inteldrmfb from EFI VGA
[   38.512542] Console: switching to colour dummy device 80x25
[   38.512614] [drm] Replacing VGA console driver
[   38.516199] iwlwifi 0000:02:00.0: firmware: direct-loading firmware iwlwifi-3168-22.ucode
[   38.516392] iwlwifi 0000:02:00.0: loaded firmware version 22.361476.0 op_mode iwlmvm
[   38.518680] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   38.518681] [drm] Driver supports precise vblank timestamp query.
[   38.519844] MXM: GUID detected in BIOS
[   38.519875] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20160831/nsarguments-95)
[   38.519933] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20160831/nsarguments-95)
[   38.519984] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20160831/nsarguments-95)
[   38.520172] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[   38.520176] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[   38.520177] nouveau: detected PR support, will not use DSM
[   38.520201] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[   38.520280] nouveau 0000:01:00.0: unknown chipset (137000a1)
[   38.520289] nouveau: probe of 0000:01:00.0 failed with error -12
[   38.526560] input: MSI WMI hotkeys as /devices/virtual/input/input8
[   38.526946] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   38.532859] [drm] GuC firmware load skipped
[   38.536224] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_01.bin (-2)
[   38.536234] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_01.bin failed with error -2
[   38.536236] i915 0000:00:02.0: Failed to load DMC firmware [https://01.org/linuxgraphics/intel-linux-graphics-firmwares], disabling runtime power management.
[   38.536741] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   38.537037] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[   38.537101] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[   38.537140] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:12/LNXVIDEO:01/input/input10
[   38.538290] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   38.538296] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[   38.542576] fbcon: inteldrmfb (fb0) is primary device
[   38.561090] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[   38.562690] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   38.562861] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   38.564122] ACPI: Battery Slot [BAT1] (battery present)
[   38.565713] ACPI: AC Adapter [ADP1] (off-line)
[   38.609866] Adding 33468412k swap on /dev/mapper/laptop--tarach--vg-swap_1.  Priority:-1 extents:1 across:33468412k SSFS
[   38.611821] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   38.616048] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[   38.662554] EXT4-fs (sda2): mounting ext2 file system using the ext4 subsystem
[   38.670513] EXT4-fs (sda2): mounted filesystem without journal. Opts: (null)
[   38.674535] nvidia: loading out-of-tree module taints kernel.
[   38.674545] nvidia: module license 'NVIDIA' taints kernel.
[   38.674546] Disabling lock debugging due to kernel taint
[   38.697484] nvidia-nvlink: Nvlink Core is being initialized, major device number 246
[   38.698288] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  384.90  Tue Sep 19 19:17:35 PDT 2017 (using threaded interrupts)
[   38.708059] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  384.90  Tue Sep 19 17:05:19 PDT 2017
[   38.712086] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   39.783099] [drm] RC6 on
[   39.832416] Console: switching to colour frame buffer device 240x67
[   39.861664] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   39.917173] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC898: line_outs=2 (0x15/0x1b/0x0/0x0/0x0) type:speaker
[   39.917176] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   39.917179] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[   39.917181] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   39.917182] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[   39.917184] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   39.917187] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[   39.917189] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   39.953129] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[   39.953351] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[   39.953484] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[   39.953602] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   39.953733] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   39.996791] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   39.996794] Bluetooth: BNEP filters: protocol multicast
[   39.996800] Bluetooth: BNEP socket layer initialized
[   40.232896] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[   40.233885] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[   40.241557] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   40.242743] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.242917] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.276758] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.276926] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.292693] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   40.302693] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.302863] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.336717] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.336886] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled
[   40.352550] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   40.460092] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   44.875055] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[   44.929623] wlp2s0: authenticate with 4c:09:b4:1b:b7:c6
[   44.935662] wlp2s0: send auth to 4c:09:b4:1b:b7:c6 (try 1/3)
[   44.995279] wlp2s0: authenticated
[   44.998794] wlp2s0: associate with 4c:09:b4:1b:b7:c6 (try 1/3)
[   45.003288] wlp2s0: RX AssocResp from 4c:09:b4:1b:b7:c6 (capab=0x431 status=0 aid=4)
[   45.005173] wlp2s0: associated
[   45.005245] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[   46.559355] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   46.560674] Bridge firewalling registered
[   46.568390] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[   46.657394] Initializing XFRM netlink socket
[   46.663545] Netfilter messages via NETLINK v0.30.
[   46.664705] ctnetlink v0.93: registering with nfnetlink.
[   46.692800] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   63.570798] usb 1-8: new high-speed USB device number 4 using xhci_hcd
[   63.712175] usb 1-8: New USB device found, idVendor=1b1c, idProduct=1a09
[   63.712180] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   63.712182] usb 1-8: Product: Voyager GT 3.0
[   63.712185] usb 1-8: Manufacturer: Corsair
[   63.712187] usb 1-8: SerialNumber: 23031108350000040259
[   63.728618] usb-storage 1-8:1.0: USB Mass Storage device detected
[   63.728877] scsi host4: usb-storage 1-8:1.0
[   63.729138] usbcore: registered new interface driver usb-storage
[   63.731465] usbcore: registered new interface driver uas
[   64.745462] scsi 4:0:0:0: Direct-Access     Corsair  Voyager GT 3.0   1.00 PQ: 0 ANSI: 4
[   64.746551] sd 4:0:0:0: Attached scsi generic sg3 type 0
[   64.746755] sd 4:0:0:0: [sdc] 62607360 512-byte logical blocks: (32.1 GB/29.9 GiB)
[   64.746914] sd 4:0:0:0: [sdc] Write Protect is off
[   64.746920] sd 4:0:0:0: [sdc] Mode Sense: bf 00 00 00
[   64.747145] sd 4:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   64.748516]  sdc: sdc1
[   64.749506] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[   79.079983] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Re: Zainstalowałem sterowniki nvidia i "Oh no something went wrong"
Odinstaluj - prawdopodobnie w ten sposób:
#   NVIDIA-Linux-x86_64-384.90.run --uninstall
Zainstaluj zgodnie z wiki:
https://wiki.debian.org/NvidiaGraphicsDrivers
Sterownik w wersji 375.82 obsługuje tą kartę:
http://www.nvidia.com/Download/driverRe ... 0911/en-us .
Na przyszłość - zakładając wątek podaj szczegóły na temat używanej gałęzi (wersji) Debiana i używanego sprzętu.
starach
Niestety nie było tam żadnej metody odinstalowywującej.
Zreinstalowałem system po czym wykonując czynność opisane w linku który wysłałeś ( https://wiki.debian.org/NvidiaGraphicsD ... ion_375.66 ),
zainstalowałem sterowniki. Efekt identyczny ... Usunąłem sterowniki nvidia tak jak jest to opisane na w/w stronie i co prawda dostaję się do ekranu logowania, ale nie mogę się zalogować. Po wpisaniu poprawnego hasła ekran na < 1 sekundę gaśnie i pojawia się ponownie ekran logowania. Hasło jest poprawne bo kiedy wpiszę błędne dostaje komunikat że jest ono błędne... znowu muszę reinstalować system... wyć się chce...
Sprawdź logi i inne konto użytkownika.
starach
Zainstalowałem system raz jeszcze, ale bez szyfrowania dysku i zrobiłem kopię zapasową.
Potem spróbowałem zainstalować sterowniki ponownie według obu przepisów z identycznymi rezultatami.
Jakieś pomysły?
Np. kiedy nie mogę się zalogować ( opisane wyżej ) gdzie powinienem szukać informacji o przyczynie w którym logu?
saturno
Post autor: saturno »
/var/log/nazwa menedżera logowania, np.:
/var/log/kdm.log
/var/log/kdm.log.1
starach
Dziwne wydawało mi się że odpisywałem na ten temat.
Zadziałał Bumblebee. vblank_mode=0 optirun glmark2 działa świetnie :)
Dzięki
Oznacz zatem wątek jako rozwiązany zgodnie z regulaminem forum.
