Potwierdzam, /etc/rsyslog.conf includuje te konfiguracje:
# /etc/rsyslog.conf Configuration file for rsyslog.
# For more information see
# /usr/share/doc/rsyslog-doc/html/rsyslog_conf.html
# Default logging rules can be found in /etc/rsyslog.d/50-default.conf
#### MODULES ####
module(load="imuxsock") # provides support for local system logging
#module(load="immark") # provides --MARK-- message capability
# provides UDP syslog reception
#module(load="imudp")
#input(type="imudp" port="514")
# provides TCP syslog reception
#module(load="imtcp")
#input(type="imtcp" port="514")
# provides kernel logging support and enable non-kernel klog messages
module(load="imklog" permitnonkernelfacility="on")
#### GLOBAL DIRECTIVES ####
# Use traditional timestamp format.
# To enable high precision timestamps, comment out the following line.
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
# Filter duplicated messages
$RepeatedMsgReduction on
# Set the default permissions for all log files.
$FileOwner syslog
$FileGroup adm
$FileCreateMode 0640
$DirCreateMode 0755
$Umask 0022
$PrivDropToUser syslog
$PrivDropToGroup syslog
# Where to place spool and state files
$WorkDirectory /var/spool/rsyslog
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
if $msg contains 'input1,iptables denied,output1,ipT:' then -/var/log/firewall
#if $msg contains 'input1' then -/var/log/firewall
#if $msg contains 'iptables denied' then -/var/log/firewall
#if $msg contains 'output1' then -/var/log/firewall
if $msg contains 'ipT4' then -/var/log/iptables.log
Przepraszam ale nie rozumiem:
Plik musi być ładowany przed regułami
auth,authpriv.*/var/log/auth.log
Co mam sprawdzic, zrobic?
Ps. Zastanawiam sie czy jezeli string "ipT4" w /etc/rsyslog.conf jest tylko czescia suffiksa uzytego w skrypcie konfiguracji regol iptables to wystarczy do
dzialania? Czy tez musi byc uzyty caly suffix?
e:
#!/bin/sh
conntrack -F
iptables -P INPUT DROP
iptables -P FORWARD DROP
iptables -P OUTPUT ACCEPT
iptables -F
iptables -X
iptables -A INPUT -m limit --limit 2/min -j LOG --log-prefix "ipT4 DROP INPUT: "
iptables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -A INPUT -m conntrack --ctstate INVALID -m limit --limit 2/min -j LOG --log-prefix "ipT4 DROP INVALID IN: "
iptables -A INPUT -m conntrack --ctstate INVALID -j DROP
iptables -A FORWARD -m conntrack --ctstate INVALID -j LOG --log-prefix "ipT4 DROP INVALID FWD: "
iptables -A FORWARD -m conntrack --ctstate INVALID -j DROP
iptables -I OUTPUT -m state -p tcp --state NEW -i eth0 -m limit --limit 1/m --limit-burst 1 -j LOG --log-uid --log-prefix "ipT4 Outbound Connection: "
iptables -A OUTPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
iptables -A OUTPUT -m conntrack --ctstate INVALID -m limit --limit 2/min -j LOG --log-prefix "ipT4 DROP INVALID OUT: "
iptables -A OUTPUT -m conntrack --ctstate INVALID -j DROP
ip6tables -F
ip6tables -X
ip6tables -P INPUT DROP
ip6tables -P FORWARD DROP
ip6tables -P OUTPUT ACCEPT
ip6tables -A INPUT -i lo -j ACCEPT
ip6tables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
