debian i redmine
aksnet
debian i redmine
Post autor: aksnet »
instalacja redmine zrobiona zgodnie z instrukcją:
http://www.ubuntu-pomoc.org/instalacja-redmine/
Próba uruchomienia redmine kończy się komunikatem o błędach:
(plik redmine/config/database.yml istnieje z prawami do odczytu dla wszystkich)
w czym problem?
Cannot load `Rails.application.database_configuration`:
Could not load database configuration. No such file -  (RuntimeError)
  /usr/lib/ruby/vendor_ruby/rails/application/configuration.rb:105:in `database_configuration'
  /usr/lib/ruby/vendor_ruby/active_record/railtie.rb:128:in `block (2 levels) in <class:Railtie>'
  /usr/lib/ruby/vendor_ruby/active_support/lazy_load_hooks.rb:38:in `instance_eval'
  /usr/lib/ruby/vendor_ruby/active_support/lazy_load_hooks.rb:38:in `execute_hook'
  /usr/lib/ruby/vendor_ruby/active_support/lazy_load_hooks.rb:28:in `block in on_load'
  /usr/lib/ruby/vendor_ruby/active_support/lazy_load_hooks.rb:27:in `each'
  /usr/lib/ruby/vendor_ruby/active_support/lazy_load_hooks.rb:27:in `on_load'
  /usr/lib/ruby/vendor_ruby/active_record/railtie.rb:118:in `block in <class:Railtie>'
  /usr/lib/ruby/vendor_ruby/rails/initializable.rb:30:in `instance_exec'
  /usr/lib/ruby/vendor_ruby/rails/initializable.rb:30:in `run'
  /usr/lib/ruby/vendor_ruby/rails/initializable.rb:55:in `block in run_initializers'
  /usr/lib/ruby/2.1.0/tsort.rb:226:in `block in tsort_each'
  /usr/lib/ruby/2.1.0/tsort.rb:348:in `block (2 levels) in each_strongly_connected_component'
  /usr/lib/ruby/2.1.0/tsort.rb:427:in `each_strongly_connected_component_from'
  /usr/lib/ruby/2.1.0/tsort.rb:347:in `block in each_strongly_connected_component'
  /usr/lib/ruby/2.1.0/tsort.rb:345:in `each'
  /usr/lib/ruby/2.1.0/tsort.rb:345:in `call'
  /usr/lib/ruby/2.1.0/tsort.rb:345:in `each_strongly_connected_component'
  /usr/lib/ruby/2.1.0/tsort.rb:224:in `tsort_each'
  /usr/lib/ruby/2.1.0/tsort.rb:205:in `tsort_each'
  /usr/lib/ruby/vendor_ruby/rails/initializable.rb:54:in `run_initializers'
  /usr/lib/ruby/vendor_ruby/rails/application.rb:300:in `initialize!'
  /usr/share/redmine/config/environment.rb:14:in `<top (required)>'
  config.ru:3:in `require'
  config.ru:3:in `block in <main>'
  /usr/lib/ruby/vendor_ruby/rack/builder.rb:55:in `instance_eval'
  /usr/lib/ruby/vendor_ruby/rack/builder.rb:55:in `initialize'
  config.ru:1:in `new'
  config.ru:1:in `<main>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `eval'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `preload_app'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:158:in `<module:App>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:29:in `<module:PhusionPassenger>'
  /usr/share/passenger/helper-scripts/rack-preloader.rb:28:in `<main>'
Error ID
    dd4e0cbe
Re: debian i redmine
Zawsze mnie zastanawiało dlaczego ludzie sięgają po jakieś dziwne poradniki poradniki zamiast sprawdzić na stronie projektu...
http://www.redmine.org/projects/redmine ... lPassenger
