[+] Fail2ban nie startuje po aktualizacji Debian 8 Jessi do 9 Stretch
romel
Post autor: romel »
Po aktualizacji Debian 8 do 9 fail2ban nie startuje.
Przeinstalowałem ale dalej nic to nie daje, reinstalacja:
apt-get remove fail2ban
apt-get purge fail2ban
apt-get install fail2ban
niestety instalacja nie zakończyła się sukcesem:
Job for fail2ban.service failed because the control process exited with error code.
See "systemctl status fail2ban.service" and "journalctl -xe" for details.
invoke-rc.d: initscript fail2ban, action "start" failed.
● fail2ban.service - Fail2Ban Service
   Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Mon 2017-07-24 10:14:33 CEST; 12ms ago
     Docs: man:fail2ban(1)
  Process: 24483 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
lip 24 10:14:33 debian systemd[1]: fail2ban.service: Failed with result 'ex…de'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: błąd przetwarzania pakietu fail2ban (--configure):
 podproces zainstalowany skrypt post-installation zwrócił kod błędu 1
 fail2ban
a próba uruchomienia kończy się tak:
   Active: failed (Result: exit-code) since Mon 2017-07-24 09:04:20 CEST; 1min 2s ago
  Process: 23038 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
lip 24 09:04:20 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
lip 24 09:04:20 debian systemd[1]: Failed to start Fail2Ban Service.
lip 24 09:04:20 debian systemd[1]: fail2ban.service: Unit entered failed state.
lip 24 09:04:20 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
lip 24 09:04:20 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
lip 24 09:04:20 debian systemd[1]: Stopped Fail2Ban Service.
lip 24 09:04:20 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
Trochę głupio tak zostać bez obrony fail2ban - w zasadzie co 2-3 dni odcinał mi natrętów próbujących brute forca itp.
Po odinstalowaniu usunąłem wszystkie pliki konfiguracyjne, tak żeby nowa instalacja była na czysto - ale nic to nie daje.
Może ma ktoś pomysł co zrobić.
Ostatnio zmieniony 08 sierpnia 2017, 12:07 przez romel, łącznie zmieniany 1 raz.
Re: Fail2ban nie startuje po aktualizacji Debian 8 Jessi do 9 Stretch
Odpal z palca i zobacz co wypluje, ewentualnie odpal ze strace.
romel
Post autor: romel »
Ręcznie uruchomiłem tak: /usr/bin/fail2ban-client start
dostałem komunikat: ERROR Server already running
i rzeczywiście jak sprawdzam logi fail2ban to działa - są wpisy, są bany.
Natomiast jest jakiś problem ponieważ przy aktualizacji systemu wypisuje 1 pakiet fail2ban nie jest zainstalowany poprawnie.
Wygląda na to że skrypt startowy fail2ban w init.d ma problem, po sprawdzeniu statusu /etc/init.d/fail2ban status sypie błędami:
~/etc/init.d# ./fail2ban status
   Active: failed (Result: exit-code) since Tue 2017-08-08 07:52:54 CEST; 18min ago
  Process: 23415 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
sie 08 07:52:54 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:52:54 debian systemd[1]: Failed to start Fail2Ban Service.
sie 08 07:52:54 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:52:54 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:52:54 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:52:54 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 07:52:54 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
Może Debian 9 potrzebuje nowego zmienionego skryptu startowego, tylko jak ten nowy wygenerować.
romel pisze: 08 sierpnia 2017, 08:13 ...
Pokaż co tam wypisuje.
romel
Post autor: romel »
Zaczynam od: apt-get update
potem: apt-get upgrade
i dostaje:
Budowanie drzewa zależności
Obliczanie aktualizacji... Gotowe
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
1 nie w pełni zainstalowanych lub usuniętych.
Po tej operacji zostanie dodatkowo użyte 0 B miejsca na dysku.
Kontynuować? [T/n] T
Konfigurowanie pakietu fail2ban (0.9.6-2) ...
insserv: warning: script 'mydns' missing LSB tags and overrides
   Active: activating (auto-restart) (Result: exit-code) since Tue 2017-08-08 09:34:07 CEST; 13ms ago
  Process: 30696 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
sie 08 09:34:07 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
 fail2ban
Dorzuć sobie do tego skryptu mydns te LSB https://wiki.debian.org/LSBInitScripts
romel
Post autor: romel »
Dzięki, info o brakującym LSB w mydns zniknęło.
Fail2ban nadal wywala komunikaty mimo że działa...
romel
Post autor: romel »
   Active: failed (Result: exit-code) since Tue 2017-08-08 09:59:03 CEST; 56min ago
  Process: 31642 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
sie 08 09:59:03 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:59:03 debian systemd[1]: Failed to start Fail2Ban Service.
sie 08 09:59:03 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:59:03 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:59:03 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:59:03 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:59:03 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
i
journalctl -xe - tutaj jest tego sporo, wywaliłem te części gdzie było info o ukończonym poprawnym uruchomieniu, zostawiłem wpisy dotyczące fail2ban, ale i tak jest tego dużo:
-- Jednostka UNIT rozpoczęła uruchamianie.
sie 08 07:49:50 debian systemd[22853]: Received SIGRTMIN+24 from PID 22862 (kill).
sie 08 07:49:50 debian systemd[1]: Stopped User Manager for UID 0.
-- Subject: Ukończono wyłączanie jednostki user@0.service
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Jednostka user@0.service ukończyła wyłączanie.
sie 08 07:49:50 debian systemd[1]: Removed slice User Slice of root.
-- Subject: Ukończono wyłączanie jednostki user-0.slice
-- Jednostka user-0.slice ukończyła wyłączanie.
sie 08 07:49:50 debian udev-acl.ck[22864]: g_slice_set_config: assertion 'sys_page_size == 0' failed
sie 08 07:49:50 debian console-kit-daemon[2302]: missing action
sie 08 07:49:50 debian console-kit-daemon[2302]: console-kit-daemon[2302]: GLib-CRITICAL: Source ID 1240 was not found when attempting to remove it
sie 08 07:49:50 debian console-kit-daemon[2302]: GLib-CRITICAL: Source ID 1240 was not found when attempting to remove it
sie 08 07:50:25 debian systemd[1]: Reloading.
sie 08 07:50:25 debian systemd[1]: apt-daily-upgrade.timer: Adding 15min 42.602918s random time.
sie 08 07:50:25 debian systemd[1]: apt-daily.timer: Adding 5h 36min 57.647669s random time.
sie 08 07:50:25 debian systemd[1]: apt-daily-upgrade.timer: Adding 41min 56.525239s random time.
sie 08 07:50:25 debian systemd[1]: apt-daily.timer: Adding 3h 32min 18.516886s random time.
sie 08 07:50:26 debian systemd[1]: Starting Fail2Ban Service...
-- Subject: Rozpoczęto uruchamianie jednostki fail2ban.service
-- Jednostka fail2ban.service rozpoczęła uruchamianie.
sie 08 07:50:26 debian fail2ban-client[23236]: ERROR  Server already running
sie 08 07:50:26 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:50:26 debian systemd[1]: Failed to start Fail2Ban Service.
-- Subject: Jednostka fail2ban.service się nie powiodła
-- Jednostka fail2ban.service się nie powiodła.
-- Wynik: failed.
sie 08 07:50:26 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:50:26 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:50:26 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:50:26 debian systemd[1]: Stopped Fail2Ban Service.
-- Subject: Ukończono wyłączanie jednostki fail2ban.service
-- Jednostka fail2ban.service ukończyła wyłączanie.
sie 08 07:50:26 debian fail2ban-client[23240]: ERROR  Server already running
-- Wynik: failed.
sie 08 07:50:27 debian fail2ban-client[23248]: ERROR  Server already running
sie 08 07:50:27 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:50:27 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 07:50:27 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:50:27 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:50:27 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:50:27 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 07:50:27 debian systemd[1]: Starting Fail2Ban Service...
sie 08 07:50:27 debian fail2ban-client[23252]: ERROR  Server already running
-- Wynik: failed.
sie 08 07:50:28 debian fail2ban-client[23254]: ERROR  Server already running
sie 08 07:50:28 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:50:28 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 07:50:28 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:50:28 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:50:28 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:50:28 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 07:50:28 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
-- Wynik: failed.
sie 08 07:52:07 debian smbd[23303]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:07 debian dhcpd[31063]: Wrote 0 deleted host decls to leases file.
sie 08 07:52:07 debian dhcpd[31063]: Wrote 0 new dynamic host decls to leases file.
sie 08 07:52:07 debian dhcpd[31063]: Wrote 50 leases to leases file.
sie 08 07:52:07 debian dhcpd[31063]: DHCPREQUEST for 192.168.1.165 from 30:85:a9:96:30:bb (Stacja2012-i5) via eth0
sie 08 07:52:07 debian dhcpd[31063]: DHCPACK on 192.168.1.165 to 30:85:a9:96:30:bb (Stacja2012-i5) via eth0
sie 08 07:52:09 debian smbd[23304]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:10 debian smbd[23305]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:11 debian smbd[23306]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:12 debian smbd[23307]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:13 debian smbd[23308]: pam_unix(samba:session): session closed for user nobody
sie 08 07:52:51 debian systemd[1]: Reloading.
sie 08 07:52:51 debian systemd[1]: apt-daily-upgrade.timer: Adding 12min 1.089643s random time.
sie 08 07:52:51 debian systemd[1]: apt-daily.timer: Adding 10h 21min 2.722494s random time.
sie 08 07:52:51 debian smbd[23384]: pam_unix(samba:session): session opened for user terminal_tomek by (uid=0)
sie 08 07:52:52 debian systemd[1]: apt-daily-upgrade.timer: Adding 33min 48.247668s random time.
sie 08 07:52:52 debian systemd[1]: apt-daily.timer: Adding 11h 16min 54.961541s random time.
sie 08 07:52:52 debian systemd[1]: Starting Fail2Ban Service...
sie 08 07:52:52 debian fail2ban-client[23402]: ERROR  Server already running
sie 08 07:52:52 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:52:52 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 07:52:52 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:52:52 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:52:52 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:52:52 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 07:52:53 debian fail2ban-client[23406]: ERROR  Server already running
sie 08 07:52:53 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 07:52:53 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 07:52:53 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 07:52:53 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 07:52:53 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 07:52:53 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 07:52:53 debian systemd[1]: Starting Fail2Ban Service...
sie 08 07:52:53 debian fail2ban-client[23410]: ERROR  Server already running
-- Wynik: failed.
sie 08 07:52:54 debian fail2ban-client[23412]: ERROR  Server already running
-- Wynik: failed.
sie 08 07:52:54 debian systemd[1]: Starting Fail2Ban Service...
sie 08 07:52:54 debian fail2ban-client[23415]: ERROR  Server already running
-- Wynik: failed.
-- Wynik: failed.
sie 08 07:53:21 debian smbd[25223]: pam_unix(samba:session): session closed for user nobody
sie 08 07:53:25 debian kernel: device-mapper: uevent: version 1.0.3
sie 08 07:53:25 debian kernel: device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
sie 08 07:53:34 debian kernel: SGI XFS with ACLs, security attributes, realtime, no debug enabled
sie 08 07:53:34 debian kernel: JFS: nTxBlock = 7885, nTxLock = 63082
sie 08 07:53:34 debian kernel: ntfs: driver 2.1.32 [Flags: R/O MODULE].
sie 08 07:53:34 debian kernel: QNX4 filesystem 0.2.3 registered.
-- Wynik uruchamiania: done.
sie 08 09:33:48 debian systemd[1]: apt-daily.timer: Adding 3h 18min 28.944309s random time.
sie 08 09:33:48 debian systemd[1]: apt-daily.timer: Adding 9h 36min 26.260240s random time.
sie 08 09:33:48 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:33:48 debian fail2ban-client[30590]: ERROR  Server already running
sie 08 09:33:48 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:33:48 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:33:48 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:33:48 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:33:48 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:33:48 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:33:49 debian fail2ban-client[30596]: ERROR  Server already running
sie 08 09:33:49 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:33:49 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:33:49 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:33:49 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:33:49 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:33:49 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:33:49 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:33:49 debian fail2ban-client[30602]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:33:50 debian fail2ban-client[30606]: ERROR  Server already running
sie 08 09:33:50 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:33:50 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:33:50 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:33:50 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:33:50 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:33:50 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:33:50 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:33:50 debian fail2ban-client[30608]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:33:50 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
-- Wynik: failed.
sie 08 09:34:06 debian systemd[1]: Reloading.
sie 08 09:34:07 debian systemd[1]: apt-daily-upgrade.timer: Adding 35min 9.109861s random time.
sie 08 09:34:07 debian systemd[1]: apt-daily.timer: Adding 1h 52min 47.196176s random time.
sie 08 09:34:07 debian systemd[1]: Reloading.
sie 08 09:34:07 debian systemd[1]: apt-daily-upgrade.timer: Adding 46min 46.024883s random time.
sie 08 09:34:07 debian systemd[1]: apt-daily.timer: Adding 9h 1min 2.310309s random time.
sie 08 09:34:07 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:34:07 debian fail2ban-client[30696]: ERROR  Server already running
sie 08 09:34:07 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:34:07 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:34:07 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:34:07 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:34:07 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:34:08 debian fail2ban-client[30703]: ERROR  Server already running
sie 08 09:34:08 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:34:08 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:34:08 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:34:08 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:34:08 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:34:08 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:34:08 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:34:08 debian fail2ban-client[30710]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:34:09 debian fail2ban-client[30712]: ERROR  Server already running
sie 08 09:34:09 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:34:09 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:34:09 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:34:09 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:34:09 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:34:09 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:34:09 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:34:09 debian fail2ban-client[30714]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:34:09 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
-- Wynik: failed.
sie 08 09:34:43 debian smbd[29924]: pam_unix(samba:session): session closed for user terminal_tomek
sie 08 09:34:56 debian smbd[30716]: pam_unix(samba:session): session closed for user nobody
sie 08 09:39:01 debian CRON[30788]: pam_unix(cron:session): session opened for user root by (uid=0)
sie 08 09:39:01 debian CRON[30789]: pam_unix(cron:session): session opened for user root by (uid=0)
sie 08 09:39:01 debian CRON[30790]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
sie 08 09:39:01 debian CRON[30791]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
sie 08 09:39:01 debian CRON[30788]: pam_unix(cron:session): session closed for user root
sie 08 09:39:02 debian CRON[30789]: pam_unix(cron:session): session closed for user root
sie 08 09:39:11 debian systemd[1]: Starting Clean php session files...
-- Subject: Rozpoczęto uruchamianie jednostki phpsessionclean.service
-- Jednostka phpsessionclean.service rozpoczęła uruchamianie.
sie 08 09:39:11 debian systemd[1]: Started Clean php session files.
-- Subject: Ukończono uruchamianie jednostki phpsessionclean.service
-- Jednostka phpsessionclean.service ukończyła uruchamianie.
sie 08 09:44:30 debian smbd[31024]: pam_unix(samba:session): session closed for user nobody
sie 08 09:49:23 debian systemd[1]: Starting mydns.service...
-- Subject: Rozpoczęto uruchamianie jednostki mydns.service
-- Jednostka mydns.service rozpoczęła uruchamianie.
sie 08 09:49:23 debian mydns[31148]: error loading gid for group `nobody'
sie 08 09:49:23 debian mydns[31148]: using gid 65534 from user `nobody'
sie 08 09:49:23 debian mydns[31148]: Error connecting to MySQL server at localhost: Access denied for user 'username'@'localhost' (using password: YES) (errno=0)
sie 08 09:49:23 debian mydns[31143]: Starting DNS server: mydns
sie 08 09:49:23 debian systemd[1]: mydns.service: Control process exited, code=exited status=1
sie 08 09:49:23 debian systemd[1]: Failed to start mydns.service.
-- Subject: Jednostka mydns.service się nie powiodła
-- Jednostka mydns.service się nie powiodła.
-- Wynik: failed.
sie 08 09:49:23 debian systemd[1]: mydns.service: Unit entered failed state.
sie 08 09:49:23 debian systemd[1]: mydns.service: Failed with result 'exit-code'.
sie 08 09:50:08 debian named[11399]: connection refused resolving 'allegro.hit.gemius.pl/A/IN': 62.168.111.101#53
sie 08 09:50:18 debian mydns[31207]: error loading gid for group `nobody'
sie 08 09:50:18 debian mydns[31207]: using gid 65534 from user `nobody'
sie 08 09:50:18 debian mydns[31207]: Error connecting to MySQL server at localhost: Access denied for user 'username'@'localhost' (using password: YES) (errno=0)
sie 08 09:50:20 debian mydns[31209]: error loading gid for group `nobody'
sie 08 09:50:20 debian mydns[31209]: using gid 65534 from user `nobody'
sie 08 09:50:20 debian mydns[31209]: Error connecting to MySQL server at localhost: Access denied for user 'username'@'localhost' (using password: YES) (errno=0)
sie 08 09:51:02 debian systemd[1]: Reloading.
sie 08 09:51:03 debian systemd[1]: apt-daily-upgrade.timer: Adding 42.890818s random time.
sie 08 09:51:03 debian systemd[1]: apt-daily.timer: Adding 4h 12min 29.309587s random time.
sie 08 09:51:03 debian systemd[1]: Reloading.
sie 08 09:51:03 debian systemd[1]: apt-daily-upgrade.timer: Adding 38min 33.462371s random time.
sie 08 09:51:03 debian systemd[1]: apt-daily.timer: Adding 9h 13min 53.977506s random time.
sie 08 09:51:03 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:51:03 debian fail2ban-client[31305]: ERROR  Server already running
sie 08 09:51:03 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:51:03 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:51:03 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:51:03 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:51:03 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:51:03 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:51:04 debian fail2ban-client[31311]: ERROR  Server already running
sie 08 09:51:04 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:51:04 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:51:04 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:51:04 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:51:04 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:51:04 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:51:04 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:51:04 debian fail2ban-client[31316]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:51:05 debian fail2ban-client[31321]: ERROR  Server already running
sie 08 09:51:05 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:51:05 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:51:05 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:51:05 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:51:05 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:51:05 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:51:05 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:51:05 debian fail2ban-client[31323]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:51:05 debian systemd[1]: fail2ban.service: Start request repeated too quickly.
-- Wynik: failed.
sie 08 09:51:50 debian smbd[31394]: pam_unix(samba:session): session closed for user nobody
sie 08 09:56:20 debian smbd[31448]: pam_unix(samba:session): session closed for user nobody
sie 08 09:56:21 debian smbd[28522]: pam_unix(samba:session): session closed for user terminal_ksiegowosc
sie 08 09:58:14 debian mydns[31535]: error loading gid for group `nobody'
sie 08 09:58:14 debian mydns[31535]: using gid 65534 from user `nobody'
sie 08 09:58:14 debian mydns[31535]: Error connecting to MySQL server at localhost: Access denied for user 'username'@'localhost' (using password: YES) (errno=0)
sie 08 09:59:00 debian systemd[1]: Reloading.
sie 08 09:59:01 debian systemd[1]: apt-daily-upgrade.timer: Adding 26min 41.989399s random time.
sie 08 09:59:01 debian systemd[1]: apt-daily.timer: Adding 8h 16min 45.948455s random time.
sie 08 09:59:01 debian systemd[1]: Reloading.
sie 08 09:59:01 debian systemd[1]: apt-daily-upgrade.timer: Adding 27min 58.348203s random time.
sie 08 09:59:01 debian systemd[1]: apt-daily.timer: Adding 1h 32min 4.754136s random time.
sie 08 09:59:01 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:59:01 debian fail2ban-client[31624]: ERROR  Server already running
sie 08 09:59:01 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:59:01 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:59:01 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:59:01 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:59:01 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:59:01 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:59:01 debian fail2ban-client[31631]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:59:02 debian systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
sie 08 09:59:02 debian systemd[1]: Stopped Fail2Ban Service.
sie 08 09:59:02 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:59:02 debian fail2ban-client[31638]: ERROR  Server already running
sie 08 09:59:02 debian systemd[1]: fail2ban.service: Control process exited, code=exited status=255
sie 08 09:59:02 debian systemd[1]: Failed to start Fail2Ban Service.
-- Wynik: failed.
sie 08 09:59:02 debian systemd[1]: fail2ban.service: Unit entered failed state.
sie 08 09:59:02 debian systemd[1]: fail2ban.service: Failed with result 'exit-code'.
sie 08 09:59:02 debian fail2ban-client[31640]: ERROR  Server already running
-- Wynik: failed.
sie 08 09:59:03 debian systemd[1]: Starting Fail2Ban Service...
sie 08 09:59:03 debian fail2ban-client[31642]: ERROR  Server already running
-- Wynik: failed.
-- Wynik: failed.
sie 08 09:59:24 debian mydns[31655]: error loading gid for group `nobody'
sie 08 09:59:24 debian mydns[31655]: using gid 65534 from user `nobody'
sie 08 09:59:24 debian mydns[31655]: Error connecting to MySQL server at localhost: Access denied for user 'username'@'localhost' (using password: YES) (errno=0)
W tym zamieszczonym przez siebie logu masz:
sie 08 07:50:26 debian fail2ban-client[23236]: ERROR  [b]Server already running[/b]
Nic Ci to nie mówi? Pierwej wyłącz usługę a dopiero potem uruchamiaj.
