Proszę podać specyfikację sprzętową (model laptopa) poprzez edycję tej wiadomości.
Dodatkowo wynik z
lspci -vk[/color]
Witam Panowie i Panie
Mój problem jest następujący, ale wpierw kilka informacji o systemie które jestem w stanie wyświetlić w konsoli :P
Laptop to Lenovo ThinkPad T400s
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
Subsystem: Lenovo Device 20e0
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 20e4
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at f2000000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 1800 [size=8]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: i915
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
Memory at f2400000 (64-bit, non-prefetchable) [size=1M]
00:03.0 Communication controller: Intel Corporation Mobile 4 Series Chipset MEI Controller (rev 07)
Subsystem: Lenovo Device 20e6
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at f2826000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
00:03.3 Serial controller: Intel Corporation Mobile 4 Series Chipset AMT SOL Redirection (rev 07) (prog-if 02 [16550])
Subsystem: Lenovo Device 20ec
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 17
I/O ports at 1830 [size=8]
Memory at f2624000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: serial
00:19.0 Ethernet controller: Intel Corporation 82567LM Gigabit Network Connection (rev 03)
Subsystem: Lenovo Device 20ee
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f2600000 (32-bit, non-prefetchable) [size=128K]
Memory at f2625000 (32-bit, non-prefetchable) [size=4K]
I/O ports at 1840 [size=32]
Kernel driver in use: e1000e
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03) (prog-if 00 [UHCI])
Subsystem: Lenovo Device 20f0
Flags: bus master, medium devsel, latency 0, IRQ 20
I/O ports at 1860 [size=32]
Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21
I/O ports at 1880 [size=32]
00:1a.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 22
I/O ports at 18a0 [size=32]
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03) (prog-if 20 [EHCI])
Subsystem: Lenovo Device 20f1
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f2826400 (32-bit, non-prefetchable) [size=1K]
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
Subsystem: Lenovo Device 20f2
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at f2620000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: c0000000-c01fffff
Prefetchable memory behind bridge: 00000000c0200000-00000000c03fffff
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: f2500000-f25fffff
Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=0c, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f0000000-f1ffffff
Prefetchable memory behind bridge: 00000000f2900000-00000000f29fffff
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 18c0 [size=32]
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at 18e0 [size=32]
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 1c00 [size=32]
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
Memory at f2826800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=0e, subordinate=0e, sec-latency=32
00:1f.0 ISA bridge: Intel Corporation ICH9M-E LPC Interface Controller (rev 03)
Subsystem: Lenovo Device 20f5
Kernel driver in use: lpc_ich
00:1f.2 IDE interface: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 2 port SATA Controller [IDE mode] (rev 03) (prog-if 8a [Master SecP PriP])
Subsystem: Lenovo Device 20f7
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 16
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at 1c30 [size=16]
I/O ports at 1c20 [size=16]
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
Subsystem: Lenovo Device 20f9
Flags: medium devsel, IRQ 23
Memory at f2826c00 (64-bit, non-prefetchable) [size=256]
I/O ports at 1c60 [size=32]
Kernel driver in use: i801_smbus
00:1f.5 IDE interface: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 2 port SATA Controller [IDE mode] (rev 03) (prog-if 85 [Master SecO PriO])
Subsystem: Lenovo Device 20fa
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 17
I/O ports at 1ca0 [size=8]
I/O ports at 1c94 [size=4]
I/O ports at 1c98 [size=8]
I/O ports at 1c90 [size=4]
I/O ports at 1c80 [size=16]
I/O ports at 1c50 [size=16]
03:00.0 Network controller: Intel Corporation Ultimate N WiFi Link 5300
Subsystem: Intel Corporation Device 1111
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at f2500000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
05:00.0 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller (rev 01)
Subsystem: Lenovo Device 2133
Physical Slot: 3
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at f1f00000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: sdhci-pci
05:00.1 System peripheral: Ricoh Co Ltd R5U2xx (R5U230 / R5U231 / R5U241) [Memory Stick Host Controller] (rev 01)
Subsystem: Lenovo Device 2134
Physical Slot: 3
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f1f00400 (32-bit, non-prefetchable) [size=256]
Linux version 3.16.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.7-ckt25-1 (2016-03-06)
Debian GNU/Linux 8 \n \lwynik polecenia:
egrep -i 'synap|alps|etps' /proc/bus/input/devicesKod: Zaznacz cały
N: Name="PS/2 Synaptics TouchPad"a teraz do rzeczy
w kcm_touchpad otrzymuje komunikat "no touchpad found" touchpad działa jednak chciałem przyspieszyć poruszanie się kursora, niestety z poziomu kcm nie mam takiej możliwości, w zasadzie nie mam możliwości wykonania jakichkolwiek ustawień touchpada. Oprócz touchpada mam również w laptopie trackpointa (dopóty dopóki miałem windowsa to go używałem) niestety przestałem z niego korzystać po przesiadce na Debiana gdyż zaczął bardzo wolno przesuwać kursorem, a że nie znałazem do niego żadnych ustawień konifguracyjnych to idąc na łatwizne przesiadłem się na touchpada (teraz nastał czas zemsty) i do czasu kcm_touchpad działało jednak ostatnio bateria się rozładowała i wyłączył się, po włączeniu niestety przesuwanie się kursora jest za wolne jak dla mnie. Chciałbym móc to ustawiać albo z poziomu okienkowego albo z konsoli, a już super by było gdybym spowrotem przesiadł się na trackpointa.
Dodatkowo dodam że na innym forum kilka osób próbowało mi pomóc niestety... temat umarł,
to co polecali mi zrobić to m.in:
zainstalowanie jądra z backportów - DONE
przyspieszenie poruszania się kurosora poleceniem:
synclient "MinSpeed=10"
Couldn't find synaptics properties. No synaptics driver loaded?Kod: Zaznacz cały
No protocol specified
Failed to connect to X Server.Kod: Zaznacz cały
uname -a
Linux z99 4.7.0-0.bpo.1-amd64 #1 SMP Debian 4.7.5-1~bpo8+2 (2016-10-01) x86_64 GNU/LinuxKod: Zaznacz cały
dpkg -l | grep evdev
ii libevdev2 1.3+dfsg-1 amd64 wrapper library for evdev devices
ii xserver-xorg-input-evdev 1:2.9.0-2 amd64 X.Org X server -- evdev input driver
