postfix + dovecot / problem
uh4
Post autor: uh4 »
mam pewien problem którego nie mogę rozwiązać.
E-maile wewnątrz maszyny działają, mogę wysłać e-mail na świat.
Nie mogę natomiast wysłać e-mail do siebie na serwer.
W logach mi nic nie pokazuje, żadnego błędu.
Jedynie odpowiedz z gmaila:
Delivery to the following recipient failed permanently:
    xxxxx@xxxx
Technical details of permanent failure:
read error: generic::failed_precondition: read error (0): error
postfix:
root@juchnicki:~# cat /etc/postfix/main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = juchnicki.pl
mydestination = juchnicki.pl, localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
html_directory = /usr/share/doc/postfix/html
dovecot:
root@juchnicki:~# dovecot -n
# 2.2.13: /etc/dovecot/dovecot.conf
# OS: Linux 3.16.0-4-amd64 x86_64 Debian 8.5
mail_location = mbox:~/mail:INBOX=/var/mail/%u
mail_privileged_group = mail
namespace inbox {
  inbox = yes
  location =
  mailbox Drafts {
    special_use = \Drafts
  mailbox Junk {
    special_use = \Junk
  mailbox Sent {
    special_use = \Sent
  mailbox "Sent Messages" {
    special_use = \Sent
  mailbox Trash {
    special_use = \Trash
  prefix =
passdb {
  driver = pam
plugin {
  sieve = ~/.dovecot.sieve
  sieve_dir = ~/sieve
protocols = " imap lmtp pop3"
ssl = no
userdb {
  driver = passwd
Robione według:
https://www.howtoforge.com/tutorial/per ... pconfig-3/
Re: postfix + dovecot / problem
Jak masz skonfigurowanego MX-a?
