Zaszła potrzeba aktualizacji CUPS do najnowszej wersji - 2.1.3. . Kompilacja ze źródeł ze strony, ale po tym niestety cups.service podnieść się nie chce z powodu błędu:
root@vdeb# systemctl -a | grep cups
cups.path loaded active waiting CUPS Printer Service Spool
cups-browsed.service loaded active running Make remote CUPS printers available locally
● cups.service loaded failed failed CUPS Printing Service
cups.socket loaded active listening CUPS Printing Service Sockets
root@vdeb# systemctl status cups.service
● cups.service - CUPS Printing Service
Loaded: loaded (/lib/systemd/system/cups.service; enabled)
Active: failed (Result: exit-code) since pon 2016-05-23 09:15:06 CEST; 8s ago
Docs: man:cupsd(8)
man:cupsd.conf(5)
Process: 3394 ExecStart=/usr/sbin/cupsd -f (code=exited, status=127)
Main PID: 3394 (code=exited, status=127)
maj 23 09:15:06 vdeb cupsd[3394]: /usr/sbin/cupsd: symbol lookup error: /usr/sbin/cupsd: undefined symbol: httpAddrFamily
maj 23 09:15:06 vdeb systemd[1]: cups.service: main process exited, code=exited, status=127/n/a
maj 23 09:15:06 vdeb systemd[1]: Unit cups.service entered failed state.
root@vdeb# dpkg -l | grep cups
iU cups 2.1.3-5 amd64 Common UNIX Printing System(tm) - PPD/driver support, web interface
ii cups-browsed 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - cups-browsed
ii cups-client 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - client programs (SysV)
ii cups-common 1.7.5-11+deb8u1 all Common UNIX Printing System(tm) - common files
ii cups-core-drivers 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD-less printing
ii cups-daemon 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - daemon
ii cups-filters 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - Main Package
ii cups-filters-core-drivers 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - PPD-less printing
ii cups-pdf 2.6.1-15 amd64 PDF writer backend for CUPS (dummy transitional package)
ii cups-ppdc 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD manipulation utilities
ii cups-server-common 1.7.5-11+deb8u1 all Common UNIX Printing System(tm) - server common files
ii libcups2:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - Core library
ii libcupscgi1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - CGI library
ii libcupsfilters1:amd64 1.0.61-5+deb8u3 amd64 OpenPrinting CUPS Filters - Shared library
ii libcupsimage2:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - Raster image library
ii libcupsmime1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - MIME library
ii libcupsppdc1:amd64 1.7.5-11+deb8u1 amd64 Common UNIX Printing System(tm) - PPD manipulation library
ii printer-driver-cups-pdf 2.6.1-15 amd64 printer driver for PDF writing via CUPS
Linux vdeb 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/LinuxPróbowałem instalować z repo sida, ale wtedy aktualizuje mi jeszcze "milion" innych pakietów, a tego nie chcę.
Jakaś porada może?
