xorg.log
13.977] (EE) fglrx(0): atiddxDriScreenInit failed. Probably kernel module missing or incompatible.
[ 13.977] (WW) fglrx(0): ***********************************************************
[ 13.977] (WW) fglrx(0): * DRI initialization failed *
[ 13.977] (WW) fglrx(0): * kernel module (fglrx.ko) may be missing or incompatible *
[ 13.977] (WW) fglrx(0): * 2D and 3D acceleration disabled *
[ 13.977] (WW) fglrx(0):po wydaniu dpkg-reconfigure fglrx-modules-dkms
Deleting module version: 15.9
completely from the DKMS tree.
Done.
Loading new fglrx-15.9 DKMS files...
Building only for 4.4.0-0.bpo.1-amd64
Building initial module for 4.4.0-0.bpo.1-amd64
Error! Bad return status for module build on kernel: 4.4.0-0.bpo.1-amd64 (x86_64)
Consult /var/lib/dkms/fglrx/15.9/build/make.log for more information.Kod: Zaznacz cały
DKMS make.log for fglrx-15.9 for kernel 4.4.0-0.bpo.1-amd64 (x86_64)
nie, 15 maj 2016, 02:57:32 CEST
make: Wejście do katalogu '/usr/src/linux-headers-4.4.0-0.bpo.1-amd64'
LD /var/lib/dkms/fglrx/15.9/build/built-in.o
CC [M] /var/lib/dkms/fglrx/15.9/build/firegl_public.o
/var/lib/dkms/fglrx/15.9/build/firegl_public.c: In function ‘firegl_major_proc_read’:
/var/lib/dkms/fglrx/15.9/build/firegl_public.c:639:9: error: void value not ignored as it ought to be
len = seq_printf(m, "%d\n", major);
/var/lib/dkms/fglrx/15.9/build/firegl_public.c: In function ‘KCL_fpu_save_init’:
/var/lib/dkms/fglrx/15.9/build/firegl_public.c:6516:49: error: ‘XSTATE_FP’ undeclared (first use in this function)
if (!(fpu->state.xsave.header.xfeatures & XSTATE_FP))
/var/lib/dkms/fglrx/15.9/build/firegl_public.c:6516:49: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/fglrx/15.9/build/firegl_public.c: At top level:
/var/lib/dkms/fglrx/15.9/build/firegl_public.c:6506:12: warning: ‘KCL_fpu_save_init’ defined but not used [-Wunused-function]
static int KCL_fpu_save_init(struct task_struct *tsk)
/usr/src/linux-headers-4.4.0-0.bpo.1-common/scripts/Makefile.build:263: polecenia dla obiektu '/var/lib/dkms/fglrx/15.9/build/firegl_public.o' nie powiodły się
make[3]: *** [/var/lib/dkms/fglrx/15.9/build/firegl_public.o] Błąd 1
/usr/src/linux-headers-4.4.0-0.bpo.1-common/Makefile:1401: polecenia dla obiektu '_module_/var/lib/dkms/fglrx/15.9/build' nie powiodły się
make[2]: *** [_module_/var/lib/dkms/fglrx/15.9/build] Błąd 2
Makefile:146: polecenia dla obiektu 'sub-make' nie powiodły się
make[1]: *** [sub-make] Błąd 2
Makefile:8: polecenia dla obiektu 'all' nie powiodły się
make: *** [all] Błąd 2
make: Opuszczenie katalogu '/usr/src/linux-headers-4.4.0-0.bpo.1-amd64'
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:1:0:0"
Option "OpenGLOverlay" "0" ##
Option "XAANoOffscreenPixmaps" "false" ##
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666 # May help enable direct rendering.
EndSection
modprobe: FATAL: Module fglrx not found.radeon zblacklistowany , nomodeset dodany do gruba
debian jessie 8
uname -a
Linux debian 4.4.0-0.bpo.1-amd64 #1 SMP Debian 4.4.6-1~bpo8+1 (2016-03-20) x86_64 GNU/Linux
root@debian:/home/user#
instalacja zamkniętego steru ze strony producenta też się nie powiodła
/usr/share/ati/fglrx-install.log
Supported adapter detected.
Check if system has the tools required for installation.
Uninstalling any previously installed drivers.
Errors during DKMS module removal
Creating symlink /var/lib/dkms/fglrx/15.302/source ->
/usr/src/fglrx-15.302
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....
cd /var/lib/dkms/fglrx/15.302/build; sh make.sh --nohints --uname_r=4.4.0-0.bpo.1-amd64 --norootcheck....(bad exit status: 1)
[Error] Kernel Module : Failed to build fglrx-15.302 with DKMS
[Error] Kernel Module : Removing fglrx-15.302 from DKMS
Deleting module version: 15.302
Done.
[Reboot] Kernel Module : update-initramfskarta radeon r7 240 nowa w pełni sprawna
kernel 4 repowy
