Nie można zainstalowa
johnyjj2
Nie można zainstalować Mono Develop
Post autor: johnyjj2 »
Cześć,
nie mogę zainstalować Mono Develop na Debianie.
Pierwszy sposób
Pakiet ściągnięty stąd (https://packages.debian.org/jessie/all/ ... p/download) nie działa z powodu następującego błędu:
Cannot install 'libglade2.0-cil'.
Szczegóły (Lintian output) były takie:
W: monodevelop: debian-news-entry-has-unknown-version 0.18.1-1
E: monodevelop: debian-copyright-file-uses-obsolete-national-encoding at line 23
W: monodevelop: manpage-has-errors-from-man usr/share/man/man1/mdtool.1.gz 104: warning: macro `/'' not defined
E: monodevelop: menu-icon-not-in-xpm-format usr/share/icons/hicolor/scalable/apps/monodevelop.svg
W: monodevelop: script-not-executable usr/lib/monodevelop/AddIns/MonoDevelop.Autotools/templates/autogen.sh.template
W: monodevelop: script-not-executable usr/lib/monodevelop/AddIns/MonoDevelop.Autotools/templates/configure.template
W: monodevelop: script-not-executable usr/lib/monodevelop/AddIns/MonoDevelop.Autotools/templates/exe.wrapper.in.template
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/appconfig.xsd
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/XMLSchema.xsd
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/W3C-License.html
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/xslt.xsd
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/nant.xsd
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.AspNet/Schemas/readme.txt
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/manifest.xsd
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.XmlEditor/schemas/readme.txt
W: monodevelop: executable-not-elf-or-script usr/lib/monodevelop/AddIns/MonoDevelop.AspNet/Schemas/W3C-License.html
Lintian finished with exit status 1
Zaś ręczna instalacja libglade:
root@myusername:~# sudo apt-get install libglade
Reading package lists... Done
Building dependency tree
E: Unable to locate package libglade
root@myusername:~# sudo apt-get install libglade2.0-cil
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libglade2.0-cil : Depends: libgtk2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@myusername:~#
Drugi sposób
Te trzy polecenia (http://www.mono-project.com/docs/gettin ... erivatives) zadziałały, więc repozytorium pakietów powinno być zaktualizowane. Ale później polecenia z sekcji 'Usage" nie działały:
root@myusername:~# sudo apt-get install mono-devel
mono-devel : Depends: libgdiplus (>= 2.6.7) but it is not going to be installed
Depends: libmono-system-design4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed
Depends: libmono-system-messaging4.0-cil (>= 2.10.1) but it is not going to be installed
Depends: libmono-system-runtime4.0-cil (>= 2.10.1) but it is not going to be installed
Depends: libmono-system-servicemodel-activation4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-servicemodel-web4.0-cil (>= 3.2.1) but it is not going to be installed
Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed
Depends: libmono-system-web-extensions4.0-cil (>= 2.10.3) but it is not going to be installed
Depends: libmono-system-web-services4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed
Depends: libmono-system-windows-forms4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-cil-dev (= 4.2.2.30-0xamarin2) but it is not going to be installed
Podobnie z drugim z pakietów wspomnianych w 'Usage'.
Jak zainstalować Mono Develop (w celu umożliwienia stworzenia prostej aplikacji na Androida przy pomocy języka C#) na Debianie?
Z góry dzięki!
lizard
Post autor: lizard »
Pokaż zawartość /etc/apt/sources.list i /etc/apt/sources.list.d/*.list. Wygląda mi to na problem z repozytoriami.
johnyjj2
lizard pisze:Pokaż zawartość /etc/apt/sources.list i /etc/apt/sources.list.d/*.list. Wygląda mi to na problem z repozytoriami.
Może tak być. Przed chwilą wykomentowałem repozytorium Canonical, zrobiłem apt-get update i niestety to nie wystarczyło. Apt-get -f install niczego nie musiał naprawiać.
# deb-src cdrom:[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30]/ jessie main
# deb cdrom:[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30]/ jessie main
deb http://ftp.uk.debian.org/debian/ jessie main
deb-src http://ftp.uk.debian.org/debian/ jessie main
deb http://security.debian.org/ jessie/updates main
deb-src http://security.debian.org/ jessie/updates main
# jessie-updates, previously known as 'volatile'
deb http://ftp.uk.debian.org/debian/ jessie-updates main
deb-src http://ftp.uk.debian.org/debian/ jessie-updates main
# deb http://archive.canonical.com/ jessie partner
# deb-src http://archive.canonical.com/ jessie partner
# Debian 8 "Jessie"
deb http://httpredir.debian.org/debian/ jessie main contrib
name@debian:/etc/apt/sources.list.d$ ls
google-talkplugin.list mono-xamarin.list.save
google-talkplugin.list.save webupd8team-haguichi-jessie.list
mono-xamarin.list
Za to zauważyłem, że brakująca zależność to
root@myusername:~# apt-get install libjpeg8
Package libjpeg8 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libjpeg8' has no installation candidate
Pobrałem stąd https://sourceforge.net/projects/libjpe ... p_redirect i zauważyłem, że jest tam jakiś install-sh, to go próbuję uruchomić.
[INDENT]root@debian:/home/user/Downloads/jpeg-6b# ./install-sh
-su: ./install-sh: /bin/sh^M: bad interpreter: No such file or directory
[/INDENT]
NIestety nigdy nie robiłem builda ani nie tworzyłem pakietów pod Linuksem. A chyba tego libjpeg8 po prostu nie ma w tym wydaniu Debiana.
lizard
Dodaj o repozytoriów głównych Debiana komponenety non-free i contrib:
deb [URL]http://ftp.uk.debian.org/debian/[/URL] jessie main non-free contrib
deb-src [URL]http://ftp.uk.debian.org/debian/[/URL] jessie main non-free contrib
deb [URL]http://security.debian.org/[/URL] jessie/updates main non-free contrib
deb-src [URL]http://security.debian.org/[/URL] jessie/updates main non-free contrib
deb [URL]http://ftp.uk.debian.org/debian/[/URL] jessie-updates main non-free contrib
deb-src [URL]http://ftp.uk.debian.org/debian/[/URL] jessie-updates main non-free contrib
Potem standardowe: apt-get update && apt-get install monodevelop.
johnyjj2 pisze:
To jest dobry przykład na to, aby nie mieszać repozytoriów dystrybucji. :)
Proszę używać tagów CODE, a nie QUOTE.
