Mam problem z konfiguracją Samby jako Active Directory.Po instalacji Samby uruchamiam samba-tools domain provision.Po wpisaniu danych o które prosi Samba wyskakują mi 3 błędy
ERROR(<class 'samba.provision.ProvisioningError'>): Provision failed - ProvisioningError: guess_names: Realm 'SERWER' must not be equal to short domain name 'SERWER'! File "/usr/local/samba/lib/python2.7/site-packages/samba/netcmd/domain.py", line 442, in run nosync=ldap_backend_nosync, ldap_dryrun_mode=ldap_dryrun_mode)
File "/usr/local/samba/lib/python2.7/site-packages/samba/provision/__init__.py", line 2025, in provision sitename=sitename, rootdn=rootdn, domain_names_forced=(samdb_fill == FILL_DRS))
File "/usr/local/samba/lib/python2.7/site-packages/samba/provision/__init__.py ", line 641, in guess_names raise ProvisioningError("guess_names: Realm '%s' must not be equal to short domain name '%s'!" % (realm, domain))
Poniżej pliki które mogą pomóc w diagnostyce problemu
/etc/network/interfaces
# This file describes the network interfaces available on your system# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
auto eth1
iface eth1 inet dhcp
#SAMBA I DHCP
auto eth0
iface eth0 inet static
address 172.16.0.1
netmask 255.255.0.0
network 172.16.0.0
broadcast 172.16.255.255
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=b62910f2-85d6-4482-85de-761c99f3f98b / ext4 errors=remount-ro,user_xattr,acl,barrier=1 1 1
# swap was on /dev/sda5 during installation
UUID=f4b479af-df9f-4d77-847a-9ba49f20f202 none swap sw 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
Bardzo prosiłbym o pomoc,jest mi to potrzebne w ramach pracy zaliczeniowej z praktyk.
