Radeon HD 7750 - Debian Strech - problem z zamkni
[+]Radeon HD 7750 - Debian Strech - problem z zamkniętym sterownikiem
Dotychczas działałem na otwartym sterowniku.
Postanowiłem zainstalować zamknięty sterownik wg poradnika https://wiki.debian.org/ATIProprietary
Po restarcie na kernelu 4.3 mam czarny ekran, na kernelu 4.2 startuje ale coś nie do końca działa:
[root@user user]# fglrxinfo
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  157 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  16
  Current serial number in output stream:  16
Dane pomocnicze.
Wersja jądra:
[root@user user]# uname -a
Linux user 4.2.0-1-amd64 #1 SMP Debian 4.2.6-3 (2015-12-06) x86_64 GNU/Linux
Rodzaj GPU
root@user user]# lspci | grep VGA
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
Logi Xorg:
[root@user user]# cat /var/log/Xorg.0.log
[     5.112]
X.Org X Server 1.17.3
Release Date: 2015-10-26
[     5.112] X Protocol Version 11, Revision 0
[     5.112] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[     5.112] Current Operating System: Linux user 4.2.0-1-amd64 #1 SMP Debian 4.2.6-3 (2015-12-06) x86_64
[     5.112] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.2.0-1-amd64 root=UUID=6eb60859-b2f8-468e-b6d5-9cfb69860a4f ro quiet splash nomodeset
[     5.112] Build Date: 27 October 2015  11:41:02PM
[     5.112] xorg-server 2:1.17.3-2 ([URL]http://www.debian.org/support[/URL])
[     5.112] Current version of pixman: 0.33.6
[     5.112]     Before reporting problems, check [URL]http://wiki.x.org[/URL]
[     5.112] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.112] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 27 20:17:26 2016
[     5.114] (==) Using config file: "/etc/X11/xorg.conf"
[     5.114] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.119] (==) ServerLayout "aticonfig Layout"
[     5.120] (**) |-->Screen "aticonfig-Screen[0]-0" (0)
[     5.120] (**) |   |-->Monitor "aticonfig-Monitor[0]-0"
[     5.122] (**) |   |-->Device "aticonfig-Device[0]-0"
[     5.122] (==) Automatically adding devices
[     5.122] (==) Automatically enabling devices
[     5.122] (==) Automatically adding GPU devices
[     5.129] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     5.129]     Entry deleted from font path.
[     5.129] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[     5.129] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[     5.132] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[     5.132]     Entry deleted from font path.
[     5.132] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[     5.132] (==) FontPath set to:
    /usr/share/fonts/X11/misc,
    /usr/share/fonts/X11/Type1,
    built-ins
[     5.132] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.132] (II) The server relies on udev to provide the list of input devices.
[     5.132] (II) Loader magic: 0x563b65a80de0
[     5.132] (II) Module ABI versions:
[     5.132]     X.Org ANSI C Emulation: 0.4
[     5.132]     X.Org Video Driver: 19.0
[     5.132]     X.Org XInput driver : 21.0
[     5.132]     X.Org Server Extension : 9.0
[     5.133] (EE) systemd-logind: failed to get session: PID 974 does not belong to any known session
[     5.136] (--) PCI:*(0:1:0:0) 1002:683f:174b:e213 rev 0, Mem @ 0xd0000000/268435456, 0xfe780000/262144, I/O @ 0x0000b000/256, BIOS @ 0x????????/131072
[     5.136] (II) "glx" will be loaded by default.
[     5.136] (II) LoadModule: "glx"
[     5.142] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[     5.149] (II) Module glx: vendor="Advanced Micro Devices, Inc."
[     5.149]     compiled for 6.9.0, module version = 1.0.0
[     5.149] (II) LoadModule: "fglrx"
[     5.159] (II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
[     5.271] (II) Module fglrx: vendor="FireGL - AMD Technologies Inc."
[     5.271]     compiled for 1.4.99.906, module version = 15.20.3
[     5.271]     Module class: X.Org Video Driver
[     5.275] (II) Loading sub module "fglrxdrm"
[     5.276] (II) LoadModule: "fglrxdrm"
[     5.276] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[     5.279] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[     5.279]     compiled for 1.4.99.906, module version = 15.20.3
[     5.279] (II) AMD Proprietary Linux Driver Version Identifier:15.20.3
[     5.279] (II) AMD Proprietary Linux Driver Release Identifier: UNSUPPORTED-15.201.1151
[     5.279] (II) AMD Proprietary Linux Driver Build Date: Sep  8 2015 15:06:35
[     5.279] (++) using VT number 7
[     5.287] (WW) Falling back to old probe method for fglrx
[     5.340] (II) Loading PCS database from /etc/ati/amdpcsdb /etc/ati/amdpcsdb.default
[     5.347] ukiDynamicMajor: found major device number 247
[     5.347] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[     5.347] ukiOpenDevice: node name is /dev/ati/card0
[     5.347] ukiOpenDevice: open result is 10, (OK)
[     5.445] ukiOpenByBusid: ukiOpenMinor returns 10
[     5.445] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[     5.450] (--) Chipset Supported AMD Graphics Processor (0x683F) found
[     5.451] (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
[     5.453] (II) fglrx(0): pEnt->device->identifier=0x563b670f6450
[     5.453] (II) fglrx(0): === [xdl_xs117_atiddxPreInit] === begin
[     5.453] (II) fglrx(0): FB driver is not enabled
[     5.453] (II) Loading sub module "vgahw"
[     5.453] (II) LoadModule: "vgahw"
[     5.453] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[     5.454] (II) Module vgahw: vendor="X.Org Foundation"
[     5.454]     compiled for 1.17.3, module version = 0.1.0
[     5.454]     ABI class: X.Org Video Driver, version 19.0
[     5.454] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[     5.454] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     5.454] (==) fglrx(0): Default visual is TrueColor
[     5.454] (**) fglrx(0): Option "DPMS" "true"
[     5.454] (==) fglrx(0): RGB weight 888
[     5.454] (II) fglrx(0): Using 8 bits per RGB
[     5.454] (==) fglrx(0): Buffer Tiling is ON
[     5.454] (II) Loading sub module "fglrxdrm"
[     5.455] (II) LoadModule: "fglrxdrm"
[     5.455] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[     5.455] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[     5.455]     compiled for 1.4.99.906, module version = 15.20.3
[     5.457] ukiDynamicMajor: found major device number 247
[     5.457] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[     5.457] ukiOpenDevice: node name is /dev/ati/card0
[     5.457] ukiOpenDevice: open result is 12, (OK)
[     5.457] ukiOpenByBusid: ukiOpenMinor returns 12
[     5.457] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[     5.457] (**) fglrx(0): NoAccel = NO
[     5.457] (**) fglrx(0): AMD 2D Acceleration Architecture enabled
[     5.457] (--) fglrx(0): Chipset: "AMD Radeon HD 7700 Series   " (Chipset = 0x683f)
[     5.457] (--) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0xe213)
[     5.457] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original AMD
[     5.457] (--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
[     5.457] (--) fglrx(0): MMIO registers at 0xfe780000
[     5.457] (--) fglrx(0): I/O port at 0x0000b000
[     5.457] (==) fglrx(0): ROM-BIOS at 0x000c0000
[     5.458] (II) fglrx(0): AC Adapter is used
[     5.460] (EE) fglrx(0): Cannot read int vect
[     5.544] (II) Loading sub module "vbe"
[     5.544] (II) LoadModule: "vbe"
[     5.544] (II) Loading /usr/lib/xorg/modules/libvbe.so
[     5.545] (II) Module vbe: vendor="X.Org Foundation"
[     5.545]     compiled for 1.17.3, module version = 1.1.0
[     5.545]     ABI class: X.Org Video Driver, version 19.0
[     5.545] (II) Loading sub module "int10"
[     5.545] (II) LoadModule: "int10"
[     5.545] (II) Loading /usr/lib/xorg/modules/libint10.so
[     5.546] (II) Module int10: vendor="X.Org Foundation"
[     5.546]     compiled for 1.17.3, module version = 1.0.0
[     5.546]     ABI class: X.Org Video Driver, version 19.0
[     5.546] (II) fglrx(0): initializing int10
[     5.546] (EE) fglrx(0): Cannot read int vect
[     5.546] (WW) fglrx(0): GetVBEMode failed
[     5.546] (II) fglrx(0): AMD Video BIOS revision 9 or later detected
[     5.546] (--) fglrx(0): Video RAM: 1048576 kByte, Type: GDDR5
[     5.546] (II) fglrx(0): PCIE card detected
[     5.546] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[     5.546] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[     5.546] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf400000000, MCFBSize = 0x40000000)
[     5.546] (II) fglrx(0): RandR 1.2 support is enabled!
[     5.546] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[     5.546] (II) Loading sub module "fb"
[     5.546] (II) LoadModule: "fb"
[     5.546] (II) Loading /usr/lib/xorg/modules/libfb.so
[     5.547] (II) Module fb: vendor="X.Org Foundation"
[     5.547]     compiled for 1.17.3, module version = 1.0.0
[     5.547]     ABI class: X.Org ANSI C Emulation, version 0.4
[     5.547] (II) fglrx(0): EDID Management option: EDID Management is enabled
[     5.547] (II) Loading sub module "ddc"
[     5.547] (II) LoadModule: "ddc"
[     5.547] (II) Module "ddc" already built-in
[     5.699] (II) fglrx(0): Output DFP1 using monitor section aticonfig-Monitor[0]-0
[     5.699] (II) fglrx(0): Output DFP2 has no monitor section
[     5.699] (II) fglrx(0): Output DFP3 has no monitor section
[     5.700] (II) fglrx(0): Output DFP4 has no monitor section
[     5.700] (II) fglrx(0): Output DFP5 has no monitor section
[     5.700] (II) fglrx(0): Output DFP6 has no monitor section
[     5.700] (II) fglrx(0): Output CRT1 has no monitor section
[     5.700] (II) Loading sub module "ddc"
[     5.700] (II) LoadModule: "ddc"
[     5.700] (II) Module "ddc" already built-in
[     5.700] (II) fglrx(0): Connected Display0: CRT1
[     5.700] (II) fglrx(0): Display0 EDID data ---------------------------
[     5.700] (II) fglrx(0): Manufacturer: IVM  Model: 5601  Serial#: 16843009
[     5.700] (II) fglrx(0): Year: 2008  Week: 5
[     5.700] (II) fglrx(0): EDID Version: 1.3
[     5.700] (II) fglrx(0): Analog Display Input,  Input Voltage Level: 0.700/0.700 V
[     5.700] (II) fglrx(0): Sync:  Separate  Composite
[     5.700] (II) fglrx(0): Max Image Size [cm]: horiz.: 52  vert.: 33
[     5.700] (II) fglrx(0): Gamma: 2.20
[     5.700] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[     5.700] (II) fglrx(0): First detailed timing is preferred mode
[     5.700] (II) fglrx(0): redX: 0.653 redY: 0.337   greenX: 0.295 greenY: 0.607
[     5.700] (II) fglrx(0): blueX: 0.144 blueY: 0.075   whiteX: 0.313 whiteY: 0.329
[     5.700] (II) fglrx(0): Supported established timings:
[     5.700] (II) fglrx(0): 720x400@70Hz
[     5.700] (II) fglrx(0): 640x480@60Hz
[     5.700] (II) fglrx(0): 640x480@67Hz
[     5.700] (II) fglrx(0): 640x480@72Hz
[     5.700] (II) fglrx(0): 640x480@75Hz
[     5.700] (II) fglrx(0): 800x600@60Hz
[     5.700] (II) fglrx(0): 800x600@72Hz
[     5.700] (II) fglrx(0): 800x600@75Hz
[     5.700] (II) fglrx(0): 832x624@75Hz
[     5.700] (II) fglrx(0): 1024x768@60Hz
[     5.700] (II) fglrx(0): 1024x768@70Hz
[     5.700] (II) fglrx(0): 1024x768@75Hz
[     5.700] (II) fglrx(0): 1280x1024@75Hz
[     5.700] (II) fglrx(0): 1152x864@75Hz
[     5.700] (II) fglrx(0): Manufacturer's mask: 0
[     5.700] (II) fglrx(0): Supported standard timings:
[     5.700] (II) fglrx(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     5.700] (II) fglrx(0): #1: hsize: 1280  vsize 1024  refresh: 76  vid: 36993
[     5.700] (II) fglrx(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     5.700] (II) fglrx(0): #3: hsize: 1280  vsize 1024  refresh: 72  vid: 35969
[     5.700] (II) fglrx(0): #4: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     5.700] (II) fglrx(0): #5: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     5.700] (II) fglrx(0): #6: hsize: 1440  vsize 900  refresh: 75  vid: 3989
[     5.700] (II) fglrx(0): #7: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     5.700] (II) fglrx(0): Supported detailed timing:
[     5.700] (II) fglrx(0): clock: 154.0 MHz   Image Size:  519 x 324 mm
[     5.700] (II) fglrx(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[     5.700] (II) fglrx(0): v_active: 1200  v_sync: 1203  v_sync_end 1209 v_blanking: 1235 v_border: 0
[     5.700] (II) fglrx(0): Serial No: 0574280550466
[     5.700] (II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[     5.700] (II) fglrx(0): Monitor name: PLB2403WS
[     5.700] (II) fglrx(0): EDID (in hex):
[     5.700] (II) fglrx(0):     00ffffffffffff0026cd015601010101
[     5.700] (II) fglrx(0):     051201036c342178ea5ad5a7564b9b24
[     5.700] (II) fglrx(0):     135054bdef80714f81908180818ca940
[     5.700] (II) fglrx(0):     b300950f9500283c80a070b023403020
[     5.700] (II) fglrx(0):     360007442100001a000000ff00303537
[     5.700] (II) fglrx(0):     34323830353530343636000000fd0038
[     5.700] (II) fglrx(0):     4c1e5311000a202020202020000000fc
[     5.700] (II) fglrx(0):     00504c423234303357530a2020200073
[     5.700] (II) fglrx(0): End of Display0 EDID data --------------------
[     5.700] (II) fglrx(0): Dynamic Surface Resizing Enabled
[     5.701] (II) fglrx(0): EDID for output DFP1
[     5.701] (II) fglrx(0): EDID for output DFP2
[     5.701] (II) fglrx(0): EDID for output DFP3
[     5.701] (II) fglrx(0): EDID for output DFP4
[     5.701] (II) fglrx(0): EDID for output DFP5
[     5.701] (II) fglrx(0): EDID for output DFP6
[     5.702] (II) fglrx(0): EDID for output CRT1
[     5.702] (II) fglrx(0): Manufacturer: IVM  Model: 5601  Serial#: 16843009
[     5.702] (II) fglrx(0): Year: 2008  Week: 5
[     5.702] (II) fglrx(0): EDID Version: 1.3
[     5.702] (II) fglrx(0): Analog Display Input,  Input Voltage Level: 0.700/0.700 V
[     5.702] (II) fglrx(0): Sync:  Separate  Composite
[     5.702] (II) fglrx(0): Max Image Size [cm]: horiz.: 52  vert.: 33
[     5.702] (II) fglrx(0): Gamma: 2.20
[     5.702] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[     5.702] (II) fglrx(0): First detailed timing is preferred mode
[     5.702] (II) fglrx(0): redX: 0.653 redY: 0.337   greenX: 0.295 greenY: 0.607
[     5.702] (II) fglrx(0): blueX: 0.144 blueY: 0.075   whiteX: 0.313 whiteY: 0.329
[     5.702] (II) fglrx(0): Supported established timings:
[     5.702] (II) fglrx(0): 720x400@70Hz
[     5.702] (II) fglrx(0): 640x480@60Hz
[     5.702] (II) fglrx(0): 640x480@67Hz
[     5.702] (II) fglrx(0): 640x480@72Hz
[     5.702] (II) fglrx(0): 640x480@75Hz
[     5.702] (II) fglrx(0): 800x600@60Hz
[     5.702] (II) fglrx(0): 800x600@72Hz
[     5.702] (II) fglrx(0): 800x600@75Hz
[     5.702] (II) fglrx(0): 832x624@75Hz
[     5.702] (II) fglrx(0): 1024x768@60Hz
[     5.702] (II) fglrx(0): 1024x768@70Hz
[     5.702] (II) fglrx(0): 1024x768@75Hz
[     5.702] (II) fglrx(0): 1280x1024@75Hz
[     5.702] (II) fglrx(0): 1152x864@75Hz
[     5.702] (II) fglrx(0): Manufacturer's mask: 0
[     5.702] (II) fglrx(0): Supported standard timings:
[     5.702] (II) fglrx(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     5.702] (II) fglrx(0): #1: hsize: 1280  vsize 1024  refresh: 76  vid: 36993
[     5.702] (II) fglrx(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     5.702] (II) fglrx(0): #3: hsize: 1280  vsize 1024  refresh: 72  vid: 35969
[     5.702] (II) fglrx(0): #4: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     5.702] (II) fglrx(0): #5: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     5.702] (II) fglrx(0): #6: hsize: 1440  vsize 900  refresh: 75  vid: 3989
[     5.702] (II) fglrx(0): #7: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     5.702] (II) fglrx(0): Supported detailed timing:
[     5.702] (II) fglrx(0): clock: 154.0 MHz   Image Size:  519 x 324 mm
[     5.702] (II) fglrx(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[     5.702] (II) fglrx(0): v_active: 1200  v_sync: 1203  v_sync_end 1209 v_blanking: 1235 v_border: 0
[     5.702] (II) fglrx(0): Serial No: 0574280550466
[     5.702] (II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[     5.702] (II) fglrx(0): Monitor name: PLB2403WS
[     5.702] (II) fglrx(0): EDID (in hex):
[     5.702] (II) fglrx(0):     00ffffffffffff0026cd015601010101
[     5.702] (II) fglrx(0):     051201036c342178ea5ad5a7564b9b24
[     5.702] (II) fglrx(0):     135054bdef80714f81908180818ca940
[     5.702] (II) fglrx(0):     b300950f9500283c80a070b023403020
[     5.702] (II) fglrx(0):     360007442100001a000000ff00303537
[     5.702] (II) fglrx(0):     34323830353530343636000000fd0038
[     5.702] (II) fglrx(0):     4c1e5311000a202020202020000000fc
[     5.702] (II) fglrx(0):     00504c423234303357530a2020200073
[     5.703] (II) fglrx(0): Printing probed modes for output CRT1
[     5.703] (II) fglrx(0): Modeline "1920x1200"x60.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[     5.703] (II) fglrx(0): Modeline "1920x1080"x60.0  154.00  1920 1968 2000 2080  1080 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1400x1050"x60.0  162.00  1400 1664 1856 2160  1050 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x1024"x76.0  141.82  1280 1376 1512 1744  1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x1024"x72.0  132.75  1280 1368 1504 1728  1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1440x900"x75.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     5.703] (II) fglrx(0): Modeline "1440x900"x60.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x960"x76.0  141.82  1280 1376 1512 1744  960 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x960"x75.0  135.00  1280 1296 1440 1688  960 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x960"x72.0  132.75  1280 1368 1504 1728  960 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x960"x60.0  108.00  1280 1328 1440 1688  960 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x800"x76.0  141.82  1280 1376 1512 1744  800 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x800"x75.0  135.00  1280 1296 1440 1688  800 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x800"x72.0  132.75  1280 1368 1504 1728  800 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x800"x60.0  108.00  1280 1328 1440 1688  800 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1152x864"x60.0  154.00  1152 1968 2000 2080  864 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x768"x76.0  141.82  1280 1376 1512 1744  768 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x768"x75.0  135.00  1280 1296 1440 1688  768 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x768"x72.0  132.75  1280 1368 1504 1728  768 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x768"x60.0  108.00  1280 1328 1440 1688  768 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x720"x76.0  141.82  1280 1376 1512 1744  720 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x720"x75.0  135.00  1280 1296 1440 1688  720 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x720"x72.0  132.75  1280 1368 1504 1728  720 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     5.703] (II) fglrx(0): Modeline "1280x720"x60.0  108.00  1280 1328 1440 1688  720 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     5.703] (II) fglrx(0): Modeline "1024x768"x70.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     5.703] (II) fglrx(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.703] (II) fglrx(0): Modeline "800x600"x72.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     5.703] (II) fglrx(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     5.703] (II) fglrx(0): Modeline "800x600"x60.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.703] (II) fglrx(0): Modeline "640x480"x72.0   31.50  640 656 696 832  480 481 484 520 -hsync -vsync (37.9 kHz e)
[     5.703] (II) fglrx(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     5.703] (II) fglrx(0): Modeline "640x480"x67.0   27.28  640 664 728 816  480 481 484 499 -hsync +vsync (33.4 kHz e)
[     5.703] (II) fglrx(0): Modeline "640x480"x60.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.703] (II) fglrx(0): Output DFP1 disconnected
[     5.703] (II) fglrx(0): Output DFP2 disconnected
[     5.703] (II) fglrx(0): Output DFP3 disconnected
[     5.703] (II) fglrx(0): Output DFP4 disconnected
[     5.703] (II) fglrx(0): Output DFP5 disconnected
[     5.703] (II) fglrx(0): Output DFP6 disconnected
[     5.703] (II) fglrx(0): Output CRT1 connected
[     5.703] (II) fglrx(0): Using exact sizes for initial modes
[     5.703] (II) fglrx(0): Output CRT1 using initial mode 1920x1200
[     5.703] (II) fglrx(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[     5.703] (II) fglrx(0): DPI set to (96, 96)
[     5.703] (II) fglrx(0): Eyefinity capable adapter detected.
[     5.703] (II) fglrx(0): Adapter AMD Radeon HD 7700 Series    has 6 configurable heads and 1 displays connected.
[     5.703] (==) fglrx(0):  PseudoColor visuals disabled
[     5.703] (II) Loading sub module "ramdac"
[     5.703] (II) LoadModule: "ramdac"
[     5.703] (II) Module "ramdac" already built-in
[     5.703] (==) fglrx(0): NoDRI = NO
[     5.703] (==) fglrx(0): Capabilities: 0x00000000
[     5.703] (==) fglrx(0): CapabilitiesEx: 0x00000000
[     5.703] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[     5.703] (==) fglrx(0): UseFastTLS=0
[     5.703] (II) fglrx(0): Shadow Primary option: ShadowPrimary is enabled
[     5.704] (--) Depth 24 pixmap format is 32 bpp
[     5.707] (II) fglrx(0): doing swlDriScreenInit
[     5.707] (II) fglrx(0): swlDriScreenInit for fglrx driver
[     5.707] ukiDynamicMajor: found major device number 247
[     5.707] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[     5.707] ukiOpenDevice: node name is /dev/ati/card0
[     5.707] ukiOpenDevice: open result is 13, (OK)
[     5.707] ukiOpenByBusid: ukiOpenMinor returns 13
[     5.707] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[     5.707] (II) fglrx(0): [uki] DRM interface version 1.0
[     5.708] (II) fglrx(0): [uki] created "fglrx" driver at busid "PCI:1:0:0"
[     5.708] (II) fglrx(0): [uki] added 8192 byte SAREA at 0x2000
[     5.708] (II) fglrx(0): [uki] mapped SAREA 0x2000 to 0x7fba8e02e000
[     5.708] (II) fglrx(0): [uki] framebuffer handle = 0x3000
[     5.708] (II) fglrx(0): [uki] added 1 reserved context for kernel
[     5.708] (II) fglrx(0): swlDriScreenInit done
[     5.708] (II) fglrx(0): Kernel Module Version Information:
[     5.708] (II) fglrx(0):     Name: fglrx
[     5.708] (II) fglrx(0):     Version: 15.20.3
[     5.708] (II) fglrx(0):     Date: Sep  8 2015
[     5.708] (II) fglrx(0):     Desc: AMD FireGL DRM kernel module
[     5.708] (II) fglrx(0): Kernel Module version matches driver.
[     5.708] (II) fglrx(0): Kernel Module Build Time Information:
[     5.708] (II) fglrx(0):     Build-Kernel UTS_RELEASE:        4.2.0-1-amd64
[     5.708] (II) fglrx(0):     Build-Kernel MODVERSIONS:        no
[     5.708] (II) fglrx(0):     Build-Kernel __SMP__:            no
[     5.708] (II) fglrx(0):     Build-Kernel PAGE_SIZE:          0x1000
[     5.708] (II) fglrx(0): [uki] register handle = 0x00004000
[     5.710] (II) fglrx(0): DRI initialization successfull
[     5.711] (II) fglrx(0): FBADPhys: 0xf400000000 FBMappedSize: 0x010e0000
[     5.712] (==) fglrx(0): Backing store enabled
[     5.712] (**) fglrx(0): DPMS enabled
[     5.713] (II) fglrx(0): Initialized in-driver Xinerama extension
[     5.713] (**) fglrx(0): Textured Video is enabled.
[     5.713] (II) LoadModule: "glesx"
[     5.713] (II) Loading /usr/lib/xorg/modules/glesx.so
[     5.732] (II) Module glesx: vendor="X.Org Foundation"
[     5.732]     compiled for 1.4.99.906, module version = 1.0.0
[     5.732] (II) fglrx(0): GLESX enableFlags = 8784
[     5.732] (II) fglrx(0): GLESX is enabled
[     5.732] (II) LoadModule: "amdxmm"
[     5.732] (II) Loading /usr/lib/xorg/modules/amdxmm.so
[     5.734] (II) Module amdxmm: vendor="X.Org Foundation"
[     5.734]     compiled for 1.4.99.906, module version = 2.0.0
[     5.747] (II) fglrx(0): UVD feature is enabled(II) fglrx(0):
[     5.750] (II) fglrx(0): Enable composite support successfully
[     5.750] (WW) fglrx(0): Option "VendorName" is not used
[     5.750] (WW) fglrx(0): Option "ModelName" is not used
[     5.750] (II) fglrx(0): X context handle = 0x1
[     5.750] (II) fglrx(0): [DRI] installation complete
[     5.750] (==) fglrx(0): Silken mouse enabled
[     5.751] (==) fglrx(0): Using HW cursor of display infrastructure!
[     5.751] (II) fglrx(0): LPT is disabled by configure option
[     5.752] (II) fglrx(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[     5.870] (--) RandR disabled
[     5.875] (II) SELinux: Disabled on system
[     5.876] ukiDynamicMajor: found major device number 247
[     5.876] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[     5.876] ukiOpenDevice: node name is /dev/ati/card0
[     5.876] ukiOpenDevice: open result is 14, (OK)
[     5.876] ukiOpenByBusid: ukiOpenMinor returns 14
[     5.876] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[     5.878] (EE) AIGLX error: failed to open /usr/X11R6/lib64/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib64/modules/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.878] (EE) AIGLX error: failed to open /usr/lib64/dri/fglrx_dri.so, error[/usr/lib64/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.878] (EE) AIGLX error: failed to open /usr/X11R6/lib/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib/modules/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.879] (EE) AIGLX error: failed to open /usr/lib/dri/fglrx_dri.so, error[/usr/lib/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.879] (EE) AIGLX error: failed to open /usr/X11R6/lib32/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib32/modules/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.879] (EE) AIGLX error: failed to open /usr/lib32/dri/fglrx_dri.so, error[/usr/lib32/dri/fglrx_dri.so: cannot open shared object file: No such file or directory]
[     5.879] (EE) AIGLX error: failed to load OpenGL driver
[     5.879] (EE) AIGLX: reverting to software rendering
[     5.880] ukiDynamicMajor: found major device number 247
[     5.880] ukiOpenDevice: node name is /dev/ati/card0
[     5.880] ukiOpenDevice: open result is 14, (OK)
[     5.880] ukiGetBusid returned 'PCI:1:0:0'
[     5.880] ukiOpenDevice: node name is /dev/ati/card1
[     5.880] ukiOpenDevice: open result is -1, (No such device)
[     5.880] ukiOpenDevice: Open failed
[     5.880] ukiOpenDevice: node name is /dev/ati/card2
[     5.880] ukiOpenDevice: node name is /dev/ati/card3
[     5.880] ukiOpenDevice: node name is /dev/ati/card4
[     5.880] ukiOpenDevice: node name is /dev/ati/card5
[     5.880] ukiOpenDevice: node name is /dev/ati/card6
[     5.881] ukiOpenDevice: node name is /dev/ati/card7
[     5.881] ukiOpenDevice: open result is -1, (No such device)
[     5.881] ukiOpenDevice: Open failed
[     5.881] ukiOpenDevice: node name is /dev/ati/card8
[     5.881] ukiOpenDevice: node name is /dev/ati/card9
[     5.881] ukiOpenDevice: node name is /dev/ati/card10
[     5.881] ukiOpenDevice: node name is /dev/ati/card11
[     5.881] ukiOpenDevice: node name is /dev/ati/card12
[     5.881] ukiOpenDevice: node name is /dev/ati/card13
[     5.881] ukiOpenDevice: node name is /dev/ati/card14
[     5.881] ukiOpenDevice: node name is /dev/ati/card15
[     5.881] ukiDynamicMajor: found major device number 247
[     5.881] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[     5.881] ukiOpenDevice: node name is /dev/ati/card0
[     5.881] ukiOpenDevice: open result is 14, (OK)
[     5.881] ukiOpenByBusid: ukiOpenMinor returns 14
[     5.881] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[     5.923] (II) fglrx(0): OverDrive5 Detected!
[     5.931] (II) fglrx(0): Setting screen physical size to 508 x 317
[     6.008] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[     6.008] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.008] (II) LoadModule: "evdev"
[     6.008] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[     6.010] (II) Module evdev: vendor="X.Org Foundation"
[     6.010]     compiled for 1.16.4, module version = 2.9.2
[     6.010]     Module class: X.Org XInput Driver
[     6.010]     ABI class: X.Org XInput driver, version 21.0
[     6.010] (II) Using input driver 'evdev' for 'Power Button'
[     6.010] (**) Power Button: always reports core events
[     6.010] (**) evdev: Power Button: Device: "/dev/input/event4"
[     6.010] (--) evdev: Power Button: Vendor 0 Product 0x1
[     6.010] (--) evdev: Power Button: Found keys
[     6.010] (II) evdev: Power Button: Configuring as keyboard
[     6.010] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
[     6.010] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.010] (**) Option "xkb_rules" "evdev"
[     6.010] (**) Option "xkb_model" "pc105"
[     6.010] (**) Option "xkb_layout" "pl"
[     6.034] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     6.035] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.035] (II) Using input driver 'evdev' for 'Power Button'
[     6.035] (**) Power Button: always reports core events
[     6.035] (**) evdev: Power Button: Device: "/dev/input/event3"
[     6.035] (--) evdev: Power Button: Vendor 0 Product 0x1
[     6.035] (--) evdev: Power Button: Found keys
[     6.035] (II) evdev: Power Button: Configuring as keyboard
[     6.035] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3/event3"
[     6.035] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     6.035] (**) Option "xkb_rules" "evdev"
[     6.035] (**) Option "xkb_model" "pc105"
[     6.035] (**) Option "xkb_layout" "pl"
[     6.035] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event10)
[     6.035] (II) No input driver specified, ignoring this device.
[     6.035] (II) This device may have been added with another device file.
[     6.036] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event5)
[     6.036] (II) No input driver specified, ignoring this device.
[     6.036] (II) This device may have been added with another device file.
[     6.036] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event6)
[     6.037] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event7)
[     6.037] (II) No input driver specified, ignoring this device.
[     6.037] (II) This device may have been added with another device file.
[     6.037] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event8)
[     6.037] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event9)
[     6.038] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event12)
[     6.038] (II) No input driver specified, ignoring this device.
[     6.038] (II) This device may have been added with another device file.
[     6.038] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event13)
[     6.039] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event14)
[     6.039] (II) No input driver specified, ignoring this device.
[     6.039] (II) This device may have been added with another device file.
[     6.039] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event15)
[     6.039] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event16)
[     6.040] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event17)
[     6.040] (II) No input driver specified, ignoring this device.
[     6.040] (II) This device may have been added with another device file.
[     6.040] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event18)
[     6.041] (II) config/udev: Adding input device HDA Intel Line Out Side (/dev/input/event19)
[     6.041] (II) No input driver specified, ignoring this device.
[     6.041] (II) This device may have been added with another device file.
[     6.041] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event20)
[     6.042] (II) config/udev: Adding input device MLK Trust Deskset 15220 (/dev/input/event1)
[     6.042] (**) MLK Trust Deskset 15220: Applying InputClass "evdev keyboard catchall"
[     6.042] (II) Using input driver 'evdev' for 'MLK Trust Deskset 15220'
[     6.042] (**) MLK Trust Deskset 15220: always reports core events
[     6.042] (**) evdev: MLK Trust Deskset 15220: Device: "/dev/input/event1"
[     6.042] (--) evdev: MLK Trust Deskset 15220: Vendor 0x4fc Product 0x5d8
[     6.042] (--) evdev: MLK Trust Deskset 15220: Found keys
[     6.042] (II) evdev: MLK Trust Deskset 15220: Configuring as keyboard
[     6.042] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb4/4-2/4-2.2/4-2.2:1.0/0003:04FC:05D8.0001/input/input1/event1"
[     6.042] (II) XINPUT: Adding extended input device "MLK Trust Deskset 15220" (type: KEYBOARD, id 8)
[     6.042] (**) Option "xkb_rules" "evdev"
[     6.042] (**) Option "xkb_model" "pc105"
[     6.042] (**) Option "xkb_layout" "pl"
[     6.043] (II) config/udev: Adding input device MLK Trust Deskset 15220 (/dev/input/event2)
[     6.043] (**) MLK Trust Deskset 15220: Applying InputClass "evdev pointer catchall"
[     6.043] (**) MLK Trust Deskset 15220: Applying InputClass "evdev keyboard catchall"
[     6.043] (II) Using input driver 'evdev' for 'MLK Trust Deskset 15220'
[     6.043] (**) MLK Trust Deskset 15220: always reports core events
[     6.043] (**) evdev: MLK Trust Deskset 15220: Device: "/dev/input/event2"
[     6.043] (--) evdev: MLK Trust Deskset 15220: Vendor 0x4fc Product 0x5d8
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found 9 mouse buttons
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found scroll wheel(s)
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found relative axes
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found x and y relative axes
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found absolute axes
[     6.043] (II) evdev: MLK Trust Deskset 15220: Forcing absolute x/y axes to exist.
[     6.043] (--) evdev: MLK Trust Deskset 15220: Found keys
[     6.043] (II) evdev: MLK Trust Deskset 15220: Configuring as mouse
[     6.043] (II) evdev: MLK Trust Deskset 15220: Configuring as keyboard
[     6.043] (II) evdev: MLK Trust Deskset 15220: Adding scrollwheel support
[     6.043] (**) evdev: MLK Trust Deskset 15220: YAxisMapping: buttons 4 and 5
[     6.043] (**) evdev: MLK Trust Deskset 15220: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[     6.043] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb4/4-2/4-2.2/4-2.2:1.1/0003:04FC:05D8.0002/input/input2/event2"
[     6.043] (II) XINPUT: Adding extended input device "MLK Trust Deskset 15220" (type: KEYBOARD, id 9)
[     6.043] (**) Option "xkb_rules" "evdev"
[     6.043] (**) Option "xkb_model" "pc105"
[     6.043] (**) Option "xkb_layout" "pl"
[     6.043] (II) evdev: MLK Trust Deskset 15220: initialized for relative axes.
[     6.043] (WW) evdev: MLK Trust Deskset 15220: ignoring absolute axes.
[     6.043] (**) MLK Trust Deskset 15220: (accel) keeping acceleration scheme 1
[     6.043] (**) MLK Trust Deskset 15220: (accel) acceleration profile 0
[     6.043] (**) MLK Trust Deskset 15220: (accel) acceleration factor: 2.000
[     6.043] (**) MLK Trust Deskset 15220: (accel) acceleration threshold: 4
[     6.044] (II) config/udev: Adding input device MLK Trust Deskset 15220 (/dev/input/mouse0)
[     6.044] (II) No input driver specified, ignoring this device.
[     6.044] (II) This device may have been added with another device file.
[     6.044] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[     6.044] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     6.044] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[     6.044] (**) AT Translated Set 2 keyboard: always reports core events
[     6.044] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[     6.044] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[     6.045] (--) evdev: AT Translated Set 2 keyboard: Found keys
[     6.045] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[     6.045] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[     6.045] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[     6.045] (**) Option "xkb_rules" "evdev"
[     6.045] (**) Option "xkb_model" "pc105"
[     6.045] (**) Option "xkb_layout" "pl"
[     6.045] (II) config/udev: Adding input device PC Speaker (/dev/input/event11)
[     6.045] (II) No input driver specified, ignoring this device.
[     6.045] (II) This device may have been added with another device file.
[     6.051] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
[     8.010] (II) fglrx(0): EDID vendor "IVM", prod id 22017
[     8.010] (II) fglrx(0): Using EDID range info for horizontal sync
[     8.010] (II) fglrx(0): Using EDID range info for vertical refresh
[     8.010] (II) fglrx(0): Printing DDC gathered Modelines:
[     8.010] (II) fglrx(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[     8.010] (II) fglrx(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.011] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     8.011] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     8.011] (II) fglrx(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     8.011] (II) fglrx(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.011] (II) fglrx(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     8.011] (II) fglrx(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     8.011] (II) fglrx(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     8.011] (II) fglrx(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     8.011] (II) fglrx(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.011] (II) fglrx(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     8.011] (II) fglrx(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     8.011] (II) fglrx(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     8.011] (II) fglrx(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     8.011] (II) fglrx(0): Modeline "1280x1024"x76.0  141.82  1280 1376 1512 1744  1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     8.011] (II) fglrx(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.011] (II) fglrx(0): Modeline "1280x1024"x72.0  132.75  1280 1368 1504 1728  1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     8.011] (II) fglrx(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.011] (II) fglrx(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     8.011] (II) fglrx(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     8.011] (II) fglrx(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     8.088] (II) fglrx(0): EDID vendor "IVM", prod id 22017
[     8.088] (II) fglrx(0): Using hsync ranges from config file
[     8.088] (II) fglrx(0): Using vrefresh ranges from config file
[     8.088] (II) fglrx(0): Printing DDC gathered Modelines:
[     8.088] (II) fglrx(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[     8.088] (II) fglrx(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.088] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     8.088] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     8.088] (II) fglrx(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     8.088] (II) fglrx(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.088] (II) fglrx(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     8.088] (II) fglrx(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     8.088] (II) fglrx(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     8.088] (II) fglrx(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     8.088] (II) fglrx(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.088] (II) fglrx(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     8.088] (II) fglrx(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     8.088] (II) fglrx(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     8.088] (II) fglrx(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     8.088] (II) fglrx(0): Modeline "1280x1024"x76.0  141.82  1280 1376 1512 1744  1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     8.088] (II) fglrx(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.088] (II) fglrx(0): Modeline "1280x1024"x72.0  132.75  1280 1368 1504 1728  1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     8.088] (II) fglrx(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.088] (II) fglrx(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     8.088] (II) fglrx(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     8.088] (II) fglrx(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     8.365] (II) fglrx(0): EDID vendor "IVM", prod id 22017
[     8.365] (II) fglrx(0): Using hsync ranges from config file
[     8.365] (II) fglrx(0): Using vrefresh ranges from config file
[     8.365] (II) fglrx(0): Printing DDC gathered Modelines:
[     8.365] (II) fglrx(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[     8.365] (II) fglrx(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.365] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     8.365] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     8.365] (II) fglrx(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     8.365] (II) fglrx(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.365] (II) fglrx(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     8.365] (II) fglrx(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     8.365] (II) fglrx(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     8.365] (II) fglrx(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     8.365] (II) fglrx(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.365] (II) fglrx(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     8.365] (II) fglrx(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     8.365] (II) fglrx(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     8.365] (II) fglrx(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     8.365] (II) fglrx(0): Modeline "1280x1024"x76.0  141.82  1280 1376 1512 1744  1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     8.365] (II) fglrx(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.365] (II) fglrx(0): Modeline "1280x1024"x72.0  132.75  1280 1368 1504 1728  1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     8.365] (II) fglrx(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.365] (II) fglrx(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     8.365] (II) fglrx(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     8.365] (II) fglrx(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     8.383] (II) fglrx(0): EDID vendor "IVM", prod id 22017
[     8.383] (II) fglrx(0): Using hsync ranges from config file
[     8.383] (II) fglrx(0): Using vrefresh ranges from config file
[     8.383] (II) fglrx(0): Printing DDC gathered Modelines:
[     8.383] (II) fglrx(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[     8.383] (II) fglrx(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.383] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     8.383] (II) fglrx(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     8.383] (II) fglrx(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     8.383] (II) fglrx(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.383] (II) fglrx(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     8.383] (II) fglrx(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     8.383] (II) fglrx(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     8.383] (II) fglrx(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     8.383] (II) fglrx(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.383] (II) fglrx(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     8.383] (II) fglrx(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     8.383] (II) fglrx(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     8.383] (II) fglrx(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     8.383] (II) fglrx(0): Modeline "1280x1024"x76.0  141.82  1280 1376 1512 1744  1024 1025 1028 1070 -hsync +vsync (81.3 kHz e)
[     8.383] (II) fglrx(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.383] (II) fglrx(0): Modeline "1280x1024"x72.0  132.75  1280 1368 1504 1728  1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[     8.383] (II) fglrx(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     8.383] (II) fglrx(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     8.383] (II) fglrx(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     8.383] (II) fglrx(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
kolofaza
Post autor: kolofaza »
Ta instrukcja nie odnosi się do wersji Strech tylko do Stable i oldstable i nie ma gwarancji że za działa.
Na moje nie utworzyłeś konfiguracji X
po instalacji (co zapewne wykonałeś)
# aptitude update # aptitude -r install linux-headers-$(uname -r|sed 's,[^-]*-[^-]*-,,') fglrx-driver
nalezy jeszcze wykonać konfigurację:
# mkdir /etc/X11/xorg.conf.d
# echo -e 'Section "Device"\n\tIdentifier "My GPU"\n\tDriver "fglrx"\nEndSection' > /etc/X11/xorg.conf.d/20-fglrx.conf
i po późniejszym restarcie powinno być dobrze.
P.S.
Na wersji testowej mozesz jeszcze sprawdzić tutaj: https://packages.qa.debian.org/f/fglrx-driver.html
czy akurat z wersji testowej nie usunięto sterownika (kiedys mi się trafiło).
Wiem, że poradnik nie wspomina Stretch, co do konfiguracji X uczyniłem zgodnie z poradnikiem i tym twoim zacytowanym sposobem i za pomocą
aticonfig --initial
Przecież sterownik jest w repozytoriach, gdyby go nie było to nie zainstalowałby się, więc co ja mam tam niby sprawdzić na tych stronach dewelopera?
Będę musiał pochylić się nad tym wycinkiem logów, bo najwyraźniej tu jest źródło problemów:
[color=#333333][     5.878] (EE) AIGLX error: failed to open /usr/X11R6/lib64/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib64/modules/dri/fglrx_dri.so: cannot open shared object file: No such file or directory][/color]
Popołudniu spróbuje zlokalizować pliki i porobić symlinki.
AKTUALIZACJA:
Zlokalizowałem plik fglrx_dri.so w pakiecie libfglrx. Miałem już tą paczkę zainstalowałem ale pliku nie było więc przeinstalowałem paczkę co naprawiło start OpenGL.
Mimo to pod jądrem 4.3 dalej miałem czarny ekran a w logach nie znajdowałem nic pomocnego.
W między czasie uruchomiłem aktualizację systemu w której była też aktualizacja drivera fglrx.
Po aktualizacji X-y startują również pod jądrem 4.3, więc w zasadzie można uznać, że problem na jądrze 4.3 był w samym driverze, co zdajsie potwierdza się na stronie paczki.
W każdym razie problem rozwiązany i można zamknąć.
