[+] Problem z instalacj
Artrix
[+] Problem z instalacją nowych pakietów.
Post autor: Artrix »
Szukając po Google nie mogłem znaleźć odpowiedzi na mój problem, a mianowicie próbowałem zmusić Spotify do działania i w sumie udało się niestety chyba użyłem zbyt brutalnej siły ponieważ teraz nie mogę zainstalować nic z repo...
Konsola mi pluje takie coś:
# apt-get install <byle jaki pakiet>
Reading package lists... Done
Building dependency tree
nano is already the newest version.
You might want to run 'apt-get -f install' to correct these:
 libc-dev-bin : Depends: libc6 (> 2.21) but 2.19-22 is to be installed
 libc6-dev : Depends: libc6 (= 2.21-0experimental2) but 2.19-22 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Po wpisaniu apt-get -f install
Dostaje praktycznie to samo...
# apt-get install -f
Correcting dependencies... failed.
 libc-dev-bin : Depends: libc6 (> 2.21) but 2.19-22 is installed
 libc6-dev : Depends: libc6 (= 2.21-0experimental2) but 2.19-22 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Instalacja libc6 w wersji 2.21 kończy się na:
# dpkg -i libc6_2.21-0experimental2_amd64.deb
(Reading database ... 152143 files and directories currently installed.)
Preparing to replace libc6:amd64 2.19-22 (using libc6_2.21-0experimental2_amd64.deb) ...
Checking for services that may need to be restarted...
Checking init scripts...
WARNING: this version of the GNU libc requires kernel version
3.2 or later. Please upgrade your kernel before installing
glibc.
The installation of a 2.6 kernel _could_ ask you to install a new libc
first, this is NOT a bug, and should *NOT* be reported. In that case,
please add lenny sources to your /etc/apt/sources.list and run:
  apt-get install -t lenny linux-image-2.6
Then reboot into this new kernel, and proceed with your upgrade
dpkg: error processing libc6_2.21-0experimental2_amd64.deb (--install):
 subprocess new pre-installation script returned error exit status 1
Errors were encountered while processing:
Liczę na Waszą pomoc, bo sam już nie daję rady tego naprawić...
Kamilko
Post autor: Kamilko »
"Then reboot into this new kernel, and proceed with your upgrade"
Jak możesz podaj wynik i od razu jaka dystrybucja.
uname -a
A tak na szybko uważam, że masz za stary kernel.
giaur
Post autor: giaur »
Czemu upierasz się na libc6 z experimental? Chcesz koniecznie rozwalić sobie system? Jeśli nie masz Sida to nawet nie podchodź a i tak to ryzykowne.
Masz kernel starszy niz 3.2? To na czym ty siedzisz, na oldstable?
Artrix
giaur pisze:Czemu upierasz się na libc6 z experimental? Chcesz koniecznie rozwalić sobie system? Jeśli nie masz Sida to nawet nie podchodź a i tak to ryzykowne.
Nie chce rozwalać systemu... nawet nie chce instalować libc6 z experminetal, po prostu nastukałem zbyt wiele komend i teraz chcę to uratować...
Kernel: 2.6.32-042stab111.12
Distro: Wheezy
mati75
Post autor: mati75 »
to vps?
Artrix
mati75 pisze:to vps?
Tak i mam myśl czy go czasem nie zresetować i na nowo go ogarnąć.
mati75
To openvz, tylko administrator serwera może zmienić wersję jądra.
Artrix
Nie chce zmieniac wersji jadra, wolalbym pozbyc sie tego komunikatu.
mati75
Dałem Ci odpowiedź dlaczego jest ten komunikat. openvz nie nadaje się do nowszych wersji Debiana.
Artrix
Właśnie dałeś mi opowiedzieć czemu jest ten komunikat, ale nie napisałeś czy jest też jakiś inny sposób na uniknięcie go. Bo skoro wcześniej nie potrzebowałem libc6 w wersji 21 to czemu teraz potrzebuje? (w sensie czemu system potrzebuje)
