hostap z kernela 2.6.17-pp3
malinkalive
Post autor: malinkalive »
Ostatnio próbuje odpalić hostap na maszynie która udostepnia neta. Hostap robie na prismie. Klijentem ma byc winxp z karta orinoco. Po skonfigurowaniu hostap moge połączyć sie z siecią siła sygnału 100% ale na tym zabawa sie kończy nie moge zapingować prisma.
#iwconfig
imq0      no wireless extensions.
imq1      no wireless extensions.
teql0     no wireless extensions.
tunl0     no wireless extensions.
gre0      no wireless extensions.
eth1      no wireless extensions.
eth2      no wireless extensions.
eth3      IEEE 802.11b  ESSID:"test"
          Mode:Master  Frequency:2.457 GHz  Access Point: 00:0E:8E:07:E0:0E
          Bit Rate=11 Mb/s   Sensitivity=1/3
          Retry min limit:8   RTS thr :o ff   Fragment thr :o ff
          Encryption key :o ff
          Power Management :o ff
wlan0_rename  IEEE 802.11b  ESSID:"test"
          Link Quality:0  Signal level:0  Noise level:0
          Tx excessive retries:77  Invalid misc:79   Missed beacon:0
#dmesg | grep eth3
eth3: 00:02:2d:8f:71:31 auth_cb - alg=0 trans#=2 status=0 - STA authenticated
eth3: 00:02:2d:8f:71:31 assoc_cb - STA associated
eth3: updating basic rate set automatically to match with the new supported rate set
#ifconfig
eth0      Link encap:Ethernet  HWaddr 00:06:4F:02:33:16
          inet addr:ip zew   Bcast:broadcast  Mask:255.255.255.252
          RX packets:72978909 errors:66 dropped:111 overruns:21 frame:0
          TX packets:66588143 errors:0 dropped:0 overruns:0 carrier:0
          collisions:433762 txqueuelen:1000
          RX bytes:884032507 (843.0 MiB)  TX bytes:3100042131 (2.8 GiB)
          Interrupt:11 Base address:0xa800
eth1      Link encap:Ethernet  HWaddr 00:30:4F:4E:ED:A5
          inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:41637407 errors:0 dropped:0 overruns:0 frame:0
          TX packets:45116497 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4019810652 (3.7 GiB)  TX bytes:1668199220 (1.5 GiB)
          Interrupt:3 Base address:0xa400
eth2      Link encap:Ethernet  HWaddr 00:A1:B0:F1:4D:2A
          inet addr:192.168.3.1  Bcast:192.168.3.255  Mask:255.255.255.0
          RX packets:25102378 errors:807 dropped:302 overruns:144 frame:0
          TX packets:29520014 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3674114270 (3.4 GiB)  TX bytes:404105172 (385.3 MiB)
          Interrupt:10 Base address:0xa000
eth3      Link encap:UNSPEC  HWaddr 00-0E-8E-07-E0-0E-00-00-00-00-00-00-00-00-00-00
          inet addr:192.168.2.1  Bcast:192.168.2.255  Mask:255.255.255.0
          RX packets:238 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:30616 (29.8 KiB)  TX bytes:66 (66.0 b)
          Interrupt:12
imq0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          UP RUNNING NOARP  MTU:1500  Metric:1
          RX packets:72658906 errors:0 dropped:0 overruns:0 frame:0
          TX packets:72650044 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:30
          RX bytes:4101655241 (3.8 GiB)  TX bytes:4094536289 (3.8 GiB)
imq1      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          RX packets:66589097 errors:0 dropped:0 overruns:0 frame:0
          TX packets:66234535 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2025143935 (1.8 GiB)  TX bytes:1962205982 (1.8 GiB)
          RX packets:159995 errors:0 dropped:0 overruns:0 frame:0
          TX packets:159995 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:90804653 (86.5 MiB)  TX bytes:90804653 (86.5 MiB)
Wygląda dobrze ale niestety łączności brak :(
