Instalacja drukarki przez port USB na routerze Sagem Fast 2704 (b
orzechus
Instalacja drukarki przez port USB na routerze Sagem Fast 2704 (błąd "Filter failed")
Post autor: orzechus »
Proszę o pomoc.
Usiłuję uruchomić drukarkę Samsung ML-1510 podłączoną do portu usb na routerze sagem fast 2704. Przy próbie wydrukowania strony testowej pokazuje się błąd "Filter failed". Podłączona bezpośrednio do komputera drukuje bez problemu. Próbowałem przeinstalować CUPS, bez skutku. Na windows 7 również nie drukuje.
/var/log/cups/error_log
E [19/Sep/2015:16:18:35 +0200] [Job 84] Job stopped due to filter errors; please consult the error_log file for details.
D [19/Sep/2015:16:18:35 +0200] [Job 84] The following messages were recorded from 16:18:31 to 16:18:35
D [19/Sep/2015:16:18:35 +0200] [Job 84] Adding start banner page "none".
D [19/Sep/2015:16:18:35 +0200] [Job 84] Adding end banner page "none".
D [19/Sep/2015:16:18:35 +0200] [Job 84] File of type application/vnd.cups-pdf-banner queued by "anonymous".
D [19/Sep/2015:16:18:35 +0200] [Job 84] hold_until=0
D [19/Sep/2015:16:18:35 +0200] [Job 84] Queued on "ML-1510_700" by "anonymous".
D [19/Sep/2015:16:18:35 +0200] [Job 84] time-at-processing=1442672311
D [19/Sep/2015:16:18:35 +0200] [Job 84] 3 filters for job:
D [19/Sep/2015:16:18:35 +0200] [Job 84] bannertopdf (application/vnd.cups-pdf-banner to application/pdf, cost 32)
D [19/Sep/2015:16:18:35 +0200] [Job 84] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [19/Sep/2015:16:18:35 +0200] [Job 84] foomatic-rip (application/vnd.cups-pdf to printer/ML-1510_700, cost 0)
D [19/Sep/2015:16:18:35 +0200] [Job 84] job-sheets=none,none
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[0]="ML-1510_700"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[1]="84"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[2]="anonymous"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[3]="Test Page"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[4]="1"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[5]="job-uuid=urn:uuid:e4ee567c-a514-36d0-63e2-2482891487f7 job-originating-host-name=localhost time-at-creation=1442672311 time-at-processing=1442672311"
D [19/Sep/2015:16:18:35 +0200] [Job 84] argv[6]="/var/spool/cups/d00084-001"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[6]="CUPS_SERVERROOT=/etc/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[7]="CUPS_STATEDIR=/var/run/cups"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[8]="HOME=/var/spool/cups/tmp"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[10]="SERVER_ADMIN=root@debian"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[11]="SOFTWARE=CUPS/1.7.5"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[12]="TMPDIR=/var/spool/cups/tmp"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[13]="USER=root"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[14]="CUPS_MAX_MESSAGE=2047"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[16]="CUPS_ENCRYPTION=IfRequested"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[17]="IPP_PORT=631"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[18]="CHARSET=utf-8"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[19]="LANG=pl.UTF-8"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[20]="PPD=/etc/cups/ppd/ML-1510_700.ppd"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[21]="RIP_MAX_CACHE=128m"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[22]="CONTENT_TYPE=application/vnd.cups-pdf-banner"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[23]="DEVICE_URI=http://192.168.1.1:631/printers/drukarka"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[24]="PRINTER_INFO=Samsung ML-1510_700"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[25]="PRINTER_LOCATION=debian"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[26]="PRINTER=ML-1510_700"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[27]="PRINTER_STATE_REASONS=cups-ipp-conformance-failure-report,cups-ipp-missing-printer-is-accepting-jobs,cups-ipp-missing-printer-state-reasons,cups-ipp-missing-cancel-job,cups-ipp-missing-validate-job,cups-ipp-missing-job-id"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[28]="CUPS_FILETYPE=document"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-pdf"
D [19/Sep/2015:16:18:35 +0200] [Job 84] envp[30]="AUTH_I****"
D [19/Sep/2015:16:18:35 +0200] [Job 84] Started filter /usr/lib/cups/filter/bannertopdf (PID 1723)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Started filter /usr/lib/cups/filter/pdftopdf (PID 1724)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Started filter /usr/lib/cups/filter/foomatic-rip (PID 1725)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Started backend /usr/lib/cups/backend/http (PID 1726)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Sending stdin for job...
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+connecting-to-device")
D [19/Sep/2015:16:18:35 +0200] [Job 84] op='+', new_reasons=1, state_reasons=6
D [19/Sep/2015:16:18:35 +0200] [Job 84] STATE: +connecting-to-device
D [19/Sep/2015:16:18:35 +0200] [Job 84] Looking up "192.168.1.1"...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Calling FindDeviceById(cups-ML-1510_700)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Found device /org/freedesktop/ColorManager/devices/cups_ML_1510_700
D [19/Sep/2015:16:18:35 +0200] [Job 84] Calling org.freedesktop.ColorManager.Device.Get(ProfilingInhibitors)
D [19/Sep/2015:16:18:35 +0200] [Job 84] 'CM Color Calibration' Mode in SPOOLER-LESS: Off
D [19/Sep/2015:16:18:35 +0200] [Job 84] Getting input from file
D [19/Sep/2015:16:18:35 +0200] [Job 84] foomatic-rip version 1.0.61 running...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Parsing PPD file ...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option ColorSpace
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Manualfeed
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Resolution
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Economode
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option MediaType
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option RET
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Copies
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PageSize
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option ImageableArea
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PaperDimension
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Density
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option JamRecovery
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option AllowReprint
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Altitude
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PageTimeout
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PowerSaving
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PowerSaveTime
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PageSizeJCL
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option PageSizePS
D [19/Sep/2015:16:18:35 +0200] [Job 84] Added option Font
D [19/Sep/2015:16:18:35 +0200] [Job 84] Parameter Summary
D [19/Sep/2015:16:18:35 +0200] [Job 84] -----------------
D [19/Sep/2015:16:18:35 +0200] [Job 84] Spooler: cups
D [19/Sep/2015:16:18:35 +0200] [Job 84] Printer: ML-1510_700
D [19/Sep/2015:16:18:35 +0200] [Job 84] Shell: /bin/bash
D [19/Sep/2015:16:18:35 +0200] [Job 84] PPD file: /etc/cups/ppd/ML-1510_700.ppd
D [19/Sep/2015:16:18:35 +0200] [Job 84] ATTR file:
D [19/Sep/2015:16:18:35 +0200] [Job 84] Printer model: Samsung ML-1510 Foomatic/gdi
D [19/Sep/2015:16:18:35 +0200] [Job 84] Job title: Test Page
D [19/Sep/2015:16:18:35 +0200] [Job 84] File(s) to be printed:
D [19/Sep/2015:16:18:35 +0200] [Job 84] <STDIN>
D [19/Sep/2015:16:18:35 +0200] [Job 84] Ghostscript extra search path ('GS_LIB'): /usr/share/cups/fonts
D [19/Sep/2015:16:18:35 +0200] [Job 84] Printing system options:
D [19/Sep/2015:16:18:35 +0200] [Job 84] Pondering option 'job-uuid=urn:uuid:e4ee567c-a514-36d0-63e2-2482891487f7'
D [19/Sep/2015:16:18:35 +0200] [Job 84] Unknown option job-uuid=urn:uuid:e4ee567c-a514-36d0-63e2-2482891487f7.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Pondering option 'job-originating-host-name=localhost'
D [19/Sep/2015:16:18:35 +0200] [Job 84] Unknown option job-originating-host-name=localhost.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Pondering option 'time-at-creation=1442672311'
D [19/Sep/2015:16:18:35 +0200] [Job 84] Unknown option time-at-creation=1442672311.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Pondering option 'time-at-processing=1442672311'
D [19/Sep/2015:16:18:35 +0200] [Job 84] Unknown option time-at-processing=1442672311.
D [19/Sep/2015:16:18:35 +0200] [Job 84] CM Color Calibration Mode in CUPS: Off
D [19/Sep/2015:16:18:35 +0200] [Job 84] Options from the PPD file:
D [19/Sep/2015:16:18:35 +0200] [Job 84] ================================================
D [19/Sep/2015:16:18:35 +0200] [Job 84] File: <STDIN>
D [19/Sep/2015:16:18:35 +0200] [Job 84] PDF template file doesn't have form. It's okay.
D [19/Sep/2015:16:18:35 +0200] [Job 84] PID 1723 (/usr/lib/cups/filter/bannertopdf) exited with no errors.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Filetype: PDF
D [19/Sep/2015:16:18:35 +0200] [Job 84] Storing temporary files in /var/spool/cups/tmp
D [19/Sep/2015:16:18:35 +0200] [Job 84] PID 1724 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [19/Sep/2015:16:18:35 +0200] [Job 84] File contains 1 pages
D [19/Sep/2015:16:18:35 +0200] [Job 84] Starting renderer with command: gs -dFirstPage=1  -q -dBATCH -dPARANOIDSAFER -dQUIET -dNOPAUSE -dNOINTERPOLATE -sDEVICE=gdi -dDEVICEWIDTHPOINTS=595 -dDEVICEHEIGHTPOINTS=842 -r600x600 -sOutputFile=- -f    /var/spool/cups/tmp/foomatic-c1BdPN | perl -p -e 's/PJL PAGE LETTER/PJL PAGE A4/; s/PJL PAGE (\S*) AUTO/PJL PAGE $1 AUTO/; s/PJL SET TONERSAVE = OFF/PJL SET TONERSAVE = OFF\r\n\@PJL SET ECONOMODE = OFF/; s/PJL SET PAPERTYPE = NORMAL/PJL SET PAPERTYPE = NORMAL/; s/PJL SET DENSITY = 1/PJL SET DENSITY = 3/; s/(\@PJL ENTER LANGUAGE)/\@PJL SET RET = OFF\r\n$1/; s/(\@PJL ENTER LANGUAGE)/\@PJL SET JAMRECOVERY = ON\r\n$1/; s/(\@PJL ENTER LANGUAGE)/\@PJL SET REPRINT = ON\r\n$1/; s/(\@PJL ENTER LANGUAGE)/\@PJL SET ALTITUDE = OFF\r\n$1/; s/PJL COPIES = 1/PJL COPIES = 1/; s/(\@PJL ENTER LANGUAGE)/\@PJL DEFAULT TIMEOUT = 15\r\n$1/; s/(\@PJL ENTER LANGUAGE)/\@PJL DEFAULT POWERSAVE = ON\r\n$1/; s/(\@PJL ENTER LANGUAGE)/\@PJL DEFAULT POWERSAVETIME = 5\r\n$1/; '
D [19/Sep/2015:16:18:35 +0200] [Job 84] Starting process "kid3" (generation 1)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Starting process "kid4" (generation 2)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Starting process "renderer" (generation 2)
D [19/Sep/2015:16:18:35 +0200] [Job 84] JCL: %-12345X@PJL
D [19/Sep/2015:16:18:35 +0200] [Job 84] <job data>
D [19/Sep/2015:16:18:35 +0200] [Job 84] perl: warning: Setting locale failed.
D [19/Sep/2015:16:18:35 +0200] [Job 84] perl: warning: Please check that your locale settings:
D [19/Sep/2015:16:18:35 +0200] [Job 84] LANGUAGE = (unset),
D [19/Sep/2015:16:18:35 +0200] [Job 84] LC_ALL = (unset),
D [19/Sep/2015:16:18:35 +0200] [Job 84] LANG = "pl.UTF-8"
D [19/Sep/2015:16:18:35 +0200] [Job 84] are supported and installed on your system.
D [19/Sep/2015:16:18:35 +0200] [Job 84] perl: warning: Falling back to the standard locale ("C").
D [19/Sep/2015:16:18:35 +0200] [Job 84] hrDeviceDesc="Unknown"
D [19/Sep/2015:16:18:35 +0200] [Job 84] prtGeneralCurrentLocalization type is 0, expected 2!
D [19/Sep/2015:16:18:35 +0200] [Job 84] backendWaitLoop(snmp_fd=7, addr=0x7f3e7f716a18, side_cb=0x7f3e7f05abe0)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Connecting to 192.168.1.1:631
D [19/Sep/2015:16:18:35 +0200] [Job 84] Connecting to printer.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Set job-printer-state-message to "Connecting to printer.", current level=INFO
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="-cups-certificate-error")
D [19/Sep/2015:16:18:35 +0200] [Job 84] op='-', new_reasons=1, state_reasons=7
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="-connecting-to-device")
D [19/Sep/2015:16:18:35 +0200] [Job 84] STATE: -connecting-to-device
D [19/Sep/2015:16:18:35 +0200] [Job 84] Connected to printer.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Set job-printer-state-message to "Connected to printer.", current level=INFO
D [19/Sep/2015:16:18:35 +0200] [Job 84] Connected to 192.168.1.1:631...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Getting supported attributes...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Get-Printer-Attributes: successful-ok (successful-ok)
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+cups-ipp-conformance-failure-report,cups-ipp-missing-printer-is-accepting-jobs")
D [19/Sep/2015:16:18:35 +0200] [Job 84] op='+', new_reasons=2, state_reasons=6
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+cups-ipp-conformance-failure-report,cups-ipp-missing-printer-state-reasons")
D [19/Sep/2015:16:18:35 +0200] [Job 84] document-format-supported (1 values)
D [19/Sep/2015:16:18:35 +0200] [Job 84] [0] = "application/octet-stream"
D [19/Sep/2015:16:18:35 +0200] [Job 84] operations-supported (4 values)
D [19/Sep/2015:16:18:35 +0200] [Job 84] [0] = Print-Job
D [19/Sep/2015:16:18:35 +0200] [Job 84] [1] = Get-Job-Attributes
D [19/Sep/2015:16:18:35 +0200] [Job 84] [2] = Get-Jobs
D [19/Sep/2015:16:18:35 +0200] [Job 84] [3] = Get-Printer-Attributes
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+cups-ipp-conformance-failure-report,cups-ipp-missing-cancel-job")
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+cups-ipp-conformance-failure-report,cups-ipp-missing-validate-job")
D [19/Sep/2015:16:18:35 +0200] [Job 84] final_content_type="application/vnd.cups-pdf", document_format="application/octet-stream"
D [19/Sep/2015:16:18:35 +0200] [Job 84] Print-Job IPP/2.0
D [19/Sep/2015:16:18:35 +0200] [Job 84] printer-uri="http://192.168.1.1:631/printers/drukarka"
D [19/Sep/2015:16:18:35 +0200] [Job 84] requesting-user-name="anonymous"
D [19/Sep/2015:16:18:35 +0200] [Job 84] job-name="84 - Test Page"
D [19/Sep/2015:16:18:35 +0200] [Job 84] document-format="application/octet-stream"
D [19/Sep/2015:16:18:35 +0200] [Job 84] Adding all operation/job attributes.
D [19/Sep/2015:16:18:35 +0200] [Job 84] IPP/2.0 Print-Job #2
D [19/Sep/2015:16:18:35 +0200] [Job 84] ---- operation-attributes-tag ----
D [19/Sep/2015:16:18:35 +0200] [Job 84] attributes-charset charset utf-8
D [19/Sep/2015:16:18:35 +0200] [Job 84] attributes-natural-language naturalLanguage pl
D [19/Sep/2015:16:18:35 +0200] [Job 84] printer-uri uri http://192.168.1.1:631/printers/drukarka
D [19/Sep/2015:16:18:35 +0200] [Job 84] requesting-user-name nameWithoutLanguage anonymous
D [19/Sep/2015:16:18:35 +0200] [Job 84] job-name nameWithoutLanguage 84 - Test Page
D [19/Sep/2015:16:18:35 +0200] [Job 84] document-format mimeMediaType application/octet-stream
D [19/Sep/2015:16:18:35 +0200] [Job 84] ---- job-attributes-tag ----
D [19/Sep/2015:16:18:35 +0200] [Job 84] job-originating-host-name nameWithoutLanguage localhost
D [19/Sep/2015:16:18:35 +0200] [Job 84] job-uuid uri urn:uuid:e4ee567c-a514-36d0-63e2-2482891487f7
D [19/Sep/2015:16:18:35 +0200] [Job 84] ---- end-of-attributes-tag ----
D [19/Sep/2015:16:18:35 +0200] [Job 84] Sending file using HTTP/1.1 chunking...
D [19/Sep/2015:16:18:35 +0200] [Job 84] Print-Job: successful-ok (successful-ok)
D [19/Sep/2015:16:18:35 +0200] [Job 84] Print job accepted - job ID unknown.
D [19/Sep/2015:16:18:35 +0200] [Job 84] update_reasons(attr=0(), s="+cups-ipp-conformance-failure-report,cups-ipp-missing-job-id")
D [19/Sep/2015:16:18:35 +0200] [Job 84] (monitor) Get-Jobs: server-error-internal-error (Success)
D [19/Sep/2015:16:18:35 +0200] [Job 84] (monitor) job-state=pending
D [19/Sep/2015:16:18:35 +0200] [Job 84] ATTR: auth-info-required=none
D [19/Sep/2015:16:18:35 +0200] [Job 84] PID 1725 (/usr/lib/cups/filter/foomatic-rip) stopped with status 9.
D [19/Sep/2015:16:18:35 +0200] [Job 84] Hint: Try setting the LogLevel to "debug" to find out more.
D [19/Sep/2015:16:18:35 +0200] [Job 84] PID 1726 (/usr/lib/cups/backend/http) exited with no errors.
D [19/Sep/2015:16:18:35 +0200] [Job 84] renderer exited with status 141
D [19/Sep/2015:16:18:35 +0200] [Job 84] A filter used in addition to the renderer itself may have failed.Kid3 exit status: 1
D [19/Sep/2015:16:18:35 +0200] [Job 84] End of messages
D [19/Sep/2015:16:18:35 +0200] [Job 84] printer-state=3(idle)
D [19/Sep/2015:16:18:35 +0200] [Job 84] printer-state-message="Filter failed"
D [19/Sep/2015:16:18:35 +0200] [Job 84] printer-state-reasons=cups-ipp-conformance-failure-report,cups-ipp-missing-printer-is-accepting-jobs,cups-ipp-missing-printer-state-reasons,cups-ipp-missing-cancel-job,cups-ipp-missing-validate-job,cups-ipp-missing-job-id
System: Debian 8 amd64
hsurim
Post autor: hsurim »
Jeśli jest wpięta do routera, to czy system widzi ją pod tym adresem ?
http://localhost:631
orzechus
Tak, widzi ją.
hsurim
A dla pewności, uruchom (nielubiane na tym forum) Ubuntu z CD live i sprawdź, jak w nim będzie to się zachowywać (?)
Sugeruję sprawdzić to dlatego, gdyż Debian (niestety) ma kłopot np. z obsługą urządzeń (drukarka ze skanerem) podłączonymi do sieci za pośrednictwem wi-fi.
Jeśli i tam nie ruszy, to przyczyna będzie albo sam router, albo (niestety) sterownik linuksowy.
orzechus
To znaczy, drukarka nie komunikuje się z komputerem po wifi. Jest podłączona do portu usb routera, a komputer jest podłączony kablem do tego samego routera. W takim wypadku też spróbować uruchomić ją z Ubuntu?
hsurim
orzechus pisze:(...)
Tak.
U mnie, w Debianie, nie działa w pełni (drukarka działa ale skaner milczy) gdy jest podłączone do routera po wifi
Na kablu do komputera , działa wszystko.
W *ubuntu, jak podłączę ją do routera, czy komputera, to wszystko bryka
orzechus
Komputer z którego chcę wydrukować jest podłączony kablem do routera, nie po wifi.
hsurim
Nie istotne w tym momencie.
Chodzi przecież o to, czy ruszy wszystko w *ubuntu.
Jak pisałem, wystarczy uruchomić komputer z live *ubuntu (bez jego instalacji) i przez aplikację w ustawieniach "dodaj drukarkę", przeprowadź jej instalację.
Po wyniku, będziesz więcej wiedział, gdzie leży przyczyna jej niedziałania.
orzechus
Na ubuntu jest to samo. Ale wydrukowała w windows 7.
hsurim
Zassij zatem sterownik od producenta -
http://www.samsung.com/uk/support/model/ML-1510
[/url]
W środę będę w pracusi, to z ciekawości looknę, jak tam na Debianie będzie działać drukarka sieciowa (podłączona przewodowo z routerem).
