sun-java6-bin, sun-java6-pluginKod: Zaznacz cały
$ frostwire
Starting FrostWire...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.6.0]
Configuring environment...
Loading FrostWire:
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00002b7684810835, pid=7154, tid=1076017488
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.6.0-b105 mixed mode)
# Problematic frame:
# C [libc.so.6+0x2f835] catgets+0x15
# An error report file with more information is saved as /tmp/hs_err_pid7154.log
# If you would like to submit a bug report, please visit:
# [url]http://java.sun.com/webapps/bugreport/crash.jsp[/url]
/usr/lib/frostwire/runFrostwire.sh: line 125: 7154 Przerwane ${JAVA_PROGRAM_DIR}java -ea -Dorg.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog -Djava.library.path=. $EXECUTABLE -jar FrostWire.jar $ARGUMENTS
Something went wrong with FrostWire.
Maybe you're using the wrong version of Java?
(FrostWire is tested against and works best with with Sun's JRE, Java 1.4+)
The version of Java in your PATH is:
java version "1.6.0"
Java(TM) SE Runtime Environment (build 1.6.0-b105)
Java HotSpot(TM) 64-Bit Server VM (build 1.6.0-b105, mixed mode)
$ opera
ERROR: ld.so: object 'libjvm.so' from LD_PRELOAD cannot be preloaded: ignored.
ERROR: ld.so: object 'libawt.so' from LD_PRELOAD cannot be preloaded: ignored.
/usr/lib/opera/9.22-20070716.6/opera: error while loading shared libraries: libqt-mt.so.3: wrong ELF class: ELFCLASS64
$java -status
Unrecognized option: -status
Could not create the Java virtual machine.
$ java -version
