Problem z instalacj
debianU
Problem z instalacją i usuwaniem pakietów.
Post autor: debianU »
Witam, problem jest dość strasznie irytujący.
Podczas instalacji, lub próby usunięcia jakiegoś pakietu, w konsoli zaczyna mi sypać błędami, poniżej dodaje logi, proszę o pomoc.
Reading package lists... DoneBuilding dependency tree
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
23 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up shared-mime-info (1.0-1+b1) ...
Warning: program compiled against libxml 208 using older 207
/var/lib/dpkg/info/shared-mime-info.postinst: line 13: 12469 Segmentation fault        update-mime-database.real /usr/share/mime
dpkg: error processing shared-mime-info (--configure):
 subprocess installed post-installation script returned error exit status 139
dpkg: dependency problems prevent configuration of libgtk-3-0:amd64:
 libgtk-3-0:amd64 depends on shared-mime-info; however:
  Package shared-mime-info is not configured yet.
dpkg: error processing libgtk-3-0:amd64 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libcanberra-gtk3-0:amd64:
 libcanberra-gtk3-0:amd64 depends on libgtk-3-0 (>= 3.0.0); however:
  Package libgtk-3-0:amd64 is not configured yet.
dpkg: error processing libcanberra-gtk3-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-0:amd64:
 libgtk2.0-0:amd64 depends on shared-mime-info; however:
dpkg: error processing libgtk2.0-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgail18:amd64:
 libgail18:amd64 depends on libgtk2.0-0 (= 2.24.10-2); however:
  Package libgtk2.0-0:amd64 is not configured yet.
dpkg: error processing libgail18:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgtkmm-3.0-1:amd64:
 libgtkmm-3.0-1:amd64 depends on libgtk-3-0 (>= 3.4.0); however:
dpkg: error processing libgtkmm-3.0-1:amd64 (--configure):
dpkg: dependency problems prevent configuration of python-gtk2:
 python-gtk2 depends on libgtk2.0-0 (>= 2.24.0); however:
dpkg: error processing python-gtk2 (--configure):
dpkg: dependency problems prevent configuration of libglade2-0:
 libglade2-0 depends on libgtk2.0-0 (>= 2.14.0); however:
dpkg: error processing libglade2-0 (--configure):
dpkg: dependency problems prevent configuration of python-glade2:
 python-glade2 depends on libglade2-0 (>= 1:2.6.1); however:
  Package libglade2-0 is not configured yet.
 python-glade2 depends on libgtk2.0-0 (>= 2.18.0); however:
 python-glade2 depends on python-gtk2 (= 2.24.0-3+b1); however:
  Package python-gtk2 is not configured yet.
dpkg: error processing python-glade2 (--configure):
dpkg: dependency problems prevent configuration of fslint:
 fslint depends on python-gtk2 (>= 2.4); however:
 fslint depends on python-glade2; however:
  Package python-glade2 is not configured yet.
dpkg: error processing fslint (--configure):
Setting up gconf2 (3.2.5-1+build1) ...
dpkg: error processing gconf2 (--configure):
 subprocess installed post-installation script returned error exit status 245
dpkg: dependency problems prevent configuration of gstreamer0.10-gconf:amd64:
 gstreamer0.10-gconf:amd64 depends on gconf2 (>= 2.28.1-2); however:
  Package gconf2 is not configured yet.
dpkg: error processing gstreamer0.10-gconf:amd64 (--configure):
dpkg: dependency problems prevent configuration of gstreamer0.10-plugins-good:amd        64:
 gstreamer0.10-plugins-good:amd64 depends on gstreamer0.10-gconf; however:
  Package gstreamer0.10-gconf:amd64 is not configured yet.
dpkg: error processing gstreamer0.10-plugins-good:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgtk2-perl:
 libgtk2-perl depends on libgtk2.0-0 (>= 2.24.0); however:
 libgtk2-perl depends on shared-mime-info; however:
dpkg: error processing libgtk2-perl (--configure):
dpkg: dependency problems prevent configuration of libgtk2-gladexml-perl:
 libgtk2-gladexml-perl depends on libglade2-0 (>= 1:2.6.1); however:
 libgtk2-gladexml-perl depends on libgtk2.0-0 (>= 2.8.0); however:
 libgtk2-gladexml-perl depends on libgtk2-perl (>= 1.00); however:
  Package libgtk2-perl is not configured yet.
dpkg: error processing libgtk2-gladexml-perl (--configure):
dpkg: dependency problems prevent configuration of gtkorphan:
 gtkorphan depends on libgtk2-perl (>= 1:1.100-1); however:
 gtkorphan depends on libgtk2-gladexml-perl; however:
  Package libgtk2-gladexml-perl is not configured yet.
dpkg: error processing gtkorphan (--configure):
dpkg: dependency problems prevent configuration of libcanberra-gtk3-module:amd64:
 libcanberra-gtk3-module:amd64 depends on libcanberra-gtk3-0 (>= 0.25); however:
  Package libcanberra-gtk3-0:amd64 is not configured yet.
 libcanberra-gtk3-module:amd64 depends on libgtk-3-0 (>= 3.2.2-3); however:
 libcanberra-gtk3-module:amd64 depends on gconf2 (>= 2.28.1-2); however:
dpkg: error processing libcanberra-gtk3-module:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgtk-3-bin:
 libgtk-3-bin depends on libgtk-3-0 (>= 3.4.2-7); however:
dpkg: error processing libgtk-3-bin (--configure):
dpkg: dependency problems prevent configuration of libgtk2.0-bin:
 libgtk2.0-bin depends on libgtk2.0-0 (= 2.24.10-2); however:
dpkg: error processing libgtk2.0-bin (--configure):
dpkg: dependency problems prevent configuration of libwebkitgtk-1.0-0:
 libwebkitgtk-1.0-0 depends on libgail18 (>= 1.18.0); however:
  Package libgail18:amd64 is not configured yet.
 libwebkitgtk-1.0-0 depends on libgtk2.0-0 (>= 2.24.3); however:
dpkg: error processing libwebkitgtk-1.0-0 (--configure):
dpkg: dependency problems prevent configuration of mopidy:
 mopidy depends on gstreamer0.10-plugins-good; however:
  Package gstreamer0.10-plugins-good:amd64 is not configured yet.
dpkg: error processing mopidy (--configure):
dpkg: dependency problems prevent configuration of mopidy-alsamixer:
 mopidy-alsamixer depends on mopidy; however:
  Package mopidy is not configured yet.
dpkg: error processing mopidy-alsamixer (--configure):
dpkg: dependency problems prevent configuration of pavucontrol:
 pavucontrol depends on libcanberra-gtk3-0 (>= 0.25); however:
 pavucontrol depends on libgtk-3-0 (>= 3.0.0); however:
 pavucontrol depends on libgtkmm-3.0-1 (>= 3.4.0); however:
  Package libgtkmm-3.0-1:amd64 is not configured yet.
dpkg: error processing pavucontrol (--configure):
Errors were encountered while processing:
 shared-mime-info
 libgtk-3-0:amd64
 libgtk2.0-0:amd64
 libgail18:amd64
 python-gtk2
 libglade2-0
 python-glade2
 fslint
 gconf2
 libgtk2-perl
 gtkorphan
 libgtk-3-bin
 libgtk2.0-bin
 libwebkitgtk-1.0-0
 mopidy
 mopidy-alsamixer
 pavucontrol
root@vzxxxx:/var/log#
Jaka wersja Debiana?
Podaj wyniki poleceń z terminala:
cat /etc/apt/preferences
cat /etc/apt/sources.list
ls -al /etc/apt/sources.list.d
saturno
Post autor: saturno »
debianU pisze:
I wszystko jasne.
saturno co takiego? Tu nie chodzi, że brak miejsca na dysku, tylko o to że instalacja nie zajmie więcej miejsca bo zainstalowane pakiety nie zostały skonfigurowane i zainstalowane.
wykonaj najpierw
apt-get install -f
jeśli bezbłędnie doinstaluje potrzebne pliki i wszystkie przekonfiguruje to możesz dalej instalować cokolwiek więcej póżniej.
