[+] HP Deskjet 5940 problem ze sterownikiem?
syngromu88
Post autor: syngromu88 »
Witam!
Zainstalowałem swoją drukarkę za pomocą system-config-printer, oczywiście zainstalowałem wcześniej sterownik hplip.
Wczoraj doinstalowałem zestaw narzędzi hplip-gui ponieważ dodaje toolbar hp i można sprawdzić m.in. poziom tuszu.
Drukarka drukuje i wszystko raczej jest dobrze, problem pojawia się tylko podczas diagnostyki sterownika HPLIP (opcja Diagnose HPLIP Driver).
HP Linux Imaging and Printing System (ver. 3.14.6)
Self Diagnse Utility and Healing Utility ver. 1.0
Copyright (c) 2001-13 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Checking for Deprecated items....
error: This distro (i.e debian  testing) is either deprecated or not yet supported.
The diagnosis is limited on unsupported platforms. Do you want to continue?(y=yes*, n=no):
Wybieram yes (y).
Checking for HPLIP updates....
error: Failed to locate hp-upgrade utility
Checking for Dependencies....
warning: debian-testing version is not supported. Using debian-7.5 versions dependencies to verify and install...
| SYSTEM INFO |
 Kernel: 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt11-1 (2015-05-24) GNU/Linux
 Host: lenovo-b590
 Proc: 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt11-1 (2015-05-24) GNU/Linux
 Distribution: debian testing
 Bitness: 32 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.14.6
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for debian distro  testing version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf.  Generated from hplip.conf.in by configure.
[hplip]
version=3.14.6
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-doc/HTML
html=/usr/share/doc/hplip-3.14.6
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.14.6
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: Nie ma takiego pliku ani katalogu
Current contents of '~/.hplip/hplip.conf' file:
[settings]
systray_visible = 0
systray_messages = 0
[last_used]
device_uri = "hp:/usb/Deskjet_5900_series?serial=CN6811T1TY04KF"
printer_name =
working_dir = .
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[refresh]
rate = 30
enable = true
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[upgrade]
notify_upgrade = false
last_upgraded_time = 1435662560.03203
pending_upgrade_time = 0
[installation]
date_time = 30.06.2015 13:09:28
version = 3.14.6
 <Package-name>        <Package-Desc>      <Required/Optional> <Min-Version> <Installed-Version> <Status>   <Comment>
|  External Dependencies |
 policykit            Admin-Policy-framework    OPTIONAL        -               0.105           OK         -
 gs                   Ghostscript               REQUIRED        7.05            9.06            OK         -
 network              Network-wget              OPTIONAL        -               1.16.3          OK         -
 scanimage            Shell-Scanning            OPTIONAL        1.0             1.0.24          OK         -
 avahi-utils          avahi-utils               OPTIONAL        -               0.6.31          OK         -
 dbus                 DBus                      REQUIRED        -               1.8.18          OK         -
 cups                 CUPS                      REQUIRED        1.1             1.7.5           OK         'CUPS Scheduler is running'
 xsane                SANE-GUI                  OPTIONAL        0.9             0.999           OK         -
|  General Dependencies |
 error: reportlab     Python-PDF-Lib            OPTIONAL        2.0             3.2.0           MISSING    'reportlab needs to be installed'
 libcrypto            OpenSSL-Crypto-Lib        REQUIRED        -               1.0.2           OK         -
 pil                  Python-Image-Lib          OPTIONAL        -               1.1.7           OK         -
 pyqt4-dbus           PyQt4-DBUS                REQUIRED        4.0             4.11.4          OK         -
 libjpeg              JPEG-Lib                  REQUIRED        -               -               OK         -
 libpthread           POSIX-Threads-Lib         REQUIRED        -               2.19            OK         -
 python-dbus          Python-DBUS               REQUIRED        0.80.0          1.2.0           OK         -
 python-devel         Python-SDK                REQUIRED        2.2             2.7.10          OK         -
 pyqt4                Python-Qt4                REQUIRED        4.0             4.11.4          OK         -
 cups-devel           CUPS-SDK                  REQUIRED        -               1.7.5           OK         -
 sane-devel           SANE-SDK                  REQUIRED        -               1.0.24          OK         -
 libusb               USB-Lib                   REQUIRED        -               1.0             OK         -
 sane                 Scan-Lib                  REQUIRED        -               1.0.24          OK         -
 cups-image           CUPS-Image-Lib            REQUIRED        -               1.7.5           OK         -
 libnetsnmp-devel     SNMP-Networking-SDK       REQUIRED        5.0.9           5.7.3           OK         -
 python-xml           Python-XML-Lib            REQUIRED        -               2.1.0           OK         -
 python-notify        Desktop-notifications     OPTIONAL        -               -               OK         -
|  Compile Time Dependencies |
 gcc                  gcc-Compiler              REQUIRED        -               4.9.2           OK         -
 error: libtool       Build-tools               REQUIRED        -               -               MISSING    'libtool needs to be installed'
 make                 GNU-Build-tools           REQUIRED        3.0             4.0             OK         -
|  Python Extentions |
 cupsext              CUPS-Extension            REQUIRED        -               3.14.6          OK         -
 pcardext             PhotoCard-Extension       REQUIRED        -               3.14.6          OK         -
 hpmudext             IO-Extension              REQUIRED        -              3.14.6          OK
|  Scan Configuration |
 hpaio                HPLIP-SANE-Backend        REQUIRED        -               3.14.6          OK         'hpaio found in /etc/sane.d/dll.conf'
 scanext              Scan-SANE-Extension       REQUIRED        -               3.14.6          OK         -
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| DISCOVERED USB DEVICES |
  Device URI                        Model
  hp:/usb/Deskjet_5900_series?seri  HP Deskjet 5900 series
  al=CN6811T1TY04KF
| INSTALLED CUPS PRINTER QUEUES |
Deskjet_5900
Type: Printer
Device URI: hp:/usb/Deskjet_5900_series?serial=CN6811T1TY04KF
PPD: /etc/cups/ppd/Deskjet_5900.ppd
PPD Description: HP Deskjet 5900 Series, hpcups 3.14.6
Printer status: printer Deskjet_5900 is idle.  enabled since wto, 30 cze 2015, 11:04:25
Communication status: Good
| PERMISSION |
USB             Deskjet_5900                   Required        -        -        OK       Node:'/dev/bus/usb/001/002' Perm:'  root  lp rw- rw- rw- rw- rw- r--'
Missing Required Dependencies
error: 'libtool' package is missing/incompatible
Missing Optional Dependencies
error: 'python-reportlab' package is missing/incompatible
ENTER ROOT/SUPERUSER PASSWORD
Please enter the root/superuser password:
Po wpisaniu hasła root'a jest zminiająca się kreska wskazująca pracę w toku i nic się więcej nie dzieje.
Mam zaintalowane gcc, build-essential oraz lib-tool i python-reportlab, więc nie wiem w czym problem. :confused:
Proszę o pomoc.
syngromu88
Cóż... pobrałem stery z http://hplipopensource.com, zainstalowałem i wszystko jest wporzo.
Temat do zamknięcia.
Proszę pamiętać o odpowiednim oznaczaniu wątków jako rozwiązanych.
