Postix - Mail delivery failed: returning message to sender
ReVerse
Post autor: ReVerse »
Witam wszystkich :)
Skonfigurowałem sobie serwer VPS w całości według tego poradnika:
howtoforge.com/perfect-server-ubuntu-14.10-with-nginx-bind-dovecot-and-ispconfig-3#-install-postfix-dovecot-mysql-phpmyadmin-rkhunter-binutils
Wszystko działa super, poza jedną rzeczą, dokładnie mam problem z dostarczaniem poczty. Tzn wysyłam np z gmail wiadomość e-mail na skrzynkę założoną na moim VPS i dostaje wiadomość zwrotną:
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed:
reverse@nicewebmaster.com
Unrouteable address
Wysyłanie wiadomości działa bez najmniejszych problemów i dociera na wp, gmail itp, odbieranie niestety nie działa :(
main.cf
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
readme_directory = /usr/share/doc/postfix
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = nicewebmaster.com
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
home_mailbox = Maildir/
mydestination = nicewebmaster.com
master.cf
# Postfix master process configuration file.  For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type  private unpriv  chroot  wakeup  maxproc command + args
#               (yes)   (yes)   (yes)   (never) (100)
smtp      inet  n       -       -       -       -       smtpd
#smtp      inet  n       -       -       -       1       postscreen
#smtpd     pass  -       -       -       -       -       smtpd
#dnsblog   unix  -       -       -       -       0       dnsblog
#tlsproxy  unix  -       -       -       -       0       tlsproxy
submission inet n       -       -       -       -       smtpd
  -o syslog_name=postfix/submission
  -o smtpd_tls_security_level=encrypt
  -o smtpd_sasl_auth_enable=yes
  -o smtpd_client_restrictions=permit_sasl_authenticated,reject
#  -o smtpd_reject_unlisted_recipient=no
#  -o smtpd_client_restrictions=$mua_client_restrictions
#  -o smtpd_helo_restrictions=$mua_helo_restrictions
#  -o smtpd_sender_restrictions=$mua_sender_restrictions
#  -o smtpd_recipient_restrictions=
#  -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
#  -o milter_macro_daemon_name=ORIGINATING
smtps     inet  n       -       -       -       -       smtpd
  -o syslog_name=postfix/smtps
  -o smtpd_tls_wrappermode=yes
Ustawienie rekordów DNS
Plik /etc/hosts
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
127.0.0.1 localhost.localdomain localhost
# Auto-generated hostname. Please do not remove this comment.
91.230.202.157 nicewebmaster.com  nicewebmaster mail.nicewebmaster.com
::1             localhost ip6-localhost ip6-loopback
Pokaż logi jakie są zapisywane przy odbiorze wiadomości.
pawkrol
Post autor: pawkrol »
Problem dotyczy tylko gmaila czy innych dostawców też np. onet,interia itp. ?
ReVerse
Logi wrzucę jak wrócę wieczorem do domu :)
pawkrol z żadnej poczty nie dochodzi gmail, wp, interia, onet, za każdym razem wraca do mnie wiadomość "Mail delivery failed: returning message to sender"
pawkrol
Podaj mi jakiegoś maila testowego, wyślę do Ciebie i zobaczymy jak to wygląda w logach od strony nadawcy.
Bo dns wygląda w porządku, jak również połączenie telnetem przebiega prawidłowo.
W obrębie własnej domeny maile dochodzą ?
ReVerse
reverse@nicewebmaster.com lub pawel@nicewebmaster.com
Maile nie dochodzą nawet wewnątrz domeny :(
Poniżej wyciąg z logów var/log/mail.log
Jun 18 13:20:01 nicewebmaster postfix/smtpd[1952]: connect from localhost[::1]
Jun 18 13:20:01 nicewebmaster postfix/smtpd[1952]: lost connection after CONNECT from localhost[::1]
Jun 18 13:20:01 nicewebmaster postfix/smtpd[1952]: disconnect from localhost[::1]
Jun 18 13:20:16 nicewebmaster postfix/smtpd[1952]: connect from localhost[::1]
Jun 18 13:20:26 nicewebmaster postfix/smtpd[1952]: disconnect from localhost[::1]
Jun 18 13:20:53 nicewebmaster dovecot: pop3-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2297, secured, session=<rOGcB84YewAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:21:08 nicewebmaster dovecot: imap-login: Login: user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2309, secured, session=<y496CM4YgAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:21:08 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Jun 18 13:22:23 nicewebmaster dovecot: pop3(reverse@nicewebmaster.com): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Jun 18 13:22:43 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2322, secured, session=<LNwpDs4YAwAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:22:43 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=44 out=843
Jun 18 13:22:43 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2324, secured, session=<3JssDs4YEwAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:22:43 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=261 out=1691
Jun 18 13:22:43 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2326, secured, session=<WRItDs4YFQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:22:43 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:22:45 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2328, secured, session=<nMtBDs4YPAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:22:45 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Jun 18 13:23:33 nicewebmaster postfix/smtpd[1893]: timeout after END-OF-MESSAGE from localhost.localdomain[127.0.0.1]
Jun 18 13:23:33 nicewebmaster postfix/smtpd[1893]: disconnect from localhost.localdomain[127.0.0.1]
Jun 18 13:23:34 nicewebmaster postfix/smtpd[1896]: timeout after END-OF-MESSAGE from localhost.localdomain[127.0.0.1]
Jun 18 13:23:34 nicewebmaster postfix/smtpd[1896]: disconnect from localhost.localdomain[127.0.0.1]
Jun 18 13:25:01 nicewebmaster dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=::1, lip=::1, secured, session=<MVplFs4YTwAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:25:01 nicewebmaster dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=::1, lip=::1, secured, session=<gnplFs4YowAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:25:01 nicewebmaster postfix/smtpd[2394]: connect from localhost[::1]
Jun 18 13:25:01 nicewebmaster postfix/smtpd[2394]: lost connection after CONNECT from localhost[::1]
Jun 18 13:25:01 nicewebmaster postfix/smtpd[2394]: disconnect from localhost[::1]
Jun 18 13:25:40 nicewebmaster postfix/master[1430]: terminating on signal 15
Jun 18 13:25:40 nicewebmaster postfix/master[2566]: daemon started -- version 2.11.0, configuration /etc/postfix
Jun 18 13:25:47 nicewebmaster dovecot: config: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 18 13:25:47 nicewebmaster dovecot: auth: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 18 13:25:47 nicewebmaster dovecot: log: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 18 13:25:47 nicewebmaster dovecot: master: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Jun 18 13:25:47 nicewebmaster dovecot: master: Dovecot v2.2.9 starting up (core dumps disabled)
Jun 18 13:26:06 nicewebmaster postfix/smtpd[2598]: connect from ms024.swits.pl[193.106.238.29]
Jun 18 13:26:06 nicewebmaster postfix/trivial-rewrite[2604]: warning: do not list domain nicewebmaster.com in BOTH mydestination and virtual_mailbox_domains
Jun 18 13:26:06 nicewebmaster postfix/smtpd[2598]: A8D1915268BA: client=ms024.swits.pl[193.106.238.29]
Jun 18 13:26:06 nicewebmaster postfix/cleanup[2608]: A8D1915268BA: message-id=<000001d0a9eb$dc3369b0$949a3d10$@cyrklaf.eu>
Jun 18 13:26:06 nicewebmaster postfix/qmgr[2570]: A8D1915268BA: from=<kontakt@cyrklaf.eu>, size=1689, nrcpt=1 (queue active)
Jun 18 13:26:06 nicewebmaster postfix/smtpd[2598]: disconnect from ms024.swits.pl[193.106.238.29]
Jun 18 13:26:06 nicewebmaster amavis[1237]: (01237-02) (!)connect to /var/run/clamav/clamd.ctl failed, attempt #1: Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory
Jun 18 13:26:07 nicewebmaster amavis[1237]: (01237-02) (!)connect to /var/run/clamav/clamd.ctl failed, attempt #1: Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory
Jun 18 13:26:07 nicewebmaster amavis[1237]: (01237-02) (!)ClamAV-clamd: All attempts (1) failed connecting to /var/run/clamav/clamd.ctl, retrying (2)
Jun 18 13:26:13 nicewebmaster amavis[1237]: (01237-02) (!)connect to /var/run/clamav/clamd.ctl failed, attempt #1: Can't connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory
Jun 18 13:26:13 nicewebmaster amavis[1237]: (01237-02) (!)ClamAV-clamd av-scanner FAILED: run_av error: Too many retries to talk to /var/run/clamav/clamd.ctl (All attempts (1) failed connecting to /var/run/clamav/clamd.ctl) at (eval 139) line 603.\n
Jun 18 13:26:13 nicewebmaster amavis[1237]: (01237-02) (!)WARN: all primary virus scanners failed, considering backups
Jun 18 13:26:25 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2616, secured, session=<VVVeG84YfgAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:25 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=44 out=843
Jun 18 13:26:25 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2618, secured, session=<YX5hG84YkQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:25 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=261 out=1691
Jun 18 13:26:25 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2620, secured, session=<yzJiG84YlgAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:25 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:26:25 nicewebmaster postfix/smtpd[2621]: connect from localhost.localdomain[127.0.0.1]
Jun 18 13:26:25 nicewebmaster postfix/smtpd[2621]: E7F39152844E: client=localhost.localdomain[127.0.0.1]
Jun 18 13:26:25 nicewebmaster postfix/cleanup[2608]: E7F39152844E: message-id=<000001d0a9eb$dc3369b0$949a3d10$@cyrklaf.eu>
Jun 18 13:26:25 nicewebmaster postfix/qmgr[2570]: E7F39152844E: from=<kontakt@cyrklaf.eu>, size=2165, nrcpt=1 (queue active)
Jun 18 13:26:25 nicewebmaster amavis[1237]: (01237-02) Passed CLEAN {RelayedInbound}, [193.106.238.29]:33244 [87.205.78.208] <kontakt@cyrklaf.eu> -> <reverse@nicewebmaster.com>, Queue-ID: A8D1915268BA, Message-ID: <000001d0a9eb$dc3369b0$949a3d10$@cyrklaf.eu>, mail_id: vLy4imZMeYIe, Hits: 0.01, size: 1689, queued_as: E7F39152844E, 19267 ms
Jun 18 13:26:25 nicewebmaster postfix/smtpd[2621]: disconnect from localhost.localdomain[127.0.0.1]
Jun 18 13:26:25 nicewebmaster postfix/smtp[2609]: A8D1915268BA: to=<reverse@nicewebmaster.com>, relay=127.0.0.1[127.0.0.1]:10024, delay=19, delays=0.02/0.01/0/19, dsn=2.0.0, status=sent (250 2.0.0 from MTA(smtp:[127.0.0.1]:10025): 250 2.0.0 Ok: queued as E7F39152844E)
Jun 18 13:26:25 nicewebmaster postfix/qmgr[2570]: A8D1915268BA: removed
Jun 18 13:26:26 nicewebmaster postfix/local[2622]: E7F39152844E: to=<reverse@nicewebmaster.com>, relay=local, delay=0.07, delays=0.02/0.04/0/0.01, dsn=5.1.1, status=bounced (unknown user: "reverse")
Jun 18 13:26:26 nicewebmaster postfix/cleanup[2608]: 046DB1528452: message-id=<20150618172626.046DB1528452@nicewebmaster.com>
Jun 18 13:26:26 nicewebmaster postfix/qmgr[2570]: 046DB1528452: from=<>, size=4046, nrcpt=1 (queue active)
Jun 18 13:26:26 nicewebmaster postfix/bounce[2623]: E7F39152844E: sender non-delivery notification: 046DB1528452
Jun 18 13:26:26 nicewebmaster postfix/qmgr[2570]: E7F39152844E: removed
Jun 18 13:26:26 nicewebmaster postfix/smtp[2625]: 046DB1528452: to=<kontakt@cyrklaf.eu>, relay=mail.cyrklaf.eu[193.106.238.29]:25, delay=0.35, delays=0.01/0.02/0.11/0.22, dsn=2.0.0, status=sent (250 OK id=1Z5da4-0006vk-Ih)
Jun 18 13:26:26 nicewebmaster postfix/qmgr[2570]: 046DB1528452: removed
Jun 18 13:26:26 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2627, secured, session=<Qih3G84Y/QAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:26 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Jun 18 13:26:27 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2629, secured, session=<shGFG84Y4wAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:27 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:26:28 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2631, secured, session=<z0aNG84YBwAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:28 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=120 out=1541
Jun 18 13:26:28 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2633, secured, session=<oiCYG84Y2QAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:28 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=291 out=2408
Jun 18 13:26:30 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2635, secured, session=<nlaqG84YNQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:30 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:26:30 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2637, secured, session=<ib2zG84YKAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:30 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=114 out=1541
Jun 18 13:26:31 nicewebmaster dovecot: imap-login: Login: user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1, mpid=2639, secured, session=<OnfAG84YwAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:26:31 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Logi z ISPConfig
Jun 18 13:35:02 nicewebmaster postfix/smtpd[1834]: connect from localhost[::1]
Jun 18 13:35:02 nicewebmaster postfix/smtpd[1834]: lost connection after CONNECT from localhost[::1]
Jun 18 13:35:02 nicewebmaster postfix/smtpd[1834]: disconnect from localhost[::1]
Jun 18 13:35:13 nicewebmaster dovecot: imap-login: Login:  user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1867, secured, session=<Th/gOs4YrgAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:13 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=44 out=843
Jun 18 13:35:13 nicewebmaster dovecot: imap-login: Login:  user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1869, secured, session=<BnfjOs4Y/AAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:13 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=261 out=1691
Jun 18 13:35:13 nicewebmaster dovecot: imap-login: Login:  user=<reverse@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1871, secured, session=<7FfkOs4YGgAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:13 nicewebmaster dovecot: imap(reverse@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:35:23 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1873, secured, session=<3y5zO84Y2gAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:23 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=44 out=843
Jun 18 13:35:23 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1875, secured, session=<Qn51O84YCAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:23 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=261 out=1691
Jun 18 13:35:23 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1877, secured, session=<C4N2O84YDAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:23 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:35:25 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1887, secured, session=<AUuSO84YiwAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:25 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Jun 18 13:35:32 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1889, secured, session=<ahIGPM4Y1gAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:32 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=44 out=843
Jun 18 13:35:33 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1891, secured, session=<a6oIPM4Y4AAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:33 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=261 out=1691
Jun 18 13:35:33 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1893, secured, session=<5s4JPM4Y4wAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:33 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:35:33 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1895, secured, session=<4lYWPM4YuQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:33 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=79 out=777
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1834]: connect from localhost[::1]
Jun 18 13:35:42 nicewebmaster postfix/trivial-rewrite[1896]: warning: do  not list domain nicewebmaster.com in BOTH mydestination and  virtual_mailbox_domains
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1834]: warning: table  "mysql:/etc/postfix/mysql-virtual_client.cf": empty query string --  ignored
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1834]: 18952152841E: client=localhost[::1]
Jun 18 13:35:42 nicewebmaster postfix/cleanup[1903]: 18952152841E:  message-id=<70ec37b842c52cb73dc089dd2e8ec18a.squirrel@91.230.202.157>
Jun 18 13:35:42 nicewebmaster postfix/qmgr[1490]: 18952152841E:  from=<pawel@nicewebmaster.com>, size=729, nrcpt=1 (queue active)
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1834]: disconnect from localhost[::1]
Jun 18 13:35:42 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1906, secured, session=<cPCTPM4Y9wAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:42 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=613 out=524
Jun 18 13:35:42 nicewebmaster dovecot: imap-login: Login:  user=<pawel@nicewebmaster.com>, method=PLAIN, rip=::1, lip=::1,  mpid=1912, secured, session=<sH+WPM4YFQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:35:42 nicewebmaster dovecot: imap(pawel@nicewebmaster.com): Disconnected: Logged out in=117 out=1541
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1913]: connect from localhost.localdomain[127.0.0.1]
Jun 18 13:35:42 nicewebmaster postfix/smtpd[1913]: 77A63152844E: client=localhost.localdomain[127.0.0.1]
Jun 18 13:35:42 nicewebmaster postfix/cleanup[1903]: 77A63152844E:  message-id=<70ec37b842c52cb73dc089dd2e8ec18a.squirrel@91.230.202.157>
Jun 18 13:35:42 nicewebmaster postfix/qmgr[1490]: 77A63152844E:  from=<pawel@nicewebmaster.com>, size=1191, nrcpt=1 (queue active)
Jun 18 13:35:42 nicewebmaster amavis[1195]: (01195-01) Passed CLEAN  {RelayedOutbound}, LOCAL [::1]:55220 [87.205.78.208]  <pawel@nicewebmaster.com> -> <kontakt@cyrklaf.eu>,  Queue-ID: 18952152841E, Message-ID:  <70ec37b842c52cb73dc089dd2e8ec18a.squirrel@91.230.202.157>,  mail_id: VYqrs286_v3l, Hits: -1, size: 729, queued_as: 77A63152844E, 291  ms
Jun 18 13:35:42 nicewebmaster postfix/smtp[1904]: 18952152841E:  to=<kontakt@cyrklaf.eu>, relay=127.0.0.1[127.0.0.1]:10024,  delay=0.43, delays=0.1/0.04/0.01/0.29, dsn=2.0.0, status=sent (250 2.0.0  from MTA(smtp:[127.0.0.1]:10025): 250 2.0.0 Ok: queued as 77A63152844E)
Jun 18 13:35:42 nicewebmaster postfix/qmgr[1490]: 18952152841E: removed
Jun 18 13:35:42 nicewebmaster postfix/smtp[1914]: 77A63152844E:  to=<kontakt@cyrklaf.eu>, relay=mail.cyrklaf.eu[193.106.238.29]:25,  delay=0.2, delays=0.01/0.03/0.09/0.07, dsn=2.0.0, status=sent (250 OK  id=1Z5dj2-00077R-Ry)
Jun 18 13:35:42 nicewebmaster postfix/qmgr[1490]: 77A63152844E: removed
Jun 18 13:40:02 nicewebmaster dovecot: imap-login: Disconnected (no auth  attempts in 0 secs): user=<>, rip=::1, lip=::1, secured,  session=<JgISTM4YmQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:40:02 nicewebmaster dovecot: pop3-login: Disconnected (no auth  attempts in 0 secs): user=<>, rip=::1, lip=::1, secured,  session=<VSYSTM4Y/AAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:40:02 nicewebmaster postfix/smtpd[1997]: connect from localhost[::1]
Jun 18 13:40:02 nicewebmaster postfix/smtpd[1997]: lost connection after CONNECT from localhost[::1]
Jun 18 13:40:02 nicewebmaster postfix/smtpd[1997]: disconnect from localhost[::1]
Jun 18 13:40:42 nicewebmaster postfix/smtpd[1913]: timeout after END-OF-MESSAGE from localhost.localdomain[127.0.0.1]
Jun 18 13:40:42 nicewebmaster postfix/smtpd[1913]: disconnect from localhost.localdomain[127.0.0.1]
Jun 18 13:45:01 nicewebmaster dovecot: imap-login: Disconnected  (disconnected before auth was ready, waited 0 secs): user=<>,  rip=::1, lip=::1, secured,  session=<KqbsXc4YwQAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:45:01 nicewebmaster postfix/smtpd[2096]: connect from localhost[::1]
Jun 18 13:45:01 nicewebmaster dovecot: pop3-login: Disconnected (no auth  attempts in 0 secs): user=<>, rip=::1, lip=::1, secured,  session=<coHtXc4YJAAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:45:01 nicewebmaster postfix/smtpd[2096]: lost connection after CONNECT from localhost[::1]
Jun 18 13:45:01 nicewebmaster postfix/smtpd[2096]: disconnect from localhost[::1]
Jun 18 13:50:01 nicewebmaster dovecot: imap-login: Disconnected  (disconnected before auth was ready, waited 0 secs): user=<>,  rip=::1, lip=::1, secured,  session=<WWnLb84Y1QAAAAAAAAAAAAAAAAAAAAAB>
Jun 18 13:50:01 nicewebmaster postfix/smtpd[2211]: connect from localhost[::1]
pawkrol
Jeśli nawet wewnątrz domeny maile nie dochodzą, znaczy to że masz źle skonfigurowanego postfixa lub dovecota. Stawiam na to pierwsze.
Popraw najpierw błędy:
postfix/trivial-rewrite[2604]: warning: do not list domain nicewebmaster.com in BOTH mydestination and virtual_mailbox_domains amavis[1237]: (01237-02)
ReVerse
Usunąlem domenę z virtual_mailbox_domains i jest teraz tylko w mydestination
Odnośnie błędów to naprawiłem:
logi z clamav.log
Fri Jun 19 02:20:14 2015 -> --- Stopped at Fri Jun 19 02:20:14 2015
Fri Jun 19 02:20:14 2015 -> Socket file removed.
Fri Jun 19 02:20:15 2015 -> +++ Started at Fri Jun 19 02:20:15 2015
Fri Jun 19 02:20:15 2015 -> clamd daemon 0.98.7 (OS: linux-gnu, ARCH: x86_64, CPU: x86_64)
Fri Jun 19 02:20:15 2015 -> Log file size limited to 4294967295 bytes.
Fri Jun 19 02:20:15 2015 -> Reading databases from /var/lib/clamav
Fri Jun 19 02:20:15 2015 -> Not loading PUA signatures.
Fri Jun 19 02:20:15 2015 -> Bytecode: Security mode set to "TrustSigned".
Fri Jun 19 02:20:25 2015 -> Loaded 3848246 signatures.
Fri Jun 19 02:20:26 2015 -> LOCAL: Unix socket file /var/run/clamav/clamd.ctl
Fri Jun 19 02:20:26 2015 -> LOCAL: Setting connection queue length to 15
Fri Jun 19 02:20:26 2015 -> Limits: Global size limit set to 104857600 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: File size limit set to 26214400 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: Recursion level limit set to 10.
Fri Jun 19 02:20:26 2015 -> Limits: Files limit set to 10000.
Fri Jun 19 02:20:26 2015 -> Limits: MaxEmbeddedPE limit set to 10485760 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: MaxHTMLNormalize limit set to 10485760 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: MaxHTMLNoTags limit set to 2097152 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: MaxScriptNormalize limit set to 5242880 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: MaxZipTypeRcg limit set to 1048576 bytes.
Fri Jun 19 02:20:26 2015 -> Limits: MaxPartitions limit set to 50.
Fri Jun 19 02:20:26 2015 -> Limits: MaxIconsPE limit set to 100.
Fri Jun 19 02:20:26 2015 -> Archive support enabled.
Fri Jun 19 02:20:26 2015 -> Algorithmic detection enabled.
Fri Jun 19 02:20:26 2015 -> Portable Executable support enabled.
Fri Jun 19 02:20:26 2015 -> ELF support enabled.
Fri Jun 19 02:20:26 2015 -> Mail files support enabled.
Fri Jun 19 02:20:26 2015 -> OLE2 support enabled.
Fri Jun 19 02:20:26 2015 -> PDF support enabled.
Fri Jun 19 02:20:26 2015 -> SWF support enabled.
Fri Jun 19 02:20:26 2015 -> HTML support enabled.
Fri Jun 19 02:20:26 2015 -> Self checking every 3600 seconds.
logi z mail.log
Jun 19 02:15:49 nicewebmaster amavis[512]: starting. /usr/sbin/amavisd-new at nicewebmaster.com amavisd-new-2.7.1 (20120429), Unicode aware
Jun 19 02:15:49 nicewebmaster amavis[569]: Net::Server: Group Not Defined.  Defaulting to EGID '122 122'
Jun 19 02:15:49 nicewebmaster amavis[569]: Net::Server: User Not Defined.  Defaulting to EUID '112'
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Amavis::Conf        2.303
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Archive::Zip        1.30
Jun 19 02:15:49 nicewebmaster amavis[569]: Module BerkeleyDB          0.54
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Compress::Zlib      2.06
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Convert::TNEF       0.18
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Convert::UUlib      1.4
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Crypt::OpenSSL::RSA 0.28
Jun 19 02:15:49 nicewebmaster amavis[569]: Module DBD::mysql          4.025
Jun 19 02:15:49 nicewebmaster amavis[569]: Module DBI                 1.63
Jun 19 02:15:49 nicewebmaster amavis[569]: Module DB_File             1.827
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Digest::MD5         2.52
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Digest::SHA         5.84_01
Jun 19 02:15:49 nicewebmaster amavis[569]: Module File::Temp          0.23
Jun 19 02:15:49 nicewebmaster amavis[569]: Module IO::Socket::INET6   2.71
Jun 19 02:15:49 nicewebmaster amavis[569]: Module MIME::Entity        5.505
Jun 19 02:15:49 nicewebmaster amavis[569]: Module MIME::Parser        5.505
Jun 19 02:15:49 nicewebmaster amavis[569]: Module MIME::Tools         5.505
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail: :D KIM::Signer  0.4
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail: :D KIM::Verifier 0.4
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail::Header        2.12
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail::Internet      2.12
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail::SPF           v2.009
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Mail::SpamAssassin  3.004000
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Net: :D NS            0.68
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Net::Server         2.007
Jun 19 02:15:49 nicewebmaster amavis[569]: Module NetAddr::IP         4.071
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Socket6             0.25
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Time::HiRes         1.9725
Jun 19 02:15:49 nicewebmaster amavis[569]: Module URI                 1.60
Jun 19 02:15:49 nicewebmaster amavis[569]: Module Unix::Syslog        1.1
Jun 19 02:15:49 nicewebmaster amavis[569]: Amavis: :D B code      loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: SQL base code        loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: SQL::Log code        NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: SQL::Quarantine      NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Lookup::SQL code     loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Lookup::LDAP code    NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: AM.PDP-in proto code loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: SMTP-in proto code   loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Courier proto code   NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: SMTP-out proto code  loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Pipe-out proto code  NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: BSMTP-out proto code NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Local-out proto code loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: OS_Fingerprint code  NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: ANTI-VIRUS code      loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: ANTI-SPAM code       loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: ANTI-SPAM-EXT code   NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: ANTI-SPAM-C code     NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: ANTI-SPAM-SA code    loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Unpackers code       loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: DKIM code            loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Tools code           NOT loaded
Jun 19 02:15:49 nicewebmaster amavis[569]: Found $file            at /usr/bin/file
Jun 19 02:15:49 nicewebmaster amavis[569]: No $altermime,         not using it
Jun 19 02:15:49 nicewebmaster amavis[569]: Internal decoder for .mail
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .F
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .Z    at /bin/uncompress
Jun 19 02:15:49 nicewebmaster amavis[569]: Internal decoder for .gz
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .bz2  at /bin/bzip2 -d
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .xz   at /usr/bin/xz -dc
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .lzma at /usr/bin/xz -dc --format=lzma
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .lzo  at /usr/bin/lzop -d
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .rpm  tried: rpm2cpio.pl, rpm2cpio
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .cpio at /bin/pax
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .tar  at /bin/pax
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .deb  at /usr/bin/ar
Jun 19 02:15:49 nicewebmaster amavis[569]: Internal decoder for .zip
Jun 19 02:15:49 nicewebmaster amavis[569]: Internal decoder for .kmz
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .7z   tried: 7zr, 7za, 7z
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .rar  tried: unrar-free
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .arj  at /usr/bin/arj
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .arc  at /usr/bin/nomarch
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .zoo  at /usr/bin/zoo
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .doc  tried: ripole
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .cab  at /usr/bin/cabextract
Jun 19 02:15:49 nicewebmaster amavis[569]: No decoder for       .tnef
Jun 19 02:15:49 nicewebmaster amavis[569]: Internal decoder for .tnef
Jun 19 02:15:49 nicewebmaster amavis[569]: Found decoder for    .exe  at /usr/bin/arj
Jun 19 02:15:49 nicewebmaster amavis[569]: Using primary internal av scanner code for ClamAV-clamd
Jun 19 02:15:49 nicewebmaster amavis[569]: Found secondary av scanner ClamAV-clamscan at /usr/bin/clamscan
Jun 19 02:15:49 nicewebmaster amavis[569]: Deleting db files __db.002,__db.001,snmp.db,__db.003,nanny.db in /var/lib/amavis/db
Jun 19 02:15:49 nicewebmaster amavis[569]: Creating db in /var/lib/amavis/db/; BerkeleyDB 0.54, libdb 5.3
Jun 19 02:15:58 nicewebmaster dovecot: master: Dovecot v2.2.9 starting up (core dumps disabled)
Jun 19 02:16:06 nicewebmaster postfix/master[1475]: daemon started -- version 2.11.0, configuration /etc/postfix
Odnośnie złej konfiguracji postfixa poniżej są wszystkie pliki konfiguracyjne
/etc/postfix/master.cf
#628       inet  n       -       -       -       -       qmqpd
pickup    unix  n       -       -       60      1       pickup
cleanup   unix  n       -       -       -       0       cleanup
qmgr      unix  n       -       n       300     1       qmgr
#qmgr     unix  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       -       1000?   1       tlsmgr
rewrite   unix  -       -       -       -       -       trivial-rewrite
bounce    unix  -       -       -       -       0       bounce
defer     unix  -       -       -       -       0       bounce
trace     unix  -       -       -       -       0       bounce
verify    unix  -       -       -       -       1       verify
flush     unix  n       -       -       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       -       -       -       smtp
relay     unix  -       -       -       -       -       smtp
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       -       -       -       showq
error     unix  -       -       -       -       -       error
retry     unix  -       -       -       -       -       error
discard   unix  -       -       -       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       -       -       -       lmtp
anvil     unix  -       -       -       -       1       anvil
scache    unix  -       -       -       -       1       scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent.  See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/bin/maildrop -d vmail ${extension} ${recipient} ${user} ${nexthop} ${sender}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
#   lmtp    cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
#  mailbox_transport = lmtp:inet:localhost
#  virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus     unix  -       n       n       -       -       pipe
#  user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix  -       n       n       -       -       pipe
#  flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix    -    n    n    -    2    pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
  ${nexthop} ${user}
dovecot   unix  -       n       n       -       -       pipe
  flags=DROhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
amavis unix - - - - 2 smtp
        -o smtp_data_done_timeout=1200
        -o smtp_send_xforward_command=yes
127.0.0.1:10025 inet n - - - - smtpd
        -o content_filter=
        -o local_recipient_maps=
        -o relay_recipient_maps=
        -o smtpd_restriction_classes=
        -o smtpd_recipient_restrictions=permit_mynetworks,reject
        -o mynetworks=127.0.0.0/8
        -o strict_rfc821_envelopes=yes
        -o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
/etc/postifx/main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
biff = no
# appending .domain is the MUA's job.
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
# TLS parameters
smtpd_use_tls = yes
mydestination = nicewebmaster.com, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
html_directory = /usr/share/doc/postfix/html
home_mailbox = maildir/
virtual_alias_domains =
virtual_alias_maps = hash:/var/lib/mailman/data/virtual-mailman, proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /var/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf
smtpd_tls_security_level = may
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
relay_domains = mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks
smtpd_sender_restrictions = check_sender_access mysql:/etc/postfix/mysql-virtual_sender.cf
smtpd_client_restrictions = check_client_access mysql:/etc/postfix/mysql-virtual_client.cf
smtpd_client_message_rate_limit = 100
maildrop_destination_concurrency_limit = 1
maildrop_destination_recipient_limit = 1
virtual_transport = dovecot
header_checks = regexp:/etc/postfix/header_checks
mime_header_checks = regexp:/etc/postfix/mime_header_checks
nested_header_checks = regexp:/etc/postfix/nested_header_checks
body_checks = regexp:/etc/postfix/body_checks
owner_request_special = no
smtp_tls_security_level = may
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3
smtpd_tls_protocols = !SSLv2,!SSLv3
smtp_tls_protocols = !SSLv2,!SSLv3
dovecot_destination_recipient_limit = 1
smtpd_sasl_type = dovecot
content_filter = amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings
/etc/dovecot/dovecot.conf
listen = *,[::]
protocols = imap pop3
auth_mechanisms = plain login
disable_plaintext_auth = no
log_timestamp = "%Y-%m-%d %H:%M:%S "
mail_privileged_group = vmail
postmaster_address = postmaster@nicewebmaster.com
ssl_cert = </etc/postfix/smtpd.cert
ssl_key = </etc/postfix/smtpd.key
ssl_protocols = !SSLv2 !SSLv3
passdb {
  args = /etc/dovecot/dovecot-sql.conf
  driver = sql
userdb {
  driver = sql
plugin {
  quota = dict:user::file:/var/vmail/%d/%n/.quotausage
  sieve=/var/vmail/%d/%n/.sieve
service auth {
  unix_listener /var/spool/postfix/private/auth {
    group = postfix
    mode = 0660
    user = postfix
  unix_listener auth-userdb {
    group = vmail
    mode = 0600
    user = vmail
  user = root
service imap-login {
  client_limit = 1000
  process_limit = 500
protocol imap {
  mail_plugins = quota imap_quota
protocol pop3 {
  pop3_uidl_format = %08Xu%08Xv
protocol lda {
  mail_plugins = sieve quota
pawkrol
Ja bym zrobił odwrotnie. Usunął mydestination, a zostawił virtual_mailbox_domains.
Log z wysłanego maila:
Jun 19 08:47:04 serwerek postfix/smtpd[32156]: connect from host-195-189-90-33.net-bis.eu[195.189.90.33]
Jun 19 08:47:04 serwerek postfix/smtpd[32156]: Anonymous TLS connection established from host-195-189-90-33.net-bis.eu[195.189.90.33]: TLSv1 with cipher ECDHE-RSA-AES128-SHA (128/128 bits)
Jun 19 08:47:04 serwerek postfix/smtpd[32156]: E927B60FE3: client=host-195-189-90-33.net-bis.eu[195.189.90.33], sasl_method=PLAIN, sasl_username=pawel@pclan.eu
Jun 19 08:47:05 serwerek postfix/cleanup[32160]: E927B60FE3: message-id=<5583BAE4.7000507@pclan.eu>
Jun 19 08:47:05 serwerek opendkim[2060]: E927B60FE3: DKIM-Signature header added (s=mail, d=pclan.eu)
Jun 19 08:47:05 serwerek opendmarc[2164]: E927B60FE3: ignoring mail from pclan.eu
Jun 19 08:47:05 serwerek postfix/qmgr[31639]: E927B60FE3: from=<pawel@pclan.eu>, size=741, nrcpt=1 (queue active)
Jun 19 08:47:06 serwerek postfix/smtpd[32156]: disconnect from host-195-189-90-33.net-bis.eu[195.189.90.33]
Jun 19 08:47:06 serwerek postfix/smtp[32161]: Untrusted TLS connection established to mail.nicewebmaster.com[91.230.202.157]:25: TLSv1 with cipher AECDH-AES256-SHA (256/256 bits)
Jun 19 08:47:06 serwerek postfix/smtp[32161]: E927B60FE3: replace: header Received: from [127.0.0.1] (host-195-189-90-33.net-bis.eu [1: Received: from [127.0.0.1] (localhost [127.0.0.1])??(using TLSv1 with cipher ECDHE-RSA-AES128-SHA (128/128 bits))??(No client certificate requested)??by mail.pclan.eu (Postfix) with ESMTPSA id E927B60FE3??for <pawel@nicewebmaster.com>; Fri, 19 Jun 2015 08:47:04 +0200 (CEST)
Jun 19 08:47:06 serwerek postfix/smtp[32161]: E927B60FE3: to=<pawel@nicewebmaster.com>, relay=mail.nicewebmaster.com[91.230.202.157]:25, delay=1.7, delays=0.21/0.01/1.3/0.16, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as 65F38152840A)
Jun 19 08:47:06 serwerek postfix/qmgr[31639]: E927B60FE3: removed
Jun 19 08:47:10 serwerek postfix/smtpd[32162]: warning: hostname nicewebmaster.com does not resolve to address 91.230.202.157: Name or service not known
Jun 19 08:47:10 serwerek postfix/smtpd[32162]: connect from unknown[91.230.202.157]
Jun 19 08:47:10 serwerek postfix/smtpd[32162]: Anonymous TLS connection established from unknown[91.230.202.157]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
Jun 19 08:47:10 serwerek postfix/policy-spf[32165]: Policy action=PREPEND Received-SPF: none (nicewebmaster.com: No applicable sender policy available) receiver=serwerek.pclan.eu; identity=helo; helo=nicewebmaster.com; client-ip=91.230.202.157
Jun 19 08:47:10 serwerek postfix/smtpd[32162]: EA78960FE3: client=unknown[91.230.202.157]
Jun 19 08:47:11 serwerek postfix/cleanup[32160]: EA78960FE3: message-id=<20150619064709.C07831528456@nicewebmaster.com>
Jun 19 08:47:11 serwerek opendmarc[2164]: EA78960FE3: nicewebmaster.com none
Jun 19 08:47:11 serwerek postfix/qmgr[31639]: EA78960FE3: from=<>, size=4245, nrcpt=1 (queue active)
Jun 19 08:47:11 serwerek postfix/smtpd[32162]: disconnect from unknown[91.230.202.157]
Jun 19 08:47:12 serwerek postfix/pipe[32167]: EA78960FE3: to=<pawel@pclan.eu>, relay=dovecot, delay=2.3, delays=1.4/0/0/0.89, dsn=2.0.0, status=sent (delivered via dovecot service)
Jun 19 08:47:12 serwerek postfix/qmgr[31639]: EA78960FE3: removed
Ustaw w main.cf
myorigin = nicewebmaster.com
mydomain = nicewebmaster.com
myhostname = mail.nicewebmaster.com
smtp_helo_name = mail.nicewebmaster.com
W zwrotce mam: "<pawel@nicewebmaster.com>: unknown user: "pawel""
Sprawdź czy wogóle postfix dostaje się do bazy i widzi userów.
ReVerse
Dodałem, wysłałem e-mail na adres reverse@nicewebmaster.com i nie dotarł, ani nie ma póki co zwrotki. Oczywiście mydestination zakomentowałem i dodałem domenę do virtual
jak to sprawdzić?
