Problem z skasowaniem Plików
SZYBKI946
Post autor: SZYBKI946 »
Witam mam taki problem nie mogę skasować kilka klików:
Robię tak:
[color=#474747][font=tahoma]/# rm -fr ogp_agent [/font][/color]
wyskakuje mi odmowa usunięcia:
[color=#474747][font=tahoma]rm: cannot remove `ogp_agent/OGP_User_Files/1/teamspeak3-server_linux-x86/OGP_HOME_000000001_startup_scr.sh': Operation not permitted[/font][/color]
[color=#474747][font=tahoma]rm: cannot remove `ogp_agent/OGP_User_Files/1/teamspeak3-server_linux-x86/ts3server_minimal_runscript.sh': Operation not permitted[/font][/color]
[color=#474747][font=tahoma]rm: cannot remove `ogp_agent/OGP_User_Files/2/OGP_HOME_000000002_startup_scr.sh': Operation not permitted[/font][/color]
[color=#474747][font=tahoma]rm: cannot remove `ogp_agent/OGP_User_Files/2/srcds_run': Operation not permitted[/font][/color]
lsattr
A jakiś proces/ program nie używa pliku??
pomocne przy sprawdzeniu tego będzie polecenie lsof
SZYBKI946
root@ostroov1:/# lsattr
-------------e-- ./tmp
-------------e-- ./srv
-------------e-- ./nano.save
-------------e-- ./selinux
-------------e-- ./lost+found
-------------e-- ./lib
-------------e-- ./media
-------------e-- ./y.tar.gz
-------------e-- ./mnt
-------------e-- ./etc
lsattr: Operation not supported While reading flags on ./aquota.user
lsattr: Inappropriate ioctl for device While reading flags on ./proc
-------------e-- ./var
-------------e-- ./home
-------------e-- ./root
lsattr: Operation not supported While reading flags on ./aquota.group
-------------e-- ./usr
-------------e-- ./boot
-------------e-- ./ogp_agent
lsattr: Inappropriate ioctl for device While reading flags on ./sys
lsattr: Inappropriate ioctl for device While reading flags on ./dev
-------------e-- ./sbin
-------------e-- ./ogp_agent-3264-1.noarch.deb
-------------e-- ./opt
-------------e-- ./bin
-------------e-- ./reboot
lsattr: Inappropriate ioctl for device While reading flags on ./run
Proszę używać tagów Code do zamieszczania ważnych informacji systemowych, np. "wydruków" z konsoli //marcin'82
mati75
Post autor: mati75 »
Z jakiego użytkownika usuwasz?
