Ostatnio aktualizowałem Etch'a do Lenny, zainstalował sie tez nowy kernel 2.6.21.2-k7. Spowodowało to wystpienie problemow z sterownikami Nvidi. Stery instalowalem instalatorem nvidii, tak jak Kaka napisal w poradniku. Na jadrze 2.6.18.4-k7 dzialaja bez problemu. Probowalem reinstalowac niestety nie pomoglo. Oto wpis z Xorg.0.log
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux debian 2.6.21-2-k7 #1 SMP Wed Jul 11 04:29:08 UTC 2007 i686
Build Date: 14 July 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 4 19:18:43 2007
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "SyncMaster"
(**) | |-->Device "nVidia Corporation NV43 [GeForce 6600]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(WW) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
(==) RgbPath set to "/etc/X11/rgb"
(II) Loader magic: 0x81e50c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: 00:00:0: chip 10de,0369 card 1458,5001 rev a1 class 05,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0363 card 1458,0c11 rev a2 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0368 card 1458,0c11 rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:01:2: chip 10de,036a card 1458,0c11 rev a2 class 05,00,00 hdr 80
(II) PCI: 00:02:0: chip 10de,036c card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,036d card 1458,5004 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,036e card 1458,5002 rev a1 class 01,01,8a hdr 00
(II) PCI: 00:05:0: chip 10de,037f card 1458,b002 rev a2 class 01,01,85 hdr 80
(II) PCI: 00:05:1: chip 10de,037f card 1458,b002 rev a2 class 01,01,85 hdr 80
(II) PCI: 00:06:0: chip 10de,0370 card 0000,0000 rev a2 class 06,04,01 hdr 81
(II) PCI: 00:06:1: chip 10de,0371 card 1458,a002 rev a2 class 04,03,00 hdr 80
(II) PCI: 00:08:0: chip 10de,0373 card 1458,e000 rev a2 class 06,80,00 hdr 00
(II) PCI: 00:0f:0: chip 10de,0377 card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:0a:0: chip 104c,8024 card 1458,1000 rev 00 class 0c,00,10 hdr 00
(II) PCI: 02:00:0: chip 10de,0141 card 1458,3126 rev a2 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:6:0), (0,1,1), BCTRL: 0x0a00 (VGA_EN is cleared)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfb000000 - 0xfb0fffff (0x100000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:15:0), (0,2,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xfaffffff (0x3000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(--) PCI:*(2:0:0) nVidia Corporation NV43 [GeForce 6600] rev 162, Mem @ 0xf8000000/24, 0xe0000000/28, 0xf9000000/24
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfb000000 - 0xfb003fff (0x4000) MX[B]
[1] -1 0 0xfb004000 - 0xfb0047ff (0x800) MX[B]
[2] -1 0 0xfb108000 - 0xfb10800f (0x10) MX[B]
[3] -1 0 0xfb107000 - 0xfb1070ff (0x100) MX[B]
[4] -1 0 0xfb106000 - 0xfb106fff (0x1000) MX[B]
[5] -1 0 0xfb100000 - 0xfb103fff (0x4000) MX[B]
[6] -1 0 0xfb10a000 - 0xfb10afff (0x1000) MX[B]
[7] -1 0 0xfb109000 - 0xfb109fff (0x1000) MX[B]
[8] -1 0 0xfb105000 - 0xfb1050ff (0x100) MX[B]
[9] -1 0 0xfb104000 - 0xfb104fff (0x1000) MX[B]
[10] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[12] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[13] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[14] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[15] -1 0 0x00000b60 - 0x00000b63 (0x4) IX[B]
[16] -1 0 0x00000960 - 0x00000967 (0x8) IX[B]
[17] -1 0 0x00000be0 - 0x00000be3 (0x4) IX[B]
[18] -1 0 0x000009e0 - 0x000009e7 (0x8) IX[B]
[19] -1 0 0x0000c800 - 0x0000c80f (0x10) IX[B]
[20] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[21] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[22] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[23] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[24] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[25] -1 0 0x00001c80 - 0x00001cbf (0x40) IX[B]
[26] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfb000000 - 0xfb003fff (0x4000) MX[B]
[5] -1 0 0xfb004000 - 0xfb0047ff (0x800) MX[B]
[6] -1 0 0xfb108000 - 0xfb10800f (0x10) MX[B]
[7] -1 0 0xfb107000 - 0xfb1070ff (0x100) MX[B]
[8] -1 0 0xfb106000 - 0xfb106fff (0x1000) MX[B]
[9] -1 0 0xfb100000 - 0xfb103fff (0x4000) MX[B]
[10] -1 0 0xfb10a000 - 0xfb10afff (0x1000) MX[B]
[11] -1 0 0xfb109000 - 0xfb109fff (0x1000) MX[B]
[12] -1 0 0xfb105000 - 0xfb1050ff (0x100) MX[B]
[13] -1 0 0xfb104000 - 0xfb104fff (0x1000) MX[B]
[14] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[16] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[20] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[21] -1 0 0x00000b60 - 0x00000b63 (0x4) IX[B]
[22] -1 0 0x00000960 - 0x00000967 (0x8) IX[B]
[23] -1 0 0x00000be0 - 0x00000be3 (0x4) IX[B]
[24] -1 0 0x000009e0 - 0x000009e7 (0x8) IX[B]
[25] -1 0 0x0000c800 - 0x0000c80f (0x10) IX[B]
[26] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[27] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[28] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[29] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[30] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[31] -1 0 0x00001c80 - 0x00001cbf (0x40) IX[B]
[32] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
(II) LoadModule: "i2c"(II) Module already built-in
(II) LoadModule: "ddc"(II) Module already built-in
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.3.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module 100.14.11 Wed Jun 13 18:58:58 PDT 2007
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.3.0, module version = 1.2.1
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) NVIDIA dlloader X Driver 100.14.11 Wed Jun 13 18:23:34 PDT 2007
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 02:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="NVIDIA Corporation"
compiled for 7.1.99.2, module version = 1.0.0
(II) LoadModule: "ramdac"(II) Module already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[24] -1 0 0x00000b60 - 0x00000b63 (0x4) IX[B]
[25] -1 0 0x00000960 - 0x00000967 (0x8) IX[B]
[26] -1 0 0x00000be0 - 0x00000be3 (0x4) IX[B]
[27] -1 0 0x000009e0 - 0x000009e7 (0x8) IX[B]
[28] -1 0 0x0000c800 - 0x0000c80f (0x10) IX[B]
[29] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[30] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[31] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[32] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[33] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[34] -1 0 0x00001c80 - 0x00001cbf (0x40) IX[B]
[35] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[36] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[37] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(EE) NVIDIA(0): Failed to load the NVIDIA kernel module!
(EE) NVIDIA(0): *** Aborting ***
(II) UnloadModule: "nvidia"
(II) UnloadModule: "wfb"
(II) UnloadModule: "fb"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens foundPozdrawiam
