Eclipse-nie dzia
TDK8GB
Eclipse-nie działa prawidłowo po aktualizacji
Post autor: TDK8GB »
Witam!
Zaktualizowałem Debiana Jessie i Eclipse przestało mi poprawnie działać to znaczy samoczynnie się wyłącza, plugin AVR nie działa i :
Unable to create editor ID org.eclipse.cdt.ui.editor.CEditor: No editor descriptor for id org.eclipse.cdt.ui.editor.CEditor
org.eclipse.ui.PartInitException: No editor descriptor for id org.eclipse.cdt.ui.editor.CEditor
    at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:601)
    at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
    at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
    at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
    at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
    at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3537)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3189)
    at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
    at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
eclipse.buildId=debbuild
java.version=1.7.0_75
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86
Znikła jeszcze "perspektywa" pluginu AVR(to co się wybierało Window→Open Perspective.
Wesja:
Version: 3.8.1
Build id: debbuild
