Instalacja biblioteki libss2-php
Game
Post autor: Game »
Posiadam problem z zainstalowaniem pakietu libssh2-php na debianie 7.0 64Bit. Jest zainstalowany nginx i php-fpm
A gdy wpiszę polecenie aby zainstalować to posiadam taki błąd:
[color=#000000]root@s:/# sudo apt-get install libssh2-php        [/color]
[color=#000000]Building dependency tree        [/color]
[color=#000000]Reading state information... Done        [/color]
[color=#000000]Some packages could not be installed. This may mean that you have        [/color]
[color=#000000]requested an impossible situation or if you are using the unstable        [/color]
[color=#000000]or been moved out of Incoming.d packages have not yet been created        [/color]
[color=#000000]The following information may help to resolve the situation:
[/color]
[color=#000000]The following packages have unmet dependencies:        [/color]
[color=#000000][font=DejaVu Sans Mono]E: Unable to correct problems, you have held broken packages.[/font][/color][color=#CECECE][font=DejaVu Sans Mono]
[/font][/color]
