serwer transmisji video
Jak zainstalowac serwer red5 https://github.com/Red5/red5-server pod debianem jessie? kiedys byla paczka "red5-server" a teraz? Jakoś nie widzi mi się kompilacja ze źródeł. Czy ktoś może wie jak go uruchomić?
- LordRuthwen
Ja nie wiem, tak ciężko poszukać? https://github.com/Red5/installer
Próba kompilacji wywala błąd.
Po walce z paietami całość utkęła na tym:
Ktoś ma pomysł jak to ruszyć dalej?
Ehh... nikt nigdy tego nie instalował? Myślałem, że to wina wersji debiana, sprawdziłem to na stable, jednak efekt jest ten sam.
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ red5-server ---
[INFO] Deleting /home/lukasz/Pobrane/installer-master/debian/target
[INFO]
[INFO] --- maven-resources-plugin:2.7:resources (default-resources) @ red5-server ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory /home/lukasz/Pobrane/installer-master/debian/src/main/resources
[INFO]
[INFO] --- jdeb:1.4:jdeb (default-jdeb) @ red5-server ---
[INFO] Creating debian package: /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5+RELE~ASE_all.deb
[INFO] Building conffiles
[INFO] Skipping 'conffiles' generation. No entries provided.
[INFO] Creating changes file: /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5+RELE~ASE_all.changes
[INFO] Attaching created debian package /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5+RELE~ASE_all.deb
[INFO]
[INFO] --- jdeb:1.4:jdeb (default) @ red5-server ---
[INFO] No active profiles found
[INFO] Located keyring at /root/.gnupg/secring.gpg
[INFO] Creating debian package: /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5_all.deb
[WARNING] Signing requested, but no key supplied
[WARNING] Signing requested, but no passphrase supplied
[ERROR] Failed to create debian package /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5_all.deb
org.vafer.jdeb.PackagingException: Failed to create debian package /home/lukasz/Pobrane/installer-master/debian/target/red5-server_1.0.5_all.deb
at org.vafer.jdeb.DebMaker.makeDeb(DebMaker.java:296)
at org.vafer.jdeb.maven.DebMojo.execute(DebMojo.java:552)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
[/QUOTE]
[quote]
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 57.214s
[INFO] Finished at: Thu Apr 16 15:56:05 CEST 2015
[INFO] Final Memory: 13M/95M
[ERROR] Failed to execute goal org.vafer:jdeb:1.4:jdeb (default) on project red5-server: Failed to create debian package /var/www/repo/webrtc/installer-master/debian/target/red5-server_1.0.5_all.deb: NullPointerException -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] [URL]http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException[/URL]
2015-04-16 15:56:05 - INFO : * End make_deb.sh on 2015-04-16 15:55:04
2015-04-16 17:10:26 - INFO : * check commands this script uses
2015-04-16 17:10:26 - INFO : $ curl --version
curl 7.38.0 (x86_64-pc-linux-gnu) libcurl/7.38.0 OpenSSL/1.0.1k zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtmp rtsp scp sftp smtp smtps telnet tftp
Features: AsynchDNS IDN IPv6 Largefile GSS-API SPNEGO NTLM NTLM_WB SSL libz TLS-SRP
2015-04-16 17:10:26 - INFO : * Start make_deb.sh on 2015-04-16 17:10:26
2015-04-16 17:10:26 - INFO : ** change dir to : /home/lukasz/Pobrane/installer-master/debian/src/tarball
2015-04-16 17:10:26 - INFO : Tarball exists
2015-04-16 17:10:26 - INFO : ** making deb ...
2015-04-16 17:10:26 - INFO : $ mvn clean package
[INFO] Scanning for projects...
[INFO] Building Red5 :: Server
[INFO] task-segment: [clean, package]
[ERROR] BUILD ERROR
[INFO] Internal error in the plugin manager getting plugin 'org.apache.maven.plugins:maven-clean-plugin': Plugin 'org.apache.maven.plugins:maven-clean-plugin:2.5' has an invalid descriptor:
1) Plugin's descriptor contains the wrong group ID: org.vafer
2) Plugin's descriptor contains the wrong artifact ID: jdeb
3) Plugin's descriptor contains the wrong version: 1.4
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 2 seconds
[INFO] Finished at: Thu Apr 16 17:10:30 CEST 2015
[INFO] Final Memory: 11M/108M
2015-04-16 17:10:30 - INFO : * End make_deb.sh on 2015-04-16 17:10:26
