lspci -k |grep -A2 VGA
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Curacao PRO [Radeon R9 270]
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3050
Kernel driver in use: fglrx_pciKod: Zaznacz cały
uname -r
3.16.0-4-amd64 Kod: Zaznacz cały
glxinfo | grep string
server glx vendor string: ATI
server glx version string: 1.4
client glx vendor string: ATI
client glx version string: 1.4
OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL renderer string: AMD Radeon R9 200 Series
OpenGL core profile version string: 4.4.12968 Core Profile Context 14.201.1006.1002
OpenGL core profile shading language version string: 4.40
OpenGL version string: 4.4.12968 Compatibility Profile Context 14.201.1006.1002
OpenGL shading language version string: 4.40Kod: Zaznacz cały
glxinfo |grep direct
direct rendering: Yes
GL_AMD_multi_draw_indirect, GL_AMD_name_gen_delete,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_Eglxgears
XT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced, Kod: Zaznacz cały
glxgears
48456 frames in 5.0 seconds = 9691.102 FPS
50723 frames in 5.0 seconds = 10144.511 FPS
51695 frames in 5.0 seconds = 10338.955 FPS
51900 frames in 5.0 seconds = 10379.901 FPS
50659 frames in 5.0 seconds = 10131.762 FPS
52331 frames in 5.0 seconds = 10466.175 FPS
52201 frames in 5.0 seconds = 10440.108 FPS
52775 frames in 5.0 seconds = 10554.887 FPS
52667 frames in 5.0 seconds = 10533.215 FPS
50639 frames in 5.0 seconds = 10127.642 FPSKod: Zaznacz cały
4285.334] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 4285.334] (EE) AIGLX error: failed to open /usr/X11R6/lib64/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib64/modules/dri/fglrx_dri.so: cannot open shared$
[ 4285.334] (EE) AIGLX error: failed to open /usr/lib64/dri/fglrx_dri.so, error[/usr/lib64/dri/fglrx_dri.so: cannot open shared object file: No such file o$
[ 4285.334] (EE) AIGLX error: failed to open /usr/X11R6/lib/modules/dri/fglrx_dri.so, error[/usr/X11R6/lib/modules/dri/fglrx_dri.so: cannot open shared obj$
[ 4285.335Jeśli coś tu brakuje to poradżcie co doinstalować, przeinstalować żeby ta karta w pełni sprawnie chodziła.Wydaje mi się że fpsy jak na tą grafikę są też odrobine za małe.A obecnie pisze na LXDE z otwartymi kartami przeglądarki.I jak sprawić żeby gdm3 i gnome ruszyło na zamkniętych? Proszę o pomoc.Może to wina po prostu sterowników i trzeba poczekać na nowsze?
