Bind9 problem z konfiguracj
armen10
Bind9 problem z konfiguracją
Post autor: armen10 »
a czym moż być spowodowany ten błąd i jak można go naprawić ?
root@debian:/home/debian# grep named /var/log/daemon.log | tail -n 25
Feb 18 12:25:35 debian named[1017]: found 1 CPU, using 1 worker thread
Feb 18 12:25:35 debian named[1017]: using up to 4096 sockets
Feb 18 12:25:37 debian named[1017]: loading configuration from '/etc/bind/named.conf'
Feb 18 12:25:37 debian named[1017]: using default UDP/IPv4 port range: [1024, 65535]
Feb 18 12:25:37 debian named[1017]: using default UDP/IPv6 port range: [1024, 65535]
Feb 18 12:25:37 debian named[1017]: listening on IPv4 interface lo, 127.0.0.1#53
Feb 18 12:25:37 debian named[1017]: listening on IPv4 interface eth0, 10.0.119.11#53
Feb 18 12:25:37 debian named[1017]: generating session key for dynamic DNS
Feb 18 12:25:38 debian named[1017]: using built-in trusted-keys for view _default
Feb 18 12:25:38 debian named[1017]: set up managed keys zone for view _default, file '/var/named/dynamic/managed-keys.bind'
Feb 18 12:25:38 debian named[1017]: command channel listening on 127.0.0.1#953
Feb 18 12:51:48 debian named[1767]: starting BIND 9.7.3 -u bind
Feb 18 12:51:48 debian named[1767]: built with '--prefix=/usr' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--sysconfdir=/etc/bind' '--localstatedir=/var' '--enable-threads' '--enable-largefile' '--with-libtool' '--enable-shared' '--enable-static' '--with-openssl=/usr' '--with-gssapi=/usr' '--with-gnu-ld' '--with-dlz-postgres=no' '--with-dlz-mysql=no' '--with-dlz-bdb=yes' '--with-dlz-filesystem=yes' '--with-dlz-ldap=yes' '--with-dlz-stub=yes' '--with-geoip=/usr' '--enable-ipv6' 'CFLAGS=-fno-strict-aliasing -DDIG_SIGCHASE -O2' 'LDFLAGS=' 'CPPFLAGS='
Feb 18 12:51:48 debian named[1767]: adjusted limit on open files from 1024 to 1048576
Feb 18 12:51:48 debian named[1767]: found 1 CPU, using 1 worker thread
Feb 18 12:51:48 debian named[1767]: using up to 4096 sockets
Feb 18 12:51:48 debian named[1767]: loading configuration from '/etc/bind/named.conf'
Feb 18 12:51:48 debian named[1767]: using default UDP/IPv4 port range: [1024, 65535]
Feb 18 12:51:48 debian named[1767]: using default UDP/IPv6 port range: [1024, 65535]
Feb 18 12:51:48 debian named[1767]: listening on IPv4 interface lo, 127.0.0.1#53
Feb 18 12:51:48 debian named[1767]: listening on IPv4 interface eth0, 10.0.119.11#53
Feb 18 12:51:48 debian named[1767]: generating session key for dynamic DNS
Feb 18 12:51:48 debian named[1767]: using built-in trusted-keys for view _default
Feb 18 12:51:48 debian named[1767]: set up managed keys zone for view _default, file '/var/named/dynamic/managed-keys.bind'
Feb 18 12:51:48 debian named[1767]: command channel listening on 127.0.0.1#953
root@debian:/home/debian# /etc/init.d/bind9 restart
Stopping domain name service...: bind9rndc: connect failed: 127.0.0.1#953: connection refused
Starting domain name service...: bind9 failed!
Wydaj polecenie
rndc status
i wklej co wyświetli.
mati75
Post autor: mati75 »
Pokaż:
/etc/init.d/bind9 configtest
armen10
Po wpisaniu vps:/home/debian# rndc status
A po wpisaniu vps:/home/debian# /etc/init.d/bind9 configtest
Usage: /etc/init.d/bind9 {start|stop|reload|restart|force-reload|status}.
pawkrol
Post autor: pawkrol »
Pokaż konfig
/etc/bind/named.conf.options
/etc/bind/named.conf.default-zones
Wynik poleceń
/usr/sbin/named-checkconf
named-checkzone domena.com /etc/bind/zone_domena.com
armen10
[B]more/etc/bind/named.conf[/B]
include "/etc/bind/named.conf.options";
zone "." {
        type hint;
        file "/etc/bind/db.root";
zone "localhost" {
        type master;
        file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
        type master;
        file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
        type master;
        file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
        type master;
        file "/etc/bind/db.255";
include "/etc/bind/named.conf.local";
[B]
more/etc/bind/named.conf.options[/B]
options {
        directory "/var/cache/bind";
        // forwarders {
        //      0.0.0.0;
        auth-nxdomain no;    # conform to RFC1035
[B]/etc/bind/named.conf.default-zones[/B] - tego nie mam.
[B]
vps:/etc/bind# named-checkzone vps.local /etc/bind/vps.local/db.vps.local
zone vps.local/IN: loaded serial 205
OK
vps:/etc/bind#[/B]
pawkrol
Używaj znaczników
[/color]
Gdzie masz deklaracje strefy [b]db.vps.local ?[/b]
armen10
A gdzie powinna być ?
